    MMM-NewPIR v3
    67 Posts 18 Posters 31.0k Views 20 Watching
      jordes
      can i add an exception module to not hide, while hiding all others?
      • cowboysdudeC Offline
        cowboysdude Module Developer
        What is this module made for…RPI3 or RPI4?
          sdetweil @cowboysdude
          @cowboysdude I don’t understand the question?
          it supports all the different screen dimming approaches
          cowboysdudeC 1 Reply Last reply Reply Quote 1
            cowboysdude Module Developer @sdetweil
            @sdetweil Thanks Sam.
            • P Offline
              philmavedzenge
              Hi guys,
              After updating my MagicMirror to the latest version, this modules does not work. I tried reinstalling but its giving an error that i do not understand. Could someone help please? I have attached the logs, not sure if they will help.
              at Module._compile (internal/modules/cjs/loader.js:778:30)
              npm WARN notsup Unsupported engine for electron-rebuild@3.2.3: wanted: {“node”:“>=12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
              npm WARN notsup Not compatible with your version of node/npm: electron-rebuild@3.2.3
              npm WARN notsup Unsupported engine for @malept/cross-spawn-promise@2.0.0: wanted: {“node”:“>= 12.13.0”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
              npm WARN notsup Not compatible with your version of node/npm: @malept/cross-spawn-promise@2.0.0
              npm WARN notsup Unsupported engine for fs-extra@10.0.0: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
              npm WARN notsup Not compatible with your version of node/npm: fs-extra@10.0.0
              npm WARN notsup Unsupported engine for yargs@17.2.1: wanted: {“node”:“>=12”} (current: {“node”:“10.24.0”,“npm”:“6.13.6”})
              npm WARN notsup Not compatible with your version of node/npm: yargs@17.2.1
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! @bugsounet/pir@1.0.6 postinstall: electron-rebuild
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the @bugsounet/pir@1.0.6 postinstall script.
                DJBOOB66
                @philmavedzenge said in MMM-NewPIR v3:
                You need to update npm and node
                • P Offline
                  philmavedzenge @DJBOOB66
                  @djboob66 said in MMM-NewPIR v3:
                  Thanks for the response. How do I do that? Which folder should I update it in?
                  FoziF 1 Reply Last reply Reply Quote 0
                  • FoziF Offline
                    Fozi Project Sponsor @philmavedzenge
                    @philmavedzenge in your home directory execute following two commands:
                    sudo npm  install -g n
                    sudo n latest
                    This installs the latest node version
                    Edit: added sudo
                      DJBOOB66
                      Ok you need to find a working node and npm for all module if you have Bugs Google Aisstant v3 then it is best to check the module first GA v3 needs,
                      Node: v12.x.x upto v14.x.x
                      npm: = v6.14.15 (some trouble with v7.x)
                      I suggest trying.
                      Do in this order.
                      sudo npm cache clean -f
                      sudo n 14.0
                      now check npm with npm -v
                      If 6.14.15 do nothing more but over 7.x use below
                      sudo npm install -g npm@6.14.15
                      FoziF P 2 Replies Last reply Reply Quote 0
                      • FoziF Offline
                        Fozi Project Sponsor @DJBOOB66
                        @djboob66 you’re right…I forgot that there might be potential issues with the latest version. Thanks for the correction!
                        @philmavedzenge : Generally I’d recommend to use @sdetweil update script when updating to a new MM version. (see here) As you already updated to 2.17.1, use this command with force at he end instead of apply
                        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                        Sam‘s script checks, if the correct node and npm versions are installed and updates them accorgingly if necessary.
                        • 6
                        • 7
                        • 6 / 7
