    MMM-AlexaControl or MMM-AlexaOn/Off setup
    94 Posts 4 Posters 57.3k Views 5 Watching
      sdetweil @dave_
      @dave_ what port range did u specify? you need to set a unique port range for each mirror on your network.
      I see it defaults. never mind.
      if u are running a Spotify player on this machine, the two things fight over the discovery port, 1900. so u have to stop the Spotify client while Alexa does Discovery
      S D 2 Replies Last reply Reply Quote 0
        @dave_ you should see messages like this on MM startup for alexacontrol
        [2020-08-02 16:47:29.642] [INFO] Checking git for module: MMM-AlexaControl
        [2020-08-02 16:47:29.675] [LOG] Adding multicast membership for 127.0.0.1
        [2020-08-02 16:47:29.676] [LOG] Adding multicast membership for 192.168.2.11
        [2020-08-02 16:47:29.677] [LOG] server is listening on 11000
        [2020-08-02 16:47:29.679] [LOG] server is listening on 11001
        [2020-08-02 16:47:29.679] [LOG] server is listening on 11002
        [2020-08-02 16:47:29.680] [LOG] server is listening on 11005
          dave_ @sdetweil
          @sdetweil hmm so should i stop the Spotify and try again? Or what port range Should i specify it to?
            sdetweil @dave_
            @dave_ you MUST stop the spotify thing , then restart MM, see those messages and then do alexa discover devices (using real echo device)…
            once the devices are added, you can turn on the spotify tool …
              dave_ @sdetweil
              @sdetweil so i did turn of the Spotify and when i launched the magic mirror it is not showing up anything it’s blank screen Like usually when there’s something with config it says a message but in this case it’s blank
                sdetweil @dave_
                @dave_ look at the console where u started mm.
                pm2 logs --lines=100
                or
                in the window where u did npm start.
                black screen usually means missing library
                u did npm install in the AlexaControl folder, right?
                  dave_ @sdetweil
                  @sdetweil it’s finally showing on screen like the mm is working but still had no luck with discovery and Spotify is off
                    sdetweil @dave_
                    @dave_ did u see the startup messages from the module like i posted?
                      dave_ @sdetweil
                      @sdetweil alt text
                      I am not quite sure which line to look at but check the image
                      Just out of curiosity does it have to be alexa echo device like can’t a i use for a soundbar or speaker with built in alexa or maybe even the mobile app?
                        sdetweil @dave_
                        @dave_ u got the eaddressinuse error. something is using port 1900, this the the port we stopped Spotify to get access to
                        stop mm, then do
                        sudo netstat -a | grep 1900
                        in there is a response then something is still using the port.
                        I havent tried discovery from my Alexa app in a long time. since they made it possible via voice command
                        • 9
                        • 10
                        • 3 / 10
