    VGA Montitor
    18 Posts 8 Posters 5.3k Views 8 Watching
      aareben
      This probably has already been answered but I can’t seem to find it anywhere. I am using a vga monitor with my magic mirror and I was wondering if it could be dangerous to leave it on all the time. I’m using the PIR script in this HowTo but I’m just changing the screen to black instead of shutting it off. the monitor has popups (like detecting input )when turned off or on. should I just find a used HDMI monitor.
        sdetweil @aareben
        @aareben one of my systems has a VGA monitor, I also blank it, haven’t seen any issues.
          aareben @sdetweil
          @sdetweil do you have light bleed through when it’s blanked?
            sdetweil @aareben
            @aareben some. all.monitors have backlighting, so you get a glow, particularly at night.
              aareben @sdetweil
              @sdetweil if I lower the brightness and contrast to very low, will I still have glow?
                sdetweil @aareben
                @aareben yes
                  aareben @sdetweil
                  @sdetweil so then ill prob get an hdmi monitor
                    sdetweil @aareben
                    @aareben same glow there, unless u can actually power it off.
                      aareben @sdetweil
                      @sdetweil I’m pretty sure you can have the raspi turn on and off the screen through the hdmi. I will have to check on that.
                        sdetweil @aareben
                        @aareben none of my displays support that. so I blank them
                        • ? Offline
                          A Former User @sdetweil
                          I’m alone that my monitor turn off and not blanking???
                          I use:
                          Rpi3/rpi4 + hdmi/vga adapt + vga monitor
                            aareben @Guest
                            @Bugsounet I’m Sorry I dont understand what your saying. Maybe a translation error
                            • ? Offline
                              A Former User
                              sure I works !
                              I use +/- same config of you :
                              RPI3B+ or RPI4 + HDMI/VGA apdator + VGA monitor (24pcs)
                              and my monitor shutdown and turn on with pir sensor
                              • O Offline
                                orbezo
                                A little off-topic, nevertheless relevant: I have a laptop with no VGA port and I still use a very old ViewSonic CRT 21" monitor with it, using a HDMI-VGA adapter; When my computer sends the sleep signal to my external monitor through the adapter, the monitor does sleep successfully, so I assume there must be a way to make the RBPI send the same kind of signal through the HDMI port.
                                  MartiBot @aareben
                                  @aareben An OLED screen will provide a full black when blanked
                                  • E Offline
                                    ezeholz
                                    Hey! So, there are probably a lot of ways to turn on and off your monitors, but I’m gonna link the one that worked for me. I was using MMM-Remote-Control, but you can take those commands and run them expecting to turn on and off.
                                    https://github.com/Jopyth/MMM-Remote-Control/issues/168#issuecomment-572890815
                                      dhanushx012
                                      kayakbabeK 1 Reply Last reply Reply Quote 0
                                      • kayakbabeK Offline
                                        kayakbabe @dhanushx012
                                        @dhanushx012 I am like the guy who started this topic. I can’t just blank the screen by turning the hdmi output off on the pi. And, I can’t power off the monitor using CEC commands. Even though I am using a HDMI instead of VGA I have the simililar issues.
                                        Q: why not turn hdmi output off?
                                        A: Because my tv monitor detects no hdmi signal and just has to scream at me about it with a not very cute logo and ugly text. There are no settings within the monitor to turn off that message.
                                        Q: Why not power the monitor on/off?
                                        A: I can’t power it off and on using the CEC commands because I also get a annoying message and logo from the monitor when it starts up.
                                        Q: why do you have to use that monitor when it’s easy to get another one that will work either way?
                                        A: I have to use a cheap VIZIO on sale for $32 US that I got. I don’t have a spare lcd panel around to use. Some of us can’t simply buy another monitor. We are using what we have. So far all together with my pi, my $32 monitor, and some cables, molding (frame), glass, and film and a gestures sensor for $2.50. I’ve managed to spend just around $120.
                                        Problem: Same as the guy who originally posted. I need the monitor to be on at all times and sending a signal because of the first two issues listed. So, I am trying to use the MMM-grove-gestures built in way to hide all the modules… but some of the modules don’t behave and turn themselves back on. Super annoying. I’m still debugging that. I think it is inside the currentweather and weatherforecast modules
                                        Solution: get the screen to turn black
                                        And getting it to do that is the crux of the problem.
