    News module wiht pictures
    17 Posts 3 Posters 6.9k Views 3 Watching
      Sven1894
      I would like to include a rss-feed with pictures from a local newspaper in my MagicMirror. The module MMM-PNews looks exactly like I would like to have it but unfortunately you can only add feeds from this site, where my feed isn’t included. I couldn’t find a common module where you can add your own feeds. Does anyone know any module which does the same or something similar? Or is it possible to change the MMM-PNews module to display own rss-feeds? I took a look at the JavaScript code of the module but I couldn’t figure out a way to add own feeds.
      Thanks for your help and tipps!
      • cowboysdudeC
        cowboysdude Module Developer
        What is your feed? MMM-PNews is something I wrote :)
        Reply Quote 1
          Sven1894 @cowboysdude
          @cowboysdude Hey thanks for your answer!
          This is the link to the feed: https://www.badisches-tagblatt.de/LokalesBadenBaden.rss
          cowboysdudeC 1 Reply Last reply
          • cowboysdudeC
            cowboysdude Module Developer @Sven1894
            @Sven1894 Let me take a look at it! :) Be happy to. Should have something for you by tomorrow at some point :)
            Reply Quote 1
            • cowboysdudeC
              That should work for you :)
              Instead of News Source I put the author as the news source doesn’t change.
              Reply Quote 3
                @cowboysdude Wow thank you so much! :) It works really good, thank you! :)
                Reply Quote 1
                • cowboysdudeC
                  @Sven1894 If the language is off let me know so we can change it… I’m talking about for example ‘2 Tage vor’…want to make sure it’s correct.
                  Reply Quote 2
                  • Mykle1M
                    @cowboysdude
                    You’re so awesome!
                    Reply Quote 2
                    • cowboysdudeC
                      cowboysdude Module Developer @Mykle1
                      @Mykle1 said in News module wiht pictures:
                      @cowboysdude
                      You’re so awesome!
                      I know, right? LOL
                      Reply Quote 1
                        @cowboysdude Here’s a list of the translation errors that I noticed:
                        • ‘2 Jahre vor’ is correctly ‘vor 2 Jahren’
                        • ‘1 Jahr vor’ is correctly ‘vor 1 Jahr’
                        • ‘2 Monate vor’ is correctly ‘vor 2 Monaten’
                        • ‘1 Monat vor’ is correctly ‘vor 1 Monat’
                        • ‘2 Wochen vor’ is correctly ‘vor 2 Wochen’
                        • ‘1 Woche vor’ is correctly ‘vor 1 Woche’
                        • ‘2 Tage vor’ is correctly ‘vor 2 Tagen’
                        • ‘1 Tag vor’ is correctly ‘vor 1 Tag’
                        • ‘2 Std vor’ is correctly ‘vor 2 Std’ or ‘vor 2 Stunden’ - ‘Std’ is the abbreviation for ‘Stunde’ or ‘Stunden’
                        • ‘2 Protokoll vor’ (I think that should stand for minutes?) - is correctly ‘vor 2 Minuten’
                        • ‘1 Minute vor’ is correctly ‘vor 1 Minute’
                        • ‘2 seconds vor’ is correclty ‘vor 2 Sekunden’
                        • ‘1 seconds vor’ is correctly ‘vor 1 Sekunde’
                        I was able to correct it myself. The rest seems all correct.
                        Thank you for the effort you put in this! :)
                          Sven1894
                          @cowboysdude I noticed another error: If no author is specified in an RSS entry, the entry will not be displayed. When the first entry of the feed has no author, the module won’t display anything till an entry with an author is loaded.
                          I fixed the bug myself but wanted to let you know about it anyway :)
                          • cowboysdudeC
                            @Sven1894 said in News module wiht pictures:
                            Jahren
                            I will make those corrections after work tonight and post back so you can do a git pull to update :)
                            Reply Quote 1
                              @cowboysdude Alright thanks :)
                                Sven1894
                                @cowboysdude Is it possible to put the date, author and so on under the picture? I think it would look better there :)
                                • cowboysdudeC
                                  Not really. It’s written as a flex-container so 3 divs can be put side by side.
                                  You can play with it if you want :) Can’t get into too much trouble as it’s on github and if it gets messed up you can always just go get it and copy over the messed up files :)
                                  How to update:
                                  ~MagicMirror/modules/MMM-YourNews
                                  in that directory type: ‘git pull’
                                  That should give you the new version with no errors for no author :)
                                  Reply Quote 1
                                    @cowboysdude alright thank you :)
                                    Reply Quote 1
                                    • cowboysdudeC
                                      @Sven1894 You’re Welcome!
                                      Reply Quote 1
