    Black screen after 2.13 update - tentatively resolved
    53 Posts 9 Posters 21.5k Views 9 Watching
      sdetweil @Klinge
      @Klinge looks like u did not run
      npm install
      after the git pull
      darksky looks like it will need one too
      or use the upgrade script with force at the end, instead of apply
      see here
      • swvalentiS Offline
        swvalenti Project Sponsor
        Sam,
        Used your scrips on 3 updates with no issue except for one install. Getting black screen and ran the logs showing calendar error?
        /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
        0|MagicMir |   syscall: 'read'
        0|MagicMir | }
        0|MagicMir | [2020-09-29 00:11:23.035] [ERROR]  Calendar Error. Could not fetch calendar:  http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics Error: connect ETIMEDOUT 69.16.220.190:80
        0|MagicMir |     at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1054:14) {
        0|MagicMir |   errno: 'ETIMEDOUT',
        0|MagicMir |   code: 'ETIMEDOUT',
        0|MagicMir |   syscall: 'connect',
        0|MagicMir |   address: '69.16.220.190',
        0|MagicMir |   port: 80
        0|MagicMir | }
        0|MagicMir | [25300:0930/035804.824753:FATAL:memory.cc(22)] Out of memory. size=262144
        0|MagicMir | [12409:1001/033404.599579:FATAL:memory.cc(22)] Out of memory. size=262144
        0|MagicMir | [14477:1001/034403.637658:FATAL:memory.cc(22)] Out of memory. size=262144
        0|MagicMir | [14677:1001/034505.102662:FATAL:memory.cc(22)] Out of memory. size=262144
        0|MagicMir | [1436:1002/084636.370183:FATAL:memory.cc(22)] Out of memory. size=262144
        /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
        0|MagicMir | [2020-10-02 08:53:45.855] [LOG]    No helper found for module: MMM-EyeCandy.
        0|MagicMir | [2020-10-02 08:53:45.856] [LOG]    No helper found for module: on-this-day.
        0|MagicMir | [2020-10-02 08:53:45.856] [LOG]    All module helpers loaded.
        0|MagicMir | [2020-10-02 08:53:46.035] [LOG]    Starting server on port 8080 ...
        0|MagicMir | [2020-10-02 08:53:46.044] [INFO]   You're using a full whitelist configuration to allow for all IPs
        0|MagicMir | [2020-10-02 08:53:46.053] [LOG]    Server started ...
        0|MagicMir | [2020-10-02 08:53:46.054] [LOG]    Connecting socket for: updatenotification
        0|MagicMir | [2020-10-02 08:53:46.056] [LOG]    Connecting socket for: calendar
        0|MagicMir | [2020-10-02 08:53:46.057] [LOG]    Starting node helper for: calendar
        0|MagicMir | [2020-10-02 08:53:46.058] [LOG]    Connecting socket for: MMM-EARTH
        0|MagicMir | [2020-10-02 08:53:46.059] [LOG]    Starting module: MMM-EARTH
        0|MagicMir | [2020-10-02 08:53:46.060] [LOG]    Connecting socket for: MMM-DarkSkyForecast
        0|MagicMir | [2020-10-02 08:53:46.061] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
        0|MagicMir | [2020-10-02 08:53:46.062] [LOG]    Sockets connected & modules started ...
        0|MagicMir | [2020-10-02 08:53:46.177] [LOG]    Launching application.
          sdetweil @swvalenti
          @swvalenti hm… connection timeout
          it should handle that for sure.
          I will look at the code in a while
          that url worked here just now
            Hmm weird, two other updates went fine and this one only has the error shown giving black screen. Ran script again too and didn’t do anything. Restarted pi and nothing still error and black screen.
              sdetweil @swvalenti
              @swvalenti that calendar problem is from Sept 29. so not relevant now
              can u open the dev window, see the instructions a few messages back
              • K Offline
                Klinge @sdetweil
                @sdetweil you are right. After an npm install it works. But I don´t understand it. Because, I run an update script with git pull && npm install in the MagicMirror Folder.
                Whtatever, after the npm install it works. Is it running now because the electron was rebuilt?
                Thank you for your help.
                  sdetweil @Klinge
                  @Klinge said in Black screen after 2.13 update - tentatively resolved:
                  where did u run this npm install?
                  that command stinks,
                  if git pull returns non-0, then the npm install will not be executed
                  "&&" is used to chain commands together, such that the next command is run if and only if the preceding command exited without errors
                  use my script!..
                    This is what the dev console error is…
                    /home/pi/MagicMirror…rity-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
                      protocols.This exposes users of this app to unnecessary security risks.
                      Consider loading the following resources over HTTPS or FTPS.
                     - http://0.0.0.0:8080/css/main.css
                    - http://0.0.0.0:8080/fonts/roboto.css
                    - http://0.0.0.0:8080/socket.io/socket.io.js
                    - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
                    - http://0.0.0.0:8080/js/defaults.js
                    - http://0.0.0.0:8080/config/config.js
                    - http://0.0.0.0:8080/vendor/vendor.js
                    - http://0.0.0.0:8080/modules/default/defaultmodules.js
                    - http://0.0.0.0:8080/js/logger.js
                    - http://0.0.0.0:8080/translations/translations.js
                    - http://0.0.0.0:8080/js/translator.js
                    - http://0.0.0.0:8080/js/class.js
                    - http://0.0.0.0:8080/js/module.js
                    - http://0.0.0.0:8080/js/loader.js
                    - http://0.0.0.0:8080/js/socketclient.js
                    - http://0.0.0.0:8080/js/main.js
                    - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
                    - http://0.0.0.0:8080/translations/en.json
                    - http://0.0.0.0:8080/modules/default/alert//alert.js
                    - http://0.0.0.0:8080/modules/default/alert/notificationFx.js
                    - http://0.0.0.0:8080/modules/default/alert/notificationFx.css
                    - http://0.0.0.0:8080/vendor/css/font-awesome.css
                    - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
                    - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
                    For more information and help, consult
                    https://electronjs.org/docs/tutorial/security.
                     This warning will not show up
                    once the app is packaged.
                    /home/pi/MagicMirror…ity-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                        Policy set or a policy with "unsafe-eval" enabled. This exposes users of
                      sdetweil @swvalenti
                      @swvalenti said in Black screen after 2.13 update - tentatively resolved:
                      hm…
                      try this
                      edit ~/MagicMirror/index.html
                      < head>
                      	< title>MagicMirror²< /title>
                      	< meta name="google" content="notranslate" />
                      	< meta http-equiv="Content-type" content="text/html; charset=utf-8" />
                      	< meta name="apple-mobile-web-app-capable" content="yes">
                      	< meta name="apple-mobile-web-app-status-bar-style" content="black">
                      	< meta name="format-detection" content="telephone=no">
                      	< meta name="mobile-web-app-capable" content="yes">
                      	< meta http-equiv="Content-Security-Policy" content="script-src 'self';"> < ---- insert this line without the space after <
                        Sam, that worked thank you very much!
                          sdetweil @swvalenti
                          @swvalenti i wonder why YOU see it and no one else does…
                            I have no clue on that as all my units run the same hardware and OS
                              sdetweil @swvalenti
                              @swvalenti I opened issue https://github.com/MichMich/MagicMirror/issues/2147 to track this
                                Same unit that give me earlier issue does not load darksky or pokemon…my kids monitor…lol…other mirrors run darksky with no problem.
                                Scripts loaded for: MMM-EARTH
                                loader.js:195 Load stylesheet: modules/MMM-EARTH/MMM-EARTH.css
                                loader.js:155 Styles loaded for: MMM-EARTH
                                loader.js:157 Translations loaded for: MMM-EARTH
                                loader.js:176 Load script: modules/MMM-DarkSkyForecast//MMM-DarkSkyForecast.js
                                module.js:505 Check MagicMirror version for module 'MMM-DarkSkyForecast' - Minimum version:  2.2.0 - Current version: undefined
                                module.js:528 Uncaught TypeError: Cannot read property 'replace' of undefined
                                    at cmpVersions (module.js:528)
                                    at Function.Module.register (module.js:506)
                                    at MMM-DarkSkyForecast.js:41
                                loader.js:176 Load script: modules/MMM-DailyPokemon//MMM-DailyPokemon.js
                                module.js:505 Check MagicMirror version for module 'MMM-DailyPokemon' - Minimum version:  2.1.0 - Current version: undefined
                                    at MMM-DailyPokemon.js:10
                                loader.js:176 Load script: modules/MMM-EventHorizon//MMM-EventHorizon.js
                                module.js:513 Module registered: MMM-EventHorizon
                                loader.js:148 Bootstrapping module: MMM-EventHorizon
                                loader.js:153 Scripts loaded for: MMM-EventHorizon
                                loader.js:195 Load stylesheet: modules/MMM-EventHorizon/MMM-EventHorizon.css
                                loader.js:155 Styles loaded for: MMM-EventHorizon
                                  sdetweil @swvalenti
                                  @swvalenti weird. this is 2.13 now?
                                  grep version ~/MagicMirror/package.json
                                  can’t believe the version check would fail
                                  swvalentiS 1 Reply Last reply Reply Quote 0
                                    swvalenti Project Sponsor @sdetweil
                                    @sdetweil Yes sir 2.13
                                    Last login: Fri Oct  2 17:10:33 2020
                                    pi@raspberrypi:~ $ grep version ~/MagicMirror/package.json
                                            "version": "2.13.0",
                                    pi@raspberrypi:~ $
                                      sdetweil @swvalenti
                                      @swvalenti edit the modulename.js for each
                                      comment out (leading //)
                                      requiresVersion: “2.1.0”,
                                        That gave me a black screen
                                          sdetweil @swvalenti
                                          @swvalenti
                                          //requiresVersion: “2.1.0”,
                                            Correct, only pokemon had 2.1.0 I didnt see 2.1.0 in darksky just 2.2.0
                                            • 2 / 3
