    Dropbox-Uploader: how to synchronize a folder with cron job?
    11 Posts 3 Posters 4.3k Views 3 Watching
      MajorC Project Sponsor
      I would like to synchronize a Dropbox folder with pictures to my RPI, so I can use the pictures as MM background.
      I used https://github.com/andreafabrizi/Dropbox-Uploader
      Within some time, I managed to download one file to the default folder from my dropbox to the RPI. But I have no idea how to do this as a cron job once an hour.
      Any help is highly appreciated.
      • lavolp3L Offline
        lavolp3 Module Developer @MajorC
        @MajorC why dont you regularly download the whole folder and select files from that to show as background.
        I assume with the Download Option of the script you might be able to kind of synchronise your folder.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          MajorC Project Sponsor @lavolp3
          @lavolp3 I am able to download the folder. But I would like to have a script to do that every time the pi starts up automatically. That’s where I am having the problem at the moment.
            sdetweil @MajorC
            @MajorC which part of the ‘when the pi boots’ are u having trouble with
            if you use pm2, you can start your script with pm2
            pm2 start scriptpath
            pm2 save
              MajorC Project Sponsor @sdetweil
              @sdetweil can you give me a little bit more details? I am quite new to the MM-world and have no idea where I can find what you wrote?!?
                sdetweil @MajorC
                @MajorC YOU have to enter those commands
                you said you have a script that will download files
                now, turn it into something that happens every hour, add a while loop around it…
                (I know you don’t know, so google searching will teach you a ton)
                then, once THAT works, you can use the pm2 process manager to launch it for you
                  sdetweil @MajorC
                  so, what commands would you issue to do that
                  creating a script is as simple as writing a file with this commands
                  making it executable (see chmod command)
                  and then launching it.
                    @sdetweil the script is running fine if I start it manualy by hand.
                    I need a hint how to do it the same way, the MagicMirror starts.
                      sdetweil @MajorC
                      @MajorC i wrote the two commands u need to issue
                      pm2 start scriptpath (where is your script and what is its name, = scriptpath)
                      pm2 save
                      to set it up if you use pm2 to launch MM (which my install script does for you if you used it)
                        @sdetweil thank you. It seams to work. The script was way more easy than expected.
                        May I ask, if I roboot the MM with Strg+Q, will my script run again?
                          sdetweil @MajorC
                          @MajorC yes.pm2 reruns regardless how the system was rebooted
