    MMM-NewPIR works only one time
    6 Posts 3 Posters 1.3k Views 3 Watching
    • H
      hutz10
      Re: MMM-NewPIR
      @Bugsounet it is awesome and it works, but unfortunatly for me it works only one time. The PIR is working it resets the timer, but if I try again the time simply goes to 0 and the screen goes off.
      I used the example config, not sure if there is still something needed. Some help?
      lavolp3L ? 2 Replies Last reply Reply Quote 0
      • lavolp3L
        lavolp3 Module Developer @hutz10
        @hutz10 Have included the module name in your topic header or better responsiveness
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          A Former User @hutz10
          @hutz10 more informations needed ;)
          • H
            hutz10
            Thanks for adapting, I forgot the module name.
            So…the time that count how much time is left until the screen turns off is displayed and counting back. It works one, like I wave in front of the PIR sensor and the counter resets to start of 2 minutes. If I wave again nothing happens, should the counter not reset again?
            If the screen is black after the first time it worked, the screen remains black.
            Thank you for the help in advance.
              A Former User
              Hi, I think the delay rest potentiometer is to high (it can make 0.2 s to 3 min to the rest postion)
              you can setup you PIR sensor by reading this part:
              How do some simply test and setup sensibility/delay of your PIR sensor ?
              • H
                hutz10
                @Bugsounet it worked, I did not use the test, but made the adjustements a few times to the PIR sensor.
                Thanks a lot.
