    Starter problem
    73 Posts 8 Posters 92.1k Views 5 Watching
    • K
      kurt
      This post is deleted!
      K 1 Reply Last reply
      • Y
        yawns Moderator
        Hi Kurt,
        before you run npm start you need to change into the right directory. Default would be
        cd MagicMirror
        npm install
        npm start
        The npm install command only needs to be run first time after you downloaded the MagicMirror package. If you have already done that you can skip this step.
        Reply Quote 2
        • K
          kurt @yawns
          @yawns
          Thank you for the immediate answer.
          This is what happend
          npm ERR! Linux 4.4.38-v7+
          npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
          npm ERR! node v6.9.4
          npm ERR! npm v3.10.10
          npm ERR! code ELIFECYCLE
          npm ERR! magicmirror@2.1.0 start: electron js/electron.js
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.1.0 start script ‘electron js/electron.js’.
          npm ERR! If you do, this is most likely a problem with the magicmirror package,
          npm ERR! not with npm itself.
          npm ERR! electron js/electron.js
          npm ERR! npm bugs magicmirror
          npm ERR! Or if that isn’t available, you can get their info via:
          npm ERR! npm owner ls magicmirror
          npm ERR! /home/pi/MagicMirror/npm-debug.log
          * 0 info it worked if it ends with ok
          1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
          2 info using npm@3.10.10
          3 info using node@v6.9.4
          5 info lifecycle magicmirror@2.1.0~prestart: magicmirror@2.1.0
          6 silly lifecycle magicmirror@2.1.0~prestart: no script for prestart, continuing
          7 info lifecycle magicmirror@2.1.0~start: magicmirror@2.1.0
          8 verbose lifecycle magicmirror@2.1.0~start: unsafe-perm in lifecycle true
          9 verbose lifecycle magicmirror@2.1.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
          10 verbose lifecycle magicmirror@2.1.0~start: CWD: /home/pi/MagicMirror
          11 silly lifecycle magicmirror@2.1.0~start: Args: [ '-c', 'electron js/electron.js' ]
          12 silly lifecycle magicmirror@2.1.0~start: Returned: code: 1  signal: null
          13 info lifecycle magicmirror@2.1.0~start: Failed to exec start script
          14 verbose stack Error: magicmirror@2.1.0 start: `electron js/electron.js`
          14 verbose stack Exit status 1
          14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
          14 verbose stack     at emitTwo (events.js:106:13)
          14 verbose stack     at EventEmitter.emit (events.js:191:7)
          14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
          14 verbose stack     at ChildProcess.emit (events.js:191:7)
          14 verbose stack     at maybeClose (internal/child_process.js:877:16)
          14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
          15 verbose pkgid magicmirror@2.1.0
          16 verbose cwd /home/pi/MagicMirror
          17 error Linux 4.4.38-v7+
          18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
          19 error node v6.9.4
          20 error npm  v3.10.10
          21 error code ELIFECYCLE
          22 error magicmirror@2.1.0 start: `electron js/electron.js`
          22 error Exit status 1
          23 error Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
          23 error Make sure you have the latest version of node.js and npm installed.
          23 error If you do, this is most likely a problem with the magicmirror package,
          23 error not with npm itself.
          23 error Tell the author that this fails on your system:
          23 error     electron js/electron.js
          23 error You can get information on how to open an issue for this project with:
          23 error     npm bugs magicmirror
          23 error Or if that isn't available, you can get their info via:
          23 error     npm owner ls magicmirror
          23 error There is likely additional logging output above.
          24 verbose exit [ 1, true ]
          * list item
          • Y
            yawns Moderator
            Are you working on your raspberry? Or are you connected via ssh?
            If you are connected via ssh you need to run DISPLAY=:0 npm start instead to tell the raspberry to use the display connected to the raspberry instead of the not working ssh connection
            • K
              kurt
              I’m working via ssh, I can see the starter Logo, but thats’it
              pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
              magicmirror@2.1.0 start /home/pi/MagicMirror
              Starting MagicMirror: v2.1.0
              Loading config …
              WARNING! Could not find config file. Please create one. Starting with default configuration.
              Loading module helpers …
              Initializing new module helper …
              No helper found for module: helloworld.
              All module helpers loaded.
              Starting server op port 8080 …
              Server started …
              Sockets connected & modules started …
              Launching application.
              strawberry 3.141S 1 Reply Last reply
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @kurt
                @kurt WARNING! Could not find config file. Please create one. Starting with default configuration.
                are you sure you renamed the file correctly?
                cd ~/MagicMirror/config
                ls
                if not then copy the sample again
                cp config.js.sample config.js
                • K
                  kurt
                  Thanks a lot once more!
                  There was a point behind my “config.js” !
                  I deletet that point and tryed again with
                  this is what happened:
                  pi@raspberrypi:~ $ DISPLAY=:0 npm start
                  npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                  npm ERR! path /home/pi/package.json
                  npm ERR! code ENOENT
                  npm ERR! errno -2
                  npm ERR! syscall open
                  npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                  npm ERR! enoent This is most likely not a problem with npm itself
                  npm ERR! enoent and is related to npm not being able to find a file.
                  npm ERR! enoent
                  npm ERR!     /home/pi/npm-debug.log
                  • strawberry 3.141S
                    @kurt you are in the wrong directory again cd ~/MagicMirror
                    • K
                      kurt
                      I’m in the /home/pi/MagicMirror/config - file
                      Is this the wrong one?
                      and what does it mean “cd ~/Magic Mirror”
                      strawberry 3.141S T 2 Replies Last reply
                      • strawberry 3.141S
                        @kurt
                        your logs show what you are not in /home/pi/MagicMirror/config with the terminal console
                        if you type in that command you will be in the correct directory cd means change directory
                        after that do DISPLAY=:0 npm start
                        • T
                          tosti007 Module Developer @kurt
                          @kurt if you are on /home/pi/MagicMirror/config then you have to move one folder up. You can do this by typing cd ..
                          If there is anything don’t hesitate to contact me!
                          ProfileSwitcher, TouchNotifications
                          • K
                            kurt
                            WoW strawberry3.141 you made my day!
                            I’m looking hot, so they say :)
                            is it so that I have to typ in first the : cd ~/MagicMirror to get into the right directory, and is this the same I can see in my FTP Client?
                            Thanks a lot for your help, I’m just happy and thankfull.
                            Without you guys it would be impossible to get into that projekts so quick.
                            So I guess this the moment for the beer! Cheers and thank you again.
                            Now after some break I will start with the adaptions…
                            Do you have any hints for the best way to avoid problems with this adaption?
                            What a day
                            Greetings kurt
                            • strawberry 3.141S
                              @kurt it’s past 4 o’clock so no reason to drink no beer :D cd ~ ist the same as cd /home/pi/
                              i dont know which directory you are looking at in the client but i guess its the same.
                              what adaptions do you mean? styling, more modules, …?
                              T 1 Reply Last reply
                              • T
                                tosti007 Module Developer @strawberry 3.141
                                @strawberry-3.141 I think he means changing his config file and maybe adding in some more modules. So time to get your app up and running :P
                                @Kurt I would start by first using the default modules (like calendar, time, etc). If you aren’t sure you changed it correctly then you can always just change one thing at the time and make sure it still works.
                                • K
                                  kurt
                                  Yes, thats what i’ll do. Step by step. just change the rss feed or the compliments (does it matter how many of them you put into the modul?) weatherforcast…
                                  Also Thanks to @tosti007
                                  I feel comfortable in this forum!
                                  @strawberry-3-141 by the way you are working on an hot app?
                                  • strawberry 3.141S
                                    @kurt my bachelor thesis is about a mobile app to configure the mirror
                                    cause you are from vienna, you might want to checkout my transport module for vienna https://github.com/fewieden/MMM-WienerLinien
                                    • T
                                      @kurt no it doesn’t matter how many compliments you put in. And good to hear that you feel comfortable :) and you’re welcome!
                                      • K
                                        kurt
                                        @strawberry-3-141 Hey I allready visit it today! while drifting thru the forum. suprise! I lived in Barawitzkagasse for quite a long time. funny small world, isn’it?
                                        Is the modul allready finished or are still in it?
                                        • strawberry 3.141S
                                          @kurt it should be finished
                                          K 2 Replies Last reply
                                          • K
                                            kurt @strawberry 3.141
                                            @strawberry-3.141
                                            fine , is on my list :)
                                            • 1 / 4
