    Auto Black Screen (save mode of monitor?) after a few minutes
    11 Posts 2 Posters 5.2k Views 2 Watching
    • PeterPangP Offline
      PeterPang
      Auto Black Screen (save mode of monitor?) after a few minutes , already change to
      #xserver-command=X -s 0 -dpms ,
      but still BLACK again & again
      [Seat:*]
      #type=local
      #pam-service=lightdm
      #pam-autologin-service=lightdm-autologin
      #pam-greeter-service=lightdm-greeter
      #xserver-backend=
      #xmir-command=Xmir
      #xserver-config=
      #xserver-layout=
      #xserver-allow-tcp=false
      • wishmaster270W Offline
        wishmaster270 Module Developer @PeterPang
        @peterpang Hi,
        sdetweil wrote a script which can be used to disable the screensaver. You may look at GitHub.
        PeterPangP 1 Reply Last reply Reply Quote 0
          PeterPang @wishmaster270
          @wishmaster270 said in Auto Black Screen (save mode of monitor?) after a few minutes:
          Firstly , thanks for your reply soon , but thaere’s not about screensaver , its seem a monitor auto sleep/save mode , just black screen no screensaver.
            @peterpang Hi, Raspberry OS has an built in feature called screen blanking. Maybe that is the problem. You can disable it by adding a “consoleblank=0” to the line in “/boot/cmdline.txt” and reboot the pi.
            But i did not have this problem in my recent installations.
            PeterPangP 2 Replies Last reply Reply Quote 0
              @wishmaster270
              Thanks again , try later ^^
                @wishmaster270
                I open the File Manager , then open the " boot " folder , then click into the " cmdline.txt , see there’s a text :
                " console=serial0,115200 console=tty1 root=PARTUUID=7e583fb6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles "
                add “consoleblank=0” here ? add in the first place or where else ?
                sorry , I’m just a very very Beginner , the first time in writing progamme
                  @peterpang Hi, that’s the right file. Simply add it at the end before the closing "
                    @wishmaster270
                    I try to add " consoleblank=0 " to the cmdline.txt ,
                    but
                    failed to save the document Permission denied
                    What I can do ?=.="
                    Please help
                      PeterPang
                      additional scripts that may be useful
                      the install has two sections of additional support I have provided those separately too, in case u need to run one separately, or changed your mind after install
                      turn off screen saver and setup pm2 to autostart MM on boot…
                      screensaveroff.sh, cut/paste this line into the terminal window on your device
                      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)”
                      fixuppm2.sh, cut/paste this line into the terminal window on your device
                      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
                        @peterpang Hi, you need to run the editor with root privileges “sudo vi …” or “sudo nano …”
