    Integrating an npm module that uses import
    13 Posts 4 Posters 5.3k Views 4 Watching
    • lavolp3L Offline
      lavolp3 Module Developer
      HI all,
      I am trying to write a module around the npm module picnic-api that uses the import function instead of require
      import axios from "axios";
      This does not work within the Magicmirror environment, I get an error message when I start the mirror.
      [13.02.2021 07:21.43.938] [ERROR] /home/pi/MagicMirror/modules/MMM-Picnic/node_modules/picnic-api/index.js:1
      SyntaxError: Cannot use import statement outside a module
      Does anyone have a solution for me?
      Is there a way to use it or do I need to rewrite the npm module?
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @lavolp3
        @lavolp3 which version of nodejs are you running? import is a feature of es6 modules. You can try to enable it like this https://stackoverflow.com/a/45854500
        lavolp3L 1 Reply Last reply Reply Quote 1
        • lavolp3L Offline
          lavolp3 Module Developer @strawberry 3.141
          @strawberry-3-141 said in Integrating an npm module that uses import:
          Thanks for the tip. Upgraded to node.js 14.15 but did not work yet.
          Seeing "type": "module in my package.json also did not help.
          I will have to have a closer look at the link
          S karsten13K 2 Replies Last reply Reply Quote 0
            sdetweil @lavolp3
            @lavolp3 yiu can also use
            const ax = require('axios')
            in node_helper.js
            after npm install axios
            • lavolp3L Offline
              lavolp3 Module Developer @sdetweil
              @sdetweil that’s not sufficient. There are two more modules imported by the picnic-api module. I could require them all in node_helper but that looks too of much a workaround for me. There should be another way.
                sdetweil @lavolp3
                @lavolp3 sometimes u get to do things that arent perfect. but get to move on.
                • karsten13K Offline
                  karsten13 @lavolp3
                  @lavolp3
                  • rename node_helper.js to node_helper.mjs
                  worked in my test (did not do anything with the imported axios, but mm starts).
                    sdetweil @karsten13
                    @karsten13 was node_helper loaded? i doubt it. its optional. so this doesnt help
                      karsten13 @sdetweil
                      @sdetweil no :crying_face:
                      may using esm library is one approach as described e.g. here https://blog.logrocket.com/how-to-use-ecmascript-modules-with-node-js/
                        sdetweil @karsten13
                        @karsten13 in node… but we have a custom environment, that is not node pure…
                          sdetweil
                          i helped someone with a similar problem but the n module was wrutten in typescript and down compiled to js
                          https://github.com/Mitica/public-holidays-js
                          • lavolp3L Offline
                            @sdetweil @strawberry-3-141
                            I can’t get it working.
                            node 14.15 installed.
                            When I require the “picnic-api” npm module the usual way I get the error message inside the "picnic-api module.
                            When I do the import like described in the readme the error originates in my node_helper.js
                                    import PicnicClient, { CountryCodes, ImageSizes, HttpMethods } from "picnic-api";
                            I’m lost. At least the environment of the picnic-api module should be a “pure node” environment, why does the import not work at least in that module?
                            Changing the index.js inside picnic-api to an .mjs does not help.
                            Any more ideas?
                              sdetweil @lavolp3
                              @lavolp3 i do not know. i consider myself a node rookie, and a typescript noobie.
                              because i am away from my systems i am unable to try different solutions… at least a few more weeks
                              if u try w
                              node serverOnly
                              does it make a difference?
                              there the node engine is running the code, vs the engine thru electron…
