    MMM-OpenWeatherMapForecast Doesn't display imperial units
    21 Posts 6 Posters 11.0k Views 6 Watching
    • R
      rslohs
      Hello,
      Working on OpenWeatherMapForecast and so far have really liked it. One issue, for predicted precipitation I cannot get imperial units to show. I’ve tried changing it within config.js as well as the config file in the module as well. Any suggestions?
      module: “MMM-OpenWeatherMapForecast”,
      header: “Weather”,
      position: “bottom_right”,
      classes: “default everyone”,
      disabled: false,
      apikey: “KEY”,
      latitude: “444444”,
      longitude: “-4444444”,
      iconset: “4c”,
      concise: false,
      forecastLayout: “table”,
      units: “imperial”,
      S Mykle1M 2 Replies Last reply Reply Quote 0
        sdetweil @rslohs
        @rslohs the doc says the module config options is units
        from
        https://github.com/jharttech/MMM-weatherforecast
        • R
          rslohs @sdetweil
          @sdetweil I’m not quite sure what you’re saying. The ‘Units:“imperial”,’ is incorrect in the code I shared? What should I try differently?
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @rslohs
            @rslohs
            Just a thought: At the top of your config.js file, what are your config units set to?
            Example:
            var config = {
                address: "0.0.0.0",
                port: 8080,
                ipWhitelist: [], // Set [] to allow all IP addresses
                language: "en",
                timeFormat: 12,
                units: "imperial",
            • R
              rslohs @Mykle1
              @mykle1 thanks for the suggestion, but that is set to imperial as well.
                sdetweil @rslohs
                @rslohs its not “Units”, its “units”
                this system is case sensitive, every letter matters
                • R
                  rslohs @sdetweil
                  @sdetweil that’s what I’m using in the config file.
                  module: "MMM-OpenWeatherMapForecast",
                  header: "Schoolcraft, MI Weather",
                  classes: "default everyone",
                  disabled: false,
                  apikey: "aaaaaaaa",
                  latitude: "aaaaaaa",
                  longitude: "aaaaaa",
                  iconset: "4c",
                  concise: false,
                  forecastLayout: "table",
                  units: "imperial",
                    scumbelly @rslohs
                    @rslohs
                    A little late to weigh in but I can verify that imperial setting does not affect the Pop amount. It remains metric. Everything else is imperial.
                    Sorry.
                      scumbelly @rslohs
                      @rslohs
                      Guess what? I was trying to troubleshoot an issue in this module re: scale and noticed the .js file has changed wind calculations and the following…
                      units: {
                      accumulationRain: {
                      imperial: “mm”,
                      metric: “mm”,
                      “”: “mm”
                      accumulationSnow: {
                      imperial: “mm”,
                      metric: “mm”,
                      “”: “mm”
                      windSpeed: {
                      imperial: “mph”,
                      metric: “m/s”,
                      “”: “m/s”
                      So it looks like imperial might work for you now. I’m not going to test because I need the older .js which I had to modify to get some calculations in kph to work .
                      Cheers
                      • J
                        JohnGalt
                        My instance of this module also displays rainfall in “mm”, even though I have set units = “imperial” for the MagicMirror system as a whole and also in the module configuration.
                        I see that the Open Weather site has a page specifying “API response parameters with available units of measurement” (https://openweathermap.org/weather-data). There one finds a parameter table specifying Parameter and Description - as well as columns for “Standard”, “Metric” and “Imperial”.
                        The interesting thing is this: the table specifies temperatures correctly (“Kelvin”, “Celsius”, “Fahrenheit”) but for rain it calls out “mm”, “mm”, “mm” - or other variants for different fields, e.g.: “mm/hr” and “mm/hour”.
                        As such, I am inclined to just give up and accept the module’s behavior as a quirk of how Open Weather parses what it is getting from the NWS - but I thought i would see if anyone has a better idea.
                        kayakbabeK 1 Reply Last reply Reply Quote 0
                        • kayakbabeK
                          kayakbabe @JohnGalt
                          @JohnGalt have you tried MMM-OpenWeatherForecast instead? It seems to work better for me adn it uses the OpenWeather Map api too.
                          J 3 Replies Last reply Reply Quote 0
                          • J
                            JohnGalt @kayakbabe
                            @kayakbabe - Thanks for the tip. Can you tell me which one you use? A quick web search shows several modules with the same name. These two look like top contenders:
                            https://github.com/jclarke0000/MMM-OpenWeatherForecast
                            https://github.com/themaxgoldman/MMM-OpenWeatherForecast
                            • J
                              JohnGalt @kayakbabe
                              @kayakbabe PS: another issue with MMM-OpenWeatherMapForecast is that it doesn’t respect the “disabled: true” configuration. I had seen this before and ignored it since the module is active, but when I went in to disable it in preparation for trying one of the others, I am reminded that I cannot just disable it. I CAN put " /* and */ " around the whole thing of course, but that is just clunky, and more importantly may signal more serious coding issues.
                              • J
                                JohnGalt @kayakbabe
                                @kayakbabe FWIW, i installed the jclarke0000 module, and so far it looks pretty good - thanks again!
                                  sdetweil @JohnGalt
                                  @JohnGalt disabled is an mm config option, not a module option. it goes not to the module line, outside the module config:{} section
                                  here is the doc on all the mm config options for a module.
                                  these are separate from the module config options inside the config:{} section
                                  https://docs.magicmirror.builders/modules/configuration.html#example
                                  • J
                                    JohnGalt @sdetweil
                                    @sdetweil - Thanks Sam - I guess I was and am confused.
                                    Below are two code snips showing the subject module and one other. Both are designated to be disabled with the “disabled: true” instruction outside the config section. The top one still operates, while the bottom one [and every other module I have edited this way] is disabled. So, it’s not a big deal and I will keep an eye out for how I do things. Thanks again.
                                    {module: "MMM-OpenWeatherMapForecast", // https://github.com/MarcLandis/MMM-OpenWeatherMapForecast NOTE: See also https://github.com/sdetweil/MMM-OpenWeatherMapForecast
                                      disabled: true,
                                      header: "", // "Weather"
                                      disabled: false,
                                        apikey: "xxxxxxxxxxxxx",
                                    {module: "MMM-Temperature", // https://github.com/Tom-Hirschberger/MMM-Temperature
                                      disabled: true,
                                      header: "Office Temp + Humidity",
                                      position: "top_right", // bottom_right
                                       sensors: [
                                      sdetweil @JohnGalt
                                      @JohnGalt I need to see the rest in between
                                      top one has disabled twice, true and false
                                      • J
                                        JohnGalt @sdetweil
                                        @sdetweil - Ah crap, having both disabled: true AND disabled: false would do it!! :) I’m sure the system would execute the last command. Thanks for putting a second set of eyes on it.
                                          sdetweil @JohnGalt
                                          @JohnGalt yes, last occurrence wins
                                          • kayakbabeK
                                            kayakbabe @JohnGalt
                                            @JohnGalt
                                            I see you got your module choice working.
                                            jclarke0000 is the one I’m using.
