    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 687.7k Views 57 Watching
    • BKeyportB Offline
      @sdetweil the problem is that I can’t find the right CSS class to apply it to.
        sdetweil @BKeyport
        @BKeyport did u use the dev console to examine the content? click on the element u mean to adjust?
        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1679584458559
        may not be a class, so you would have to select more … just have to be careful if the table is in a div, in a div… then its ‘size’ and position are relative to the parent (div) …
        .modulename table {
        position: relative
        this is my goto for figuring out the selector ( the thing before the { )
        https://www.w3schools.com/cssref/css_selectors.php
        look at the css for the form in MMM-Config
        https://github.com/sdetweil/MMM-Config/blob/main/webform.css
        selector doesn’t have to start with a class…
        note in the cheat sheet its ALWAYS selects ALL elements that match
        • BKeyportB Offline
          BKeyport Module Developer @BKeyport
          @BerkSmash1984 FYI, there’s more ways to make things easier to read - fade the background - or add a background to the modules themselves.
          Here’s how to add a background to the modules:
          the .5 is the opacity in this case, I’ve got it set to 50% visible.
          .module {
            background-color: rgba(0,0,0,.5);
          • BKeyportB Offline
            @sdetweil found it. Missing a * on the opening CSS when I did it…
            .MMM-OpenWeatherForecast * {
            	box-sizing: border-box;
            	margin-left: auto;
            	margin-right: auto;
            does it, for anyone else that runs across this.
            • BKeyportB Offline
              @BerkSmash1984 I’ve also found, in the documentation for MMM-Wallpaper, a “filter” option - If you don’t want to put a background on the modules, you can use this to improve readability.
              • BerkSmash1984B Offline
                BerkSmash1984 @BKeyport
                @BKeyport
                Thanks for the responses! The filter for MMM-Wallpaper worked perfectly (I actually had values specified already but must have forget when I first setup the module). I dropped the grayscale and brightness down to 0.2 and that seems to be the sweet spot for ensure the default text color is legible, regardless of the background.
                Thanks again for your help, I really appreciate it!
                • C Offline
                  chris1971
                  I started a new setup of and the module was working. After installation of other modules (e.g. google maps) the module isn’t working anymore. I tried to delete and reinstall and got following info:
                  Pi@raspberrypi:~/MagicMirror/modules/MMM-OpenWeatherForecast $ npm install
                  npm WARN old lockfile
                  npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                  npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                  npm WARN old lockfile This is a one-time fix-up, please be patient…
                  added 4 packages, and audited 391 packages in 57s
                  1 package is looking for funding
                  run npm fund for details
                  46 vulnerabilities (3 low, 15 moderate, 23 high, 5 critical)
                  To address all issues, run:
                  npm audit fix
                  Run npm audit for details.
                  Any recommendations?
                    sdetweil @chris1971
                    @chris1971 sadly some modules interfere with others. haven’t seen this combo as a problem before.
                    the messages just mean the module hasn’t been updated in a while…
                    i’d erase the package-lock.json
                    remove the node_modules folder
                    and npm install again
                    ignore the audit message nothing we can do about it.
                    or use the --no-audit parm on the npm install
                    • C Offline
                      chris1971
                      thanks for the fast reply - do you have some more detailled steps from me as a “newbie”…
                        sdetweil @chris1971
                        @chris1971 no… do exacty what I said… and try again …
                        look in the logs, open the developers window (crtrl-shift-i on the mm screen keyboard), select the console tab and look for red error messages…
                        • C Offline
                          chris1971
                          o.k. deleted the package-lock.json and node_modules folder. No change…
                          In which logs do I have to look?
                            sdetweil @chris1971
                            @chris1971 logs, where u start MM and in the developers window as described in last post
                            • C Offline
                              chris1971
                              After some hours of installation I thought I was fine - all modules worked (but only once). komplett.JPG
                              When I restarted the mirror the weather module was not loading anymore…
                              I got following script after npm start:
                              magicmirror@2.22.0 start
                              DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                              [31.03.2023 14:13.30.165] [LOG] Starting MagicMirror: v2.22.0
                              [31.03.2023 14:13.30.177] [LOG] Loading config …
                              [31.03.2023 14:13.30.193] [LOG] Loading module helpers …
                              [31.03.2023 14:13.30.197] [LOG] No helper found for module: alert.
                              [31.03.2023 14:13.30.247] [LOG] Initializing new module helper …
                              [31.03.2023 14:13.30.249] [LOG] Module helper loaded: updatenotification
                              [31.03.2023 14:13.30.251] [LOG] No helper found for module: clock.
                              [31.03.2023 14:13.30.480] [LOG] Initializing new module helper …
                              [31.03.2023 14:13.30.481] [LOG] Module helper loaded: MMM-OpenWeatherForecast
                              [31.03.2023 14:13.31.255] [LOG] Initializing new module helper …
                              [31.03.2023 14:13.31.258] [LOG] Module helper loaded: calendar
                              [31.03.2023 14:13.31.261] [LOG] No helper found for module: MMM-TextClock.
                              [31.03.2023 14:13.31.344] [LOG] Initializing new module helper …
                              [31.03.2023 14:13.31.346] [LOG] Module helper loaded: newsfeed
                              [31.03.2023 14:13.31.348] [LOG] No helper found for module: MMM-RAIN-MAP.
                              [31.03.2023 14:13.31.358] [LOG] Initializing new module helper …
                              [31.03.2023 14:13.31.359] [LOG] Module helper loaded: MMM-GoogleMapsTraffic
                              [31.03.2023 14:13.31.361] [LOG] All module helpers loaded.
                              [31.03.2023 14:13.31.869] [LOG] Starting server on port 8080 …
                              [31.03.2023 14:13.31.892] [WARN] You’re using a full whitelist configuration to allow for all IPs
                              [31.03.2023 14:13.31.940] [ERROR] Whoops! There was an uncaught exception…
                              [31.03.2023 14:13.31.961] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                              at Server.setupListenHandle [as _listen2] (node:net:1432:16)
                              at listenInCluster (node:net:1480:12)
                              at doListen (node:net:1629:7)
                              at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
                              code: ‘EADDRINUSE’,
                              errno: -98,
                              syscall: ‘listen’,
                              address: ‘0.0.0.0’,
                              port: 8080
                              [31.03.2023 14:13.31.962] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                              [31.03.2023 14:13.31.963] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              [31.03.2023 14:13.33.284] [LOG] Launching application.
                              MESA-LOADER: failed to retrieve device information
                              …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[1907:0331/141336.327833:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                              …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[1907:0331/141337.916643:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                              …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[1907:0331/141339.068693:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                              [31.03.2023 14:13.55.813] [LOG] Shutting down server…
                              [31.03.2023 14:13.55.823] [LOG] Stopping module helper: updatenotification
                              [31.03.2023 14:13.55.825] [LOG] Stopping module helper: MMM-OpenWeatherForecast
                              [31.03.2023 14:13.55.836] [LOG] Stopping module helper: calendar
                              [31.03.2023 14:13.55.838] [LOG] Stopping module helper: newsfeed
                              [31.03.2023 14:13.55.839] [LOG] Stopping module helper: MMM-GoogleMapsTraffic
                              Any advice? Thanks again…
                                sdetweil @chris1971
                                @chris1971 that means u have another instance of MagicMirror running already
                                • C Offline
                                  chris1971 @sdetweil
                                  @sdetweil what does that mean? How can I fix it?
                                    sdetweil @chris1971
                                    @chris1971 that means something started MM, and you are trying to start it again…
                                    you cannot have two copies running at the same time on the same port
                                    do this
                                    pm2 status
                                    on one of my machines it looks like this
                                     │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                     │ 0  │ MagicMirror        │ fork     │ 20   │ online    │ 0%       │ 2.4mb    │
                                    is there only 1 app defined for pm2 to manage?
                                    • C Offline
                                      chris1971 @sdetweil
                                      pi@raspberrypi:~/MagicMirror $ pm2 status
                                      │ 0 │ MagicMirror │ fork │ 0 │ online │ 0% │ 2.4mb │
                                      looks like this…
                                      I installed your scrips and agreed both times (y/n) when I was asked to remove screensaver and start pm.
                                        sdetweil @chris1971
                                        @chris1971 ok, so when u need to change something you do
                                        pm2 stop 0 (or pm2 stop MagicMirror), (or pm2 stop all)
                                        make your change and then
                                        pm2 start 0, or MagicMirror, or all
                                        • C Offline
                                          chris1971 @sdetweil
                                          @sdetweil said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                          pm2 stop all
                                          have stopped with pm2 stop all
                                          pi@raspberrypi:~/MagicMirror $ pm2 stop all
                                          [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                                          [PM2] MagicMirror ✓
                                          │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                                          │ 0 │ MagicMirror │ default │ 2.22.0 │ fork │ 0 │ 0 │ 0 │ stopped │ 0% │ 0b │ pi │ disabled │
                                          the started with pm2 start all
                                          pi@raspberrypi:~/MagicMirror $ pm2 start all
                                          [PM2] Applying action restartProcessId on app [all](ids: [ 0 ])
                                          [PM2] MagicMirror ✓
                                          [PM2] Process successfully started
                                          │ 0 │ MagicMirror │ default │ 2.22.0 │ fork │ 2414 │ 0s │ 0 │ online │ 0% │ 2.5mb │ pi │ disabled │
                                          But no changes…
                                          checked the status and see only on 8080
                                          pi@raspberrypi:~ $ sudo netstat -lnptu
                                          Active Internet connections (only servers)
                                          Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
                                          tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 565/sshd: /usr/sbin
                                          tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 519/cupsd
                                          tcp 0 0 0.0.0.0:8080 0.0.0.0: LISTEN 1206/electron.js*
                                          tcp6 0 0 ::1:3350 :::* LISTEN 539/xrdp-sesman
                                          tcp6 0 0 :::22 :::* LISTEN 565/sshd: /usr/sbin
                                          tcp6 0 0 ::1:631 :::* LISTEN 519/cupsd
                                          tcp6 0 0 :::3389 :::* LISTEN 585/xrdp
                                          udp 0 0 0.0.0.0:68 0.0.0.0:* 526/dhcpcd
                                          udp 0 0 0.0.0.0:631 0.0.0.0:* 612/cups-browsed
                                          udp 0 0 0.0.0.0:5353 0.0.0.0:* 376/avahi-daemon: r
                                          udp 0 0 0.0.0.0:58721 0.0.0.0:* 376/avahi-daemon: r
                                          udp6 0 0 :::546 :::* 526/dhcpcd
                                          udp6 0 0 :::41014 :::* 376/avahi-daemon: r
                                          udp6 0 0 :::5353 :::* 376/avahi-daemon: r
                                            sdetweil @chris1971
                                            @chris1971 correct, and it should be running correctly now
                                            i never use pm2 when I am changing config
                                            pm2 stop all
                                            cd ~/MagicMirror
                                            npm start
                                            (ctrl-m if on same screen, to minimize)
                                            look at messages
                                            ctrl-c to stop
                                            make changes, rinse and repeat til happy
                                            then pm2 start all
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 10 / 13
