    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 687.7k Views 57 Watching
      j.e.f.f Project Sponsor Module Developer
      Ever since Apple bought Dark Sky and announced that that would stop allowing free access to their API (Thanks Apple!), I’ve been meaning to write a replacement for MMM-DarkSky Forecast.
      Well I finally got off my lazy ass and wrote it. Link to code here:
      https://github.com/jclarke0000/MMM-OpenWeatherForecast
      If you’re already using MMM-DarkSkyForecast, this will look familiar to you. In fact I based MMM-OpenWeatherForecast on MMM-DarkSkyForecast’s code.
      But! Many improvements have been included. With this rewrite I have made it possible to display every bit of weather data provided in OpenWeather’s One Call API. Be sure to fully read the README.md file to see how you can configure this module exactly to your liking.
      Installation:
      1. Navigate into your MagicMirror modules folder and execute
        git clone https://github.com/jclarke0000/MMM-OpenWeatherForecast.git.
      2. Enter the new MMM-OpenWeatherForecast directory and execute npm install.
      NOTE
      If you’re using a pre-release version, doing git pull won’t be enough to install the latest code. I replaced the deprecated request library with axios. So make sure you run npm install to get the latest dependencies. Optionally you may run npm prune to remove installation for request.
      Configuration:
      At a minimum you need to supply the following required configuration parameters:
      • apikey
      • latitude
      • longitude
      apikey needs to be specified as a String, while latitude and longitude can be specified as either a String or a Number. Both work fine.
      e.g.,
          module: "MMM-OpenWeatherForecast",
          header: "Forecast",
            apikey: "a1b2c3d4e5f6g7h8j9k0", //only string here
            latitude: 51.490230,            //number works here
            longitude: "-0.258810"          //so does a string
      You need to create a free account with OpenWeather in order to get an API key:
      https://home.openweathermap.org/users/sign_up.
      Free tier is fine – this module will not make anywhere near 60 calls per minute / 1,000,000 requests per month.
      Find out your latitude and longitude here:
      https://www.latlong.net/.
      Refer to the README for all of the other configuration options.
      NOTE
      This module uses the Nunjucks templating system and therefore requires MagicMirror version 2.2.0 or later.
      lavolp3L BKeyportB cowboysdudeC ebolisaE D 5 Replies Last reply Reply Quote 10
        jenga
        I am trying to adjust the hours under the hourly forecast to reflect a different time zone. I was reviewing the code and I see UTC references. How can I adjust this to CST?
        nitewing76N J 2 Replies Last reply Reply Quote 1
        • nitewing76N Offline
          nitewing76 @jenga
          @jenga Maybe you are having the same issue I am with incorrect current/hourly time & temperature conversion?
          • lavolp3L Offline
            lavolp3 Module Developer @j.e.f.f
            @j-e-f-f That looks REALLY tasty! Thank you for the great work!
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            swvalentiS 1 Reply Last reply Reply Quote 1
            • swvalentiS Offline
              swvalenti Project Sponsor @lavolp3
              @j-e-f-f Am I missing a way to turn off current weather alerts? Once a weather alert like high wind or snow it drops my tables down and throws other modules off.
              • BKeyportB Offline
                BKeyport Module Developer @j.e.f.f
                @j-e-f-f As always, great work. 😉
                • cowboysdudeC Offline
                  cowboysdude Module Developer @j.e.f.f
                  As of Saturday, May 1, 2021, the free Yahoo Weather API will be retired.
                  So as more time goes by the free weather api’s are dropping like flies…
                    jms3700 Project Sponsor
                    Thanks For this great job! 👍
                      MajorC Project Sponsor @cowboysdude
                      @cowboysdude it would be nice if someone with knowledge could have a look at the API of www.yr.no
                      The forecast is very good and they are providing free world wide data.
                      J cowboysdudeC 2 Replies Last reply Reply Quote 0
                      • ebolisaE Offline
                        ebolisa @j.e.f.f
                        @j-e-f-f Thanks for sharing.
                        Does it work on Pi Zero? In my case it doesn’t load. I just see FORCAST and then “Loading…” forever :astonished_face:
                        Using defaults, no changes made.
                          j.e.f.f Project Sponsor Module Developer @jenga
                          @jenga said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                          The API returns UTC time for everything as well as a timezone offset for the long/lat you provide. The module translates UTC into local time using these two bits of information. Say you’re living in London, but you configure this module with Long/Lat for New York, then the time you’ll see is local to New York. I can’t request a different timezone in the API.
                          UPDATE
                          So quick to jump to conclusions am I… this was a bug in my code. OpenWeather documentation says the hourly time forecasts are provided in UTC, and elsewhere in the API response a timezone offset is provided. I took this to mean that in order to see local time for the forecast I needed to add the offset to the hourly time. As it turns out this is not the case. OpenWeather does not explicitly say this anywhere in the docs that I could find, but the JSON response is already translated to whatever local timezone the request was made from. So if I live in London and I make a request for weather in Chicago I’ll see the hourly forecasts in local London time, not in local Chicago time.
                          I’ve changed the code so that I no longer add the offset to hourly forecast times. Do a git pull in the MMM-OpenWeatherForecast directory, then restart MM. Should be fixed up.
                            j.e.f.f Project Sponsor Module Developer @swvalenti
                            @swvalenti said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                            If you set summary: false this will stop weather alerts from displaying. The OpenWeather API doesn’t return a detailed summary (usually just a single word like “Cloudy.” ) so I didn’t think it was necessary to split these two out into separate configs.
                            If you wanted to keep the summary, but not show weather alerts, you can set summary: true in your config and then prevent display of alerts in your custom CSS as follows:
                            .MMM-OpenWeatherForecast .weather-alert {
                              display: none;
                              j.e.f.f Project Sponsor Module Developer @ebolisa
                              @ebolisa said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                              I haven’t tested this on a pi zero (I don’t have one to test on). Do you see any errors either in pm2 logs mm or in Electron if you run Magic Mirror with npm start dev?
                              Also, just double-checking: did you remember to run npm install in the MMM-OpenWeatherForecast` directory to ensure all of the dependencies were installed? Forgetting to do this would be another reason you might see it stuck on “Loading…”
                              ebolisaE 1 Reply Last reply Reply Quote 0
                                j.e.f.f Project Sponsor Module Developer @MajorC
                                @majorc said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                This looks promising, and seemingly doesn’t require an API key. I’ll keep an eye on this as a replacement candidate in case OpenWeather follows Dark Sky’s lead.
                                  anubis273
                                  Howdy!
                                  I installed this beautiful module to my magic mirror2. i run my mm in docker container and I´m at version 2.14. When I take a view at the official site it seems the latest version with 2.14 is confirmed.
                                  I think you know what comes next: I have installed the module properly and adjusted the configuration. However, only the word “forecast” is displayed. Now I have seen in the notes that I should be at least on version 2.2 with the magic mirror. I am slightly confused because 2.14 is the latest version?
                                  When I do a git pull it says that the latest version is already installed.
                                  Do I have a thinking error in my approach?
                                  Would be happy to hear something about this :-)
                                  kind regards,
                                  Nubi
                                  • ebolisaE Offline
                                    ebolisa @j.e.f.f
                                    @j-e-f-f It works on P0. My bad, had an extra space in the api key. Thank you.
                                      j.e.f.f Project Sponsor Module Developer @anubis273
                                      @anubis273 This module works on 2.14 – tested that specifically myself. MagicMirror’s version numbering can get a bit confusing… 2.14 is MUCH newer than 2.2. Versioning goes 2.2, 2.3, … 2.9, 2.10, 2.11, etc.
                                      Double check your config settings. Maybe try with just the minimal config required for MMM-OpenWeatherForecast – apikey, latitude, and longitude – and see if the module works with just those. Also make sure you’ve run npm install in the MMM-OpenWeatherForecast directory.
                                      If the module runs with just the above, then start adding your additional configuration options one at a time to see which one caused it to fail. Let me know and we can take it from there.
                                        anubis273 @j.e.f.f
                                        @j-e-f-f
                                        Hey j-e-f-f,
                                        thanks for clearing up my confusion about MagicMirror versions ;-) And thanks also for the quick feedback!
                                        So, I double checked the configuration and it doesn’t seem to have any syntax errors:
                                                header: "Forecast",
                                                    apikey: "myAPIKey",        //only string here
                                                    latitude: 50.748780,        //number works here
                                                    longitude: 7.137300        //so does a string
                                        I tried the minimal configuration as you suggested, unfortunately without success. I also checked the Api Key of OpenWeatherMap, this is also correct. The module also seems to work. The problem is that it just doesn’t load any weather data and I don’t understand why.
                                        If I find a solution to this, I will of course get back to you.
                                        Many greetings,
                                        Nubi
                                          @anubis273 I just tried the default config with your long/lat settings and the module worked for me. So let’s try digging a little more. Are you seeing any errors in the logs? There are a bunch of places to look:
                                          If you are running MagicMirror using PM2, run pm2 restart mm && pm2 logs mm. Look for any output prefixed with [MMM-OpenWeatherForecast]. If you are instead running MagicMirror from the command line, any errors will be in the in the console, prefixed like above.
                                          Also need to check to see if Electron is throwing any errors. start MagicMirror in dev mode npm start dev. Any Electron errors will show in the browser console, usually in red.
                                          Also, since the basic config isn’t working for you, but is for me, can you double check that your API Key is correct?
                                          • Jeff
                                          A 2 Replies Last reply Reply Quote 0
                                            anubis273 @j.e.f.f
                                            @j-e-f-f
                                            Hey j-e-f-f,
                                            thanks for your quick reply. I will investigate every single point you wrote. Give me a little time for that, I will get back to you as soon as possible.
                                            Regards from Germany,
                                            Nubi
                                            • 12
                                            • 13
                                            • 1 / 13
