    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 687.7k Views 57 Watching
    • karsten13K Offline
      karsten13 @sdetweil
      http://pirateweather.net
      C 1 Reply Last reply Reply Quote 1
      • C Offline
        chris1971 @karsten13
        @karsten13
        I tried a new API Token from pirateweather for OpenWeather - but the module is not loading. Do I have to do some other changes next to the API?
        The token is valid until April 22nd. Do I have to renew the token every month?
          sdetweil @chris1971
          @chris1971 pirate weather is the dark sky replacement.
          openweather has a different API token
          • C Offline
            chris1971 @sdetweil
            pirateweather is another module next to openweather? Sorry for the dumb question…
            Then I will try to go with Openweather acc. the description…
              sdetweil @chris1971
              @chris1971 no. pirateweather.net provides an API that looks like the dark sky API.
              so the dark sky module could be made to work again
              • C Offline
                chris1971 @sdetweil
                @sdetweil this would be cool. Will try and give a feedback soon.
                • C Offline
                  chris1971
                  I tried several API tokens from Pirateweather without success… But the old DarkSky APi is working again - I assume it will work only until March31st… :disappointed_face:
                    sdetweil @chris1971
                    @chris1971 you would have to change the dark sky module to use the pirate weather url too
                    • C Offline
                      chris1971
                      Do you have additional information what to change?
                      Thx
                        sdetweil @chris1971
                        @chris1971 no, but the pirateweather.net site would probably tell you
                        • C Offline
                          chris1971
                          Tried to install MMM-OpenWeatherForecast acc. the description and got a lot of errors during installation:
                          npm ERR! Linux 4.9.41-v7+
                          npm ERR! argv “/usr/bin/node” “/usr/bin/npm” “install”
                          npm ERR! node v6.12.0
                          npm ERR! npm v3.10.10
                          npm ERR! path /home/pi/MagicMirror/modules/MMM-OpenWeatherForecast/node_modules/.staging/@iarna/cli-64fafd25
                          npm ERR! code ENOENT
                          npm ERR! errno -2
                          npm ERR! syscall rename
                          npm ERR! enoent ENOENT: no such file or directory, rename ‘/home/pi/MagicMirror/modules/MMM-OpenWeatherForecast/node_modules/.staging/@iarna/cli-64fafd25’ -> ‘/home/pi/MagicMirror/modules/MMM-OpenWeatherForecast/node_modules/npm/node_modules/@iarna/cli’
                          npm ERR! enoent This is most likely not a problem with npm itself
                          npm ERR! enoent and is related to npm not being able to find a file.
                          npm ERR! enoent
                          npm ERR! /home/pi/MagicMirror/modules/MMM-OpenWeatherForecast/npm-debug.log<
                          After modification of the config and npm start I got a black screen and had to reset the system by disconnection from power supply. Any recommendations?
                            sdetweil @chris1971
                            @chris1971 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                            WAY downlevel…
                            should be node 16 and npm 8
                            use my install script, it sets up everything…
                            see https://github.com/sdetweil/MagicMirror_scripts
                            • C Offline
                              chris1971
                              I only have to type <“$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”> in the command line and the Update will be done automatically? No changes to the existing System?
                                sdetweil @chris1971
                                @chris1971 no type, just copy paste ( use ssh VM from desktop/laptop)
                                but still it’s a two part process, check by default, advise, make no changes
                                then rerun with Parm at the end to DO the upgrade
                                if you are ALREADY at the latest release, it will abort, unless that Parm is force
                                • BerkSmash1984B Offline
                                  BerkSmash1984
                                  Awesome module! Question for you: I am using MMM-Wallpaper and some of the text can be hard to read during certain wallpapers. I looked in the MMM-OpenWeatherForecast.css file but did not see an obvious place to change the color for the text highlighted in the red boxes below. I would like to set them to white (#FFFFFF). Can you tell me where in that css to set that? Thanks for your help!
                                    sdetweil @BerkSmash1984
                                    @BerkSmash1984 I do not know … but you can find out thru using the developers console
                                    see
                                    https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1679584458559
                                    BerkSmash1984B 1 Reply Last reply Reply Quote 0
                                      BerkSmash1984 @sdetweil
                                      Thank you! I will dig into it via the dev console
                                      • BKeyportB Offline
                                        BKeyport Module Developer @BerkSmash1984
                                        @BerkSmash1984
                                        It uses the defaults from MagicMirror for grey text. I use:
                                        root {
                                        	--color-text: #DDD;
                                        	--color-text-dimmed: #666;
                                        	--color-text-bright: #fff;
                                              --color-background: #000;
                                        /* Originals:
                                          --color-text: #999;
                                        BKeyportB BerkSmash1984B 3 Replies Last reply Reply Quote 0
                                        • BKeyportB Offline
                                          BKeyport Module Developer @BKeyport
                                          Anyone know how to get the entire table to center within the region? I don’t want to center the contents, only the position of the table being built by the app.
                                          thanks!
                                            sdetweil @BKeyport
                                            @BKeyport
                                            position: relative
                                            either use margin or x and width, margin is easier
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
