    Newsfeed Wrap with CSS
    13 Posts 3 Posters 3.9k Views 3 Watching
      schlittrix
      Hey,
      I’ve got a problem with the newsfeed-module.
      It works fine except the width, its too wide, so the text overwrites other modules. (newsfeed is centered).
      So .wrap doesn’t work.
      I tried it with CSS to fix the width, but than the “wrapped” text is still on the left side and not centered.
      Is there a possibility to center the “wrapped” text in the CSS-File or is there another option for me?
        Mykle1 Project Sponsor Module Developer @schlittrix
        @schlittrix
        From stackoverflow. I have not tested it.
        This should center the wrapped text as well. In custom.css file, add :
        text-align: center;
          schlittrix @Mykle1
          @mykle1
          Thank you. I tried this css-setup. The lengh is fine, but the center-function doesn’t work.
          newsfeed-desc { width: 700px; }
          text-align: center;
            sdetweil @schlittrix
            @schlittrix the text align has to be inside the bracesof the newsfeed class
            S 1 Reply Last reply Reply Quote 2
              schlittrix @sdetweil
              @sdetweil ouh. I’m a beginner :D
              so this way?
              newsfeed-desc { width: 700px; text-align: center; }
                @schlittrix yes
                u can specify lots of style elements in a single class like that
                for readability you should put the contents on separate lines inside the braces
                like this
                newsfeed-desc {
                     width: 700px;
                     text-align: center;
                S 2 Replies Last reply Reply Quote 2
                  @sdetweil said in Newsfeed Wrap with CSS:
                  @schlittrix yes
                  like this
                  newsfeed-desc {
                       width: 700px;
                       text-align: center;
                  thank you so much :)
                  I will try this today in the evening
                    @schlittrix yes
                    like this
                    newsfeed-desc {
                         width: 700px;
                         text-align: center;
                    so i tried this step without success…
                    When I just have the “width”-line, the text is wrapped, but not centered.
                    But when I put in these code with text-align, nothing happend and the text is no more wrapped…
                    any ideas? :(
                      @schlittrix
                      try this
                      newsfeed-desc {
                          width: 700px;
                          display: flex;
                          justify-content: center;
                      from here https://stackoverflow.com/questions/6618648/can-overflow-text-be-centered
                        newsfeed-desc {
                        width: 700px;
                        display: flex;
                        Don’t know, maybe I’m stupid…
                        but it still doesn’t work…
                        this is my config-setup:
                                                module: "newsfeed",
                                                position: "bottom_bar",
                                                        feeds: [
        title: "Tagesschau",
        url: "https://www.tagesschau.de/xml/rss2/"
                                                        showSourceTitle: true,
                                                        showPublishDate: true,
                                                        broadcastNewsFeeds: true,
                                                        broadcastNewsUpdates: true,
                                                        showDescription: true,
                                                        wrapDescription: true
                        and this is the css-file:
                        newsfeed-desc {
                            width: 500px;
                            display: flex;
