    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 463.3k Views 31 Watching
      sdetweil @stoffel
      @stoffel MMM-Config … MM is happy
      did the collector crash again, where u start MM, npm start or pm2 logs --lines=100
        stoffel
        autostart with pm2
          stoffel
          ok, what i see is when i start mm with npm start it loads all modules what i have installt not only from the config.js (i use now the default config.js from mm). Next i delete all moduls what i not needed.
            sdetweil @stoffel
            @stoffel sorry, I do not understand
            if there is a collector error, you should see something like
            /home/sam/mmm-config/scripts/buildschema3.js:619
              return data[left];
            TypeError: Cannot read property 'feeds' of undefined
                at get_define_info (/home/sam/mmm-config/scripts/buildschema3.js:619:14)
                at /home/sam/mmm-config/scripts/buildschema3.js:415:29
                at Array.forEach (<anonymous>)
                at Object.<anonymous> (/home/sam/mmm-config/scripts/buildschema3.js:405:24)
              stoffel
              ok, i think so,
              0|MagicMirror  | stderr 2: /home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:595
              0|MagicMirror  |     let tt = data[left];
              0|MagicMirror  |                  ^
              0|MagicMirror  | TypeError: Cannot read property '' of undefined
              0|MagicMirror  |     at get_define_info (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:595:18)
              0|MagicMirror  |     at get_define_info (/home/pi/MagicMirror/modules/MMM-Config/scripts/buildschema3.js:599:12)
              look at page 2 the 2. post
                sdetweil @stoffel
                @stoffel yes, that is because of the … the code splits the string with . and not I have 10 items, some empty… oops…
                working on fix…
                  sdetweil @stoffel
                  @stoffel I think I have a fix
                  see the issue for instructions
                  https://github.com/sdetweil/MMM-Config/issues/8
                  • FoziF Offline
                    Fozi Project Sponsor @sdetweil
                    @sdetweil The “Mother of all Modules”! :love-you_gesture_light_skin_tone:
                    That’s a fantastic job, Sam! Especially beginners will be grateful, but not only beginners.
                    • StoffbeuteluweS Offline
                      Stoffbeuteluwe Project Sponsor
                      Hi I only see this…?
                      Need a little bit help :grinning_face:
                      S 1 Reply Last reply Reply Quote -1
                        sdetweil @Stoffbeuteluwe
                        @stoffbeuteluwe try again , git pull the repo…
                          stoffel
                          i have fix it with your issues. thank you very much !!
                            sdetweil @stoffel
                            @stoffel i have seen a couple places in some data where I inadvertently change paths to files with leading …
                            so be careful…
                            will update fix when I have it…
                              stoffel
                              ok, thanks. it works well with all my modules, great!
                              but when i add the MMM-Volume i have another error. i think it is a problem from MMM-Volume. it’s two years old. it’s a json format error
                                sdetweil @stoffel
                                @stoffel no, I fixed a problem with MMM-Volume earlier today… haven’t pushed it yet…
                                  stoffel @sdetweil
                                  ok
                                  when you module works also with MMM-Volume then i am very happy.:beaming_face_with_smiling_eyes: i control my mm over remote control.
                                  thank you very much for your support, great job :thumbs_up:
                                    sdetweil @stoffel
                                    @stoffel do a git pull on the newform branch, and try it out… this is with the fix for MMM-Volume
                                    and another, plus an npm install after
                                    • AssassinsA Offline
                                      Assassins
                                      Work 100% with rpi 3, Nice modul you made, Thanks alot
                                        stoffel @sdetweil
                                        good morning
                                        sometimes i can not post, when i submit i have a error message in the lower right corner ?!
                                        ok, i’v tested your fix. at the moment your module do not work for. in mm says i use localhost, but in my config i have addressed at 0.0.0.0 and ipWhitelist: []
                                        i send you the result of pm2 logs --lines=100. one for test without MMM-Volume and one with.
                                        i hope it’s help you.
                                          sdetweil @stoffel
                                          @stoffel yes, the forum is not very helpful on why a posting error… i get it too…
                                          i refresh the screen and then I can post the exact same message… (I copy it before refresh)
                                          MMM-Volume… i thought i pushed that one line change… just did… git pull
                                          the localhost/0.0.0.0
                                          will examine
                                            sdetweil @stoffel
                                            @stoffel ok, fixes… in branch newform…
                                            on the QR code messages I was changing address AND ipWhitelist EMPTY…
                                            i only check address now, and assume you know what you are doing on whitelist
                                            • 14
                                            • 15
                                            • 2 / 15
