    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
    • A
      Alyx
      amazing work!!! are users able to make module communicate with each other? Such as using voice commands to use another module via notifications?
      S 2 Replies Last reply
        sdetweil @Alyx
        @alyx I don’t understand your question
        A 1 Reply Last reply
          sdetweil @Dinschal
          @dinschal is this from the qr?
          or did u enter a url?
          note the url is
          http://mmipaddr:mmport/modules/MMM-Config/review
          D 1 Reply Last reply
            sdetweil @Alyx
            @alyx voiceCommander is built on top of MMM-Voice and Hello-Lucy
            so, CAN you, certainly… take a voice audio -> recognizer -> send notification to other modules…
            HOW depends on the module being used…
            sometimes there is some config
            sometimes there is file editing
            sometimes there is coding
            • A
              Alyx @sdetweil
              @sdetweil No worries I’ll install and play around with this tomorrow, I was wondering if it would help with setting up modules to talk to each other, as you know I’ve been having a few issues with that xD
                sdetweil @Alyx
                @alyx My Module ONLY addresses configuration of EACH module (stuff that goes in config.js)
                what that stuff DOES/MEANS, my module does not know…
                I read the source code to figure out the variables defined
                and merge that with any info from config.js
                and build a form to collect the data
                then on save, I take the elements with data and build a new config.js
                (rename the old and write the new)
                and if restart , then I restart MM to use that new config
                • A
                  Alyx @sdetweil
                  @sdetweil Sounds great as is Sam cant wait to try it tomorrow!
                  • D
                    Dinschal @sdetweil
                    @sdetweil ah okay i used the wrong one… i used the one with config.html
                    • D
                      Dinschal
                      Is it possible to add a css section in the future? that would be really nice…
                      thanks for your work and thanks for helping me ;)
                      • D
                        Dinschal
                        @sdetweil your module is running well, but if i changed something and create the config, it deleted the location, the locationid and the weather api from the default weather module :( this is really bad… and if i change the timefomat and the analog size in the same module and push the save, create config button it didnt save the canges.
                          sdetweil @Dinschal
                          @dinschal what do u mean css section?
                          D S 2 Replies Last reply
                          • D
                            Dinschal @sdetweil
                            @sdetweil first off all good morning ;)
                            a section where you can edit the css sections of the modules… like the size or something else…
                              sdetweil @Dinschal
                              @dinschal did u set the position in the positions section?
                              can u add debug:true to my module config
                              copy back the prior config.js
                              start mm like this
                              cd ~/MagicMirror
                              npm start >somefile.txt
                              then do the change again
                              press save
                              then stop mm (ctrl-q)
                              and send me the somefile.txt
                              and the two config file, prior and new
                              and the defaults.js from the module folder
                              via email. my email is this same userid at gmail
                              u will have to rename the .js files to
                              like .txt as js files are not allowed
                                sdetweil @Dinschal
                                @dinschal ah, I think that would be very difficult.
                                unless it was a text box w the same thing u would put in custom.css
                                  @sdetweil one thing on position.
                                  I write them out in the same order by
                                  position:
                                  all the top_left together, then the top_right, etc
                                  using the module position order value, u can adjust the order of a module in a position list
                                  ( I add order: to the module info, so I can continue to keep them that way)
                                  as mm shows them that way
                                  they may NOT be in the same location( line number) in the new file
                                  • D
                                    Dinschal @sdetweil
                                    @sdetweil you got mail ;)
                                      sdetweil @Dinschal
                                      @dinschal I replied
                                      • D
                                        Dinschal @sdetweil
                                        @sdetweil yeah i have to search the right one :D
                                        • A
                                          Alyx
                                          Hi Sam,
                                          I installed this just there on a fresh image and MM install. All good except my web-view is blank. Well the title comes up with the light brown background but there’s no content beyond that.
                                          Do I need to begin installing other modules in tandem with this?
                                            sdetweil @Alyx
                                            @alyx no… should work as is for the defaults…
                                            let me look
                                            • 6
                                            • 7
                                            • 8
                                            • 14
                                            • 15
                                            • 6 / 15
