    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 463.3k Views 31 Watching
      Dinschal @sdetweil
      @sdetweil haha in the past i was tired of reading the doc too ;) but too many failures made me to read it ;)
        Alyx
        So I’m experiencing a new issue where when I use the editor and trhen press save its not actually saving the new co’ve reinstallked the module and even chmod the folder to 777
        Is this an issue others are experiencing?
        I have the config for it on the defualt settings and the somefile.txt reports that everything is find and it opened successfully on port 8301 ( this seems to change actually) I’m thinking that the port is changing while I’m editing?
        S 3 Replies Last reply Reply Quote 0
          sdetweil @Alyx
          @alyx no. the code looks for a free port, and then starts the socket connection there.
          send my the debug output from
          debug;true
          and npm start >somefile.txt
          via email
            sdetweil @Alyx
            @alyx said in Are you tired of editing config.js, or have trouble doing it, see my new module:
            please don’t do crazy things. post and I will help
              sdetweil @Alyx
              @alyx under the submit button two messages are written
              Your Configuration has been submitted
              and
              config.js created successfully
                Alyx @sdetweil
                Did the debug what folder does it go to? I have the somefile ready also
                As for the messages I get the first part but not the second saying its created
                  sdetweil @Alyx
                  @alyx debug is set in config.js for my module
                  the somefile is the debug output from save
                  also send the config.js and the defaulys.js from my module folder.
                  the .js files will have to be renamed to .txt
                  as .js files cannot be sent as attachments
                  my email is my same userid at gmail
                  lack of the second message means some content formatting issue
                    Alyx @sdetweil
                    @sdetweil Sent over there cheers
                      sdetweil @Alyx
                      @alyx sent message back. need the rest of debug
                        Alyx @sdetweil
                        @sdetweil sent back over
                          sdetweil @Alyx
                          @alyx yes… saw. was at car dealer for oil change… just got back…
                            Alyx @sdetweil
                            @sdetweil Ah no worries was out for some materials to build the mirror frame myself haha
                              sdetweil @Alyx
                              @alyx ok, the crash is because u have a bad position for selfieshoot in config.js
                              	module: "MMM-Selfieshot",
                                  position: "bottom",
                              bottom is not valid
                              https://docs.magicmirror.builders/modules/configuration.html#example
                              separate lines are my addition to the view
                              The location of the module in which the module will be loaded. Possible values are
                              top_bar,
                              top_left,
                              top_center,
                              top_right,
                              upper_third,
                              middle_center,
                              lower_third,
                              bottom_left,
                              bottom_center,
                              bottom_right,
                              bottom_bar,
                              fullscreen_above, and
                              fullscreen_below.
                              S A 2 Replies Last reply Reply Quote 0
                                I opened issue to document changes to protect against crashing
                                https://github.com/sdetweil/MMM-Config/issues/31
                                  Alyx @sdetweil
                                  @sdetweil OK back working now with that thanks! Although the conf for my pm2 seems to be not working anymore, I think I saw a similar issue somewhere in the comments here?
                                  Also I cant get the conf page anymore cause it can no longer get /modules/MMM-Config/review
                                    sdetweil @Alyx
                                    eh?? what conf for pm2? where?
                                    pm2 setup is done once at install (if you use my script and it just points to the ~/MagicMirror/installers/mm.sh
                                    eh??
                                    http://localhost:8080/modules/MMM-Config/review
                                    (the MM config says localhost, SO the url MUST be localhost to match…
                                    anything else
                                    (ip or name)
                                    will fail
                                      Alyx @sdetweil
                                      @sdetweil Before I was able to connect my alexa as a smart device with pm2 but now its not showing at all on alexa is what i mean.
                                      Yep that the link I use but I get the the home page and its the same blank interface as before with no modules tab or anything? Like I just used it to make the latest conf file so I know it works some how haha
                                        Alyx @Alyx
                                        @alyx ok screw that its working now all of a sudden ahaha
                                        The alexa thing still isnt working tho
                                          sdetweil @Alyx
                                          @alyx i;m not sure what u mean by the alexaControl problem
                                          u set it up once and then do Alexa Discover Devices.
                                          they are there forever …(until u manually delete them)
                                          now… IF the machine IP changes (like across a reboot)
                                          then the ip address that alexa saved is no longer valid and alexa can’t find them
                                          it does NOT save dns NAME, only IP address.
                                            Alyx @sdetweil
                                            Yes thats what I mean I haven’t changed anything like that although. I just used the script and the generated config file. It seems alexa can no longer find the devices and is displaying them as offline
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 14
                                            • 15
                                            • 8 / 15
