    Cursor shown in v2.16.0
    18 Posts 4 Posters 6.2k Views 4 Watching
      MajorC Project Sponsor
      I have a solid black cursor on my MM v2.16.0. The cursor disappears as soon as I move the mouse the first time.
      In the main.css I see:
      html {
        cursor: none;
        overflow: hidden;
        background: var(--color-background);
        user-select: none;
        font-size: var(--font-size);
      I used the script from @sdetweil to update and install my MM.
      Any ideas how to fix that? I think, I saw this behavior first time after updating to v2.15.0.
        MacG
        I have that too but am still in the setup phase from the Magic Mirror. The mouse and keyboard are still connected. Have you seen these solutions?
        https://forum.magicmirror.builders/topic/9859/mouse-arrow-doesn-t-hide-after-magicmirror-is-loaded
        https://github.com/evghenix/MMM-Cursor
        A transparent PNG or GIF file will probably not work either, because a mouse movement is expected.
        cursor: url(pointer.png), none;
        the “none” is a necessary fallback.
          sdetweil @MajorC
          @majorc maybe install unclutter?
            MajorC Project Sponsor @sdetweil
            @sdetweil as it was working fine before, I am not 100% happy to just install something over.
              MajorC Project Sponsor @MajorC
              Fun fact, if I move the the mouse, the cursor disappears immediately.
                sdetweil @MajorC
                @majorc so, it sounds like a defect in the electron version in 2.16
                  @sdetweil I do not know what that mean. Is there a way that I can fix it?
                  Or do I have to wait for version 17?
                  S karsten13K 2 Replies Last reply Reply Quote 0
                    sdetweil @MajorC
                    @majorc if u use chrome do u see the cursor
                    my prior comment was that maybe WE don’t have a solution
                      @sdetweil I see the cursor only on the pi. And it disappears if I move the mouse the first time on the pi. But the cursor is visible again after i do a
                      pm2 restart 0
                      On my windows machine witch chrome, I don’t see the cursor at no time.
                        sdetweil @MajorC
                        @majorc so, that confirms it’s an electron issue.
                        you could change to run server mode with chrome on the pi.
                        • karsten13K Online
                          karsten13 @MajorC
                          @majorc said in Cursor shown in v2.16.0:
                          In v2.16.0 we have electron v11, in current develop branch (which will become v2.17.0 in October) we have upgraded to electron v13.
                            sdetweil @karsten13
                            @karsten13 @MajorC
                            so u can try develop, but there is no guarantee that is is fixed there
                            karsten13K 1 Reply Last reply Reply Quote 1
                            • karsten13K Online
                              karsten13 @sdetweil
                              could fix the black cursor with an entry in custom.css:
                              html {
                                cursor: none !important;
                              Can you test if this works on your side? If so we should change this in main.css (will provide a PR then).
                                MajorC Project Sponsor @karsten13
                                @karsten13 said in Cursor shown in v2.16.0:
                                Hi Kasten,
                                I tried !important in the custom.css and in the main.css. The cursor is still visible.
                                Even after after a reboot of the pi, the same, still visible.
                                I think I will wait for v2.17.0 in October.
                                • karsten13K Online
                                  karsten13 @MajorC
                                  @majorc
                                  tried yesterday on my pi3:
                                  • v2.16.0: no cursor
                                  • v2.17.0-develop: black cursor
                                  • v2.17.0-develop with css cursor: none !important;: no cursor
                                  So waiting on v2.17.0 is no solution.
                                  Another idea is to simulate a cursor movement on electron start.
                                  • karsten13K Online
                                    karsten13 @MajorC
                                    @majorc
                                    can you try to patch the file js/electron.js for a test, please add the following at line 74:
                                    	mainWindow.webContents.on('dom-ready', (event)=> {
                                    		mainWindow.webContents.sendInputEvent({type: "mouseMove", x: 0, y: 0});
                                    Does this hide the black cursor?
                                    (I changed the code here again …)
                                      Like so?
                                      // Open the DevTools if run with "npm start dev"
                                      	if (process.argv.includes("dev")) {
                                      		if (process.env.JEST_WORKER_ID !== undefined) {
                                      			// if we are running with jest
                                      			var devtools = new BrowserWindow(electronOptions);
                                      			mainWindow.webContents.setDevToolsWebContents(devtools.webContents);
                                      		mainWindow.webContents.openDevTools();
                                      	// Set responders for window events.
                                      	mainWindow.on("closed", function () {
                                      		mainWindow = null;
                                      That works perfekt! Thank you so much!
                                      • karsten13K Online
                                        karsten13 @MajorC
                                        @majorc o.k., then I will provide a PR for this in the mm repo
