    Calendar events showing on wrong day.
    66 Posts 3 Posters 35.8k Views 3 Watching
      sdetweil @Coolie1101
      @coolie1101 if you just do
      in the MagicMirror folder
      npm start
      you should have a stream of stuff so fast u can’t read
      • Coolie1101C Offline
        Coolie1101 @sdetweil
        @sdetweil said in Calendar events showing on wrong day.:
        so, I need to see THAT vevent
        BEGIN:VEVENT
        DTSTART:20211123T100000Z
        DTEND:20211123T150000Z
        DTSTAMP:20211119T151956Z
        UID:0g4190e8en06vs************@google.com
        CREATED:20211119T151237Z
        DESCRIPTION:
        LAST-MODIFIED:20211119T151237Z
        SEQUENCE:0
        STATUS:CONFIRMED
        SUMMARY:YARD WASTE
        TRANSP:OPAQUE
        END:VEVENT
        There’s no output in the ssh window except for the following.
        pi@magicmirror:~/MagicMirror $ npm start >cal_test_debug_log.txt
        [19.11.2021 10:25.12.563] [WARN]  (electron) Security Warning: A WebContents was just created with both webviewTag and contextIsolation enabled.  This combination is fundamentally less secure and effectively bypasses the protections of contextIsolation.  We strongly recommend you move away from webviews to OOPIF or BrowserView in order for your app to be more secure
        [19.11.2021 10:25.13.777] [ERROR] ERROR! Could not find main module js file for MMM-GABackground
          @coolie1101 correct, you are sending all the output to the file (except the stuff to stderr)
          if you remove everything from the > on you’ll get the output to the ssh window, BUT it will be so big, the top will scroll off and be lost… (which is why we are sending to a file)
          Coolie1101C 1 Reply Last reply Reply Quote 0
            @sdetweil Got it, I didn’t realize the file continued on, it’s 2,486kb, which part do you need?
              @coolie1101 see this post
              https://forum.magicmirror.builders/topic/15878/calendar-events-showing-on-wrong-day/28?_=1636916667651
              from processing entry thru saving for the vevent that is the problem
              maybe 20-30 lines
                Event: {"type":"VEVENT","params":[],"start":"2021-11-23T10:00:00.000Z","datetype":"date-time","end":"2021-11-23T15:00:00.000Z","dtstamp":"2021-11-19T15:25:46.000Z","uid":"0g4190e8en06vs************@google.com","created":"2021-11-19T15:12:37.000Z","description":"","lastmodified":"2021-11-19T15:12:37.000Z","location":"","sequence":"0","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"}
                [19.11.2021 10:26.06.439] [DEBUG] startDate (local): Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                [19.11.2021 10:26.06.440] [DEBUG] endDate (local): Tue Nov 23 2021 10:00:00 GMT-0500 (Eastern Standard Time)
                [19.11.2021 10:26.06.442] [DEBUG] duration: 18000000
                [19.11.2021 10:26.06.443] [DEBUG] title: YARD WASTE
                [19.11.2021 10:26.06.465] [DEBUG] initial tz=Etc/UTC
                [19.11.2021 10:26.06.474] [DEBUG] corrected tz=Etc/UTC
                [19.11.2021 10:26.06.478] [DEBUG] start date/time=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                [19.11.2021 10:26.06.492] [DEBUG] start offset=0
                [19.11.2021 10:26.06.495] [DEBUG] start date/time w tz =Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                [19.11.2021 10:26.06.498] [DEBUG] event date=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                [19.11.2021 10:26.06.500] [DEBUG] event offset=0 hour=10 event date=Tue Nov 23 2021 05:00:00 GMT-0500 (Eastern Standard Time)
                [19.11.2021 10:26.06.514] [DEBUG] adjustHours=0
                [19.11.2021 10:26.06.523] [DEBUG] Processing entry...
                [19.11.2021 10:26.06.527] [DEBUG]
                [19.11.2021 10:26.08.304] [DEBUG] Title: YARD WASTE, with dates: ["2021-11-23T09:00:00.000Z","2021-11-30T09:00:00.000Z","2021-12-07T09:00:00.000Z","2021-12-14T09:00:00.000Z","2021-12-21T09:00:00.000Z","2021-12-28T09:00:00.000Z"]
                The one in question at the moment is ““2021-11-30T09:00:00.000Z”” which display’s as 2021-12-01
                  @coolie1101 yes that’s what the correction should enable
                  05:00 ny, +4 (now est) =09:00 utc time
                    @coolie1101 but there is no time zone set in the appointment
                      It shows as set in the calendar itself?
                        @coolie1101 yes, BUT it doesn’t show in the ics file…
                        anyhow…
                        show me the next entry from the debug output
                        or send me the debug output file via email
                        same userid at gmail
                          Event: {"type":"VEVENT","params":[],"start":"2022-01-26T10:00:00.000Z","datetype":"date-time","end":"2022-01-26T15:00:00.000Z","dtstamp":"2021-11-19T16:07:10.000Z","uid":"0idffl8ue0gac*************@google.com","created":"2021-11-19T13:18:54.000Z","description":"Recycling Bottles, Cans, and Plastic.","lastmodified":"2021-11-19T13:18:54.000Z","location":"","sequence":"0","status":"CONFIRMED","summary":"RECYCLING (BOTTLES, CANS and PLASTIC) ","transparency":"TRANSPARENT"}
                          [19.11.2021 11:07.22.130] [DEBUG] startDate (local): Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                          [19.11.2021 11:07.22.135] [DEBUG] endDate (local): Wed Jan 26 2022 10:00:00 GMT-0500 (Eastern Standard Time)
                          [19.11.2021 11:07.22.141] [DEBUG] duration: 18000000
                          [19.11.2021 11:07.22.146] [DEBUG] title: RECYCLING (BOTTLES, CANS and PLASTIC)
                          [19.11.2021 11:07.22.160] [DEBUG] initial tz=Etc/UTC
                          [19.11.2021 11:07.22.169] [DEBUG] corrected tz=Etc/UTC
                          [19.11.2021 11:07.22.174] [DEBUG] start date/time=Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                          [19.11.2021 11:07.22.178] [DEBUG] start offset=0
                          [19.11.2021 11:07.22.182] [DEBUG] start date/time w tz =Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                          [19.11.2021 11:07.22.189] [DEBUG] event date=Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                          [19.11.2021 11:07.22.195] [DEBUG] event offset=0 hour=10 event date=Wed Jan 26 2022 05:00:00 GMT-0500 (Eastern Standard Time)
                          [19.11.2021 11:07.22.202] [DEBUG] adjustHours=0
                          [19.11.2021 11:07.22.209] [DEBUG] Processing entry...
                          [19.11.2021 11:07.22.217] [DEBUG]
                          This is the Calendar Event I believe we should be looking at
                          BEGIN:VEVENT
                          DTSTART;TZID=America/New_York:20210406T050000
                          DTEND;TZID=America/New_York:20210406T100000
                          RRULE:FREQ=WEEKLY;WKST=SU;UNTIL=20211230T045959Z;BYDAY=TU
                          EXDATE;TZID=America/New_York:20211123T050000
                          DTSTAMP:20211119T165604Z
                          UID:0v89h5cit8nq6m************@google.com
                          CREATED:20211026T075843Z
                          DESCRIPTION:
                          LAST-MODIFIED:20211026T080254Z
                          SEQUENCE:1
                          STATUS:CONFIRMED
                          SUMMARY:YARD WASTE
                          TRANSP:OPAQUE
                          END:VEVENT
                          This last event listed as “UNTIL=20211230T045959Z”, displays as Dec 1st.
                            @coolie1101 I added 2 to the end, Yard Waste 2, and see this, with my system set to eastern time. I didn’t delete the prior ics entries
                              @sdetweil I understand that it works, and it is indeed working, but why is it showing a day later is what I am trying to figure out, what about the entries for 11/23-12/6?
                                @coolie1101 I don’t see a day late… the event is Tuesdays, weekly, 11/23 is tuesday, 11/30 is tuesday, 12/7 is tuesday
                                I am looking for the 11/23 entry…
                                DUH, it says exclude 11/23
                                  Those dates are correct, the 11/23 entry was deleted and re-added, so it’s not part of the yearly schedule anymore.
                                  For me the entry for 11/30 displays on the monitor as Dec 1st.
                                    @coolie1101 said in Calendar events showing on wrong day.:
                                    its hard to tell which cal entry it comes from when the text is all the same.
                                    Coolie1101C 2 Replies Last reply Reply Quote 0
                                      @sdetweil I believe it’s form the one i posted earlier, top of this page.
                                        This is the new (re-created) entry
                                        BEGIN:VEVENT
                                        DESCRIPTION:
                                        SEQUENCE:0
                                        STATUS:CONFIRMED
                                        SUMMARY:YARD WASTE
                                        TRANSP:OPAQUE
                                        END:VEVENT
                                        This is the old (yearly) entry
                                        BEGIN:VEVENT
                                        DESCRIPTION:
                                        SEQUENCE:1
                                        STATUS:CONFIRMED
                                        SUMMARY:YARD WASTE
                                        TRANSP:OPAQUE
                                        END:VEVENT
                                          @coolie1101 I don’t see the wrong date
                                          yard waste is on 11/30
                                            All highlited is a day ahead.
                                            • 3 / 4
