    MMM-SwissTransport
    transportation
    17 Posts 7 Posters 14.5k Views 9 Watching
      Bangee Module Developer
      I’ve created a new module called SwissTransport Module which shows next trains departing on your favourit station.
      It’s based on modified basic moduls from magic mirror and an opensource API.
      on git you’ll find it here:
      [card:Bangee44/MMM-swisstransport]
      How can I add many diffrent departingstation? Any suggestions?
        https://github.com/Bangee44/MMM-TrainConnections
        I’ve modified my script. Check out this one.
        P F 2 Replies Last reply Reply Quote 0
        • K Offline
          KirAsh4 Moderator
          For troubleshooting or HOWTO questions, please post in the Troubleshooting thread:
          https://forum.magicmirror.builders/topic/212/mmm-swisstransport/1
          • F Offline
            flooo @Bangee
            @Bangee is the first version of this module still around?
            I prefer the old versions style as it looks ‘cleaner’…
            If this version doesn’t exist anymore, is it a load of stuff I would have to change to create that look in the new version? :D
            • K Offline
              KirAsh4 Moderator @flooo
              @flooo, you can look at the repository’s commit history (https://github.com/Bangee44/MMM-swisstransport/commits/master), and then checkout a specific revision by using the SHA1: git checkout <sha1> Note that you may need to use the full sha1 value, not the truncated one.
              For example, the last commit on May 3rd is 146a6ce. If you click on that, it expands that commit and you can see the full sha1 value as 146a6cec2aaa5007255cb157ed415ba180639354 in the upper right. So your checkout command then becomes:
              git checkout 146a6cec2aaa5007255cb157ed415ba180639354
              This is of course done from INSIDE the module’s folder!
              • K Offline
                KirAsh4 Moderator
                Oh, I just noticed that his post where he said he change it was also done on May 3rd … so perhaps that original version no longer exists, which sort of defeats the purpose of using git …
                  I think you would like to use this one.
                  • F Offline
                    flooo
                    cool, thanks a lot
                    • kwyjibo089K Offline
                      kwyjibo089
                      Great module. Already added it to my mirror. Is there any chance I could filter the list and display only trains? If I put in my Station (Wädenswil) I get lots of busses and also boats.
                        @kwyjibo089, yes it’s possible:
                        change the line function getParams() like this:
                        	/* getParams()
                        	 * Generates an url with api parameters based on the config.
                        	 * return String - URL params.
                        	getParams: function() {
                        		var params = "?";
                                        params += "id=" + this.config.id;
                        		params += "&limit=" + this.config.maximumEntries;
                                        params += "&transportations[]=ec_ic&transportations[]=s_sn_r&transportations[]=ir&transportations[]=re_d&transportations[]=ice_tgv_rj";
                        		return params;
                        The line params += "&transportations[]=ec_ic&transportations[]=s_sn_r..."; is new an should allow you to filter the transportation object.
                        Here are all option:
                        transportations
                        Transportation means; one or more of ice_tgv_rj, ec_ic, ir, re_d, ship, s_sn_r, bus, cableway, arz_ext, tramway_underground
                        example:
                        &transportations[]=ec_ic&transportations[]=bus
                        Source: http://transport.opendata.ch/docs.html#section
                        It’s not testet yet, but I think it should work for you.
                        Have fun,
                        Gruss aus Oberrieden :-)
                        kwyjibo089K 1 Reply Last reply Reply Quote 0
                          kwyjibo089 @Bangee
                          nice, works like a charm! thanks a lot!
                            I’ve made an update. Now it works with a node_helper.js so you will have less problems with CORS errors.
                            Have fun
                              mydiva
                              Hi @Bangee
                              Now it stays with connection and shows nothing else. I tried a clean install of the module but it did’t work anymore.
                                BenGig
                                Has the station ID based data source been dropped by search.ch? Connections are not so convenient as station departure times. I have a bus stop nearby and want do display all departures, one particular connection is not informative enough.
                                • V Offline
                                  vanhoekd
                                  Departure times have not been dropped by Search.ch. I had the same Issue as BenGig and then just reverted to the old version, which is still working.
                                    kwyjibo089 @vanhoekd
                                    @vanhoekd said in MMM-SwissTransport:
                                    how do you do that?
                                    • V Offline
                                      vanhoekd
                                      Use
                                      git checkout sha1
                                      to check out a particular commit.
                                      where sha1 is the number of the commit on this site: Git repo
