    MMM-SwissTransport
    transportation
    17 Posts 7 Posters 13.5k Views 9 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator @flooo
      @flooo, you can look at the repository’s commit history (https://github.com/Bangee44/MMM-swisstransport/commits/master), and then checkout a specific revision by using the SHA1: git checkout <sha1> Note that you may need to use the full sha1 value, not the truncated one.
      For example, the last commit on May 3rd is 146a6ce. If you click on that, it expands that commit and you can see the full sha1 value as 146a6cec2aaa5007255cb157ed415ba180639354 in the upper right. So your checkout command then becomes:
      git checkout 146a6cec2aaa5007255cb157ed415ba180639354
      This is of course done from INSIDE the module’s folder!
      • KirAsh4K Offline
        KirAsh4 Moderator
        Oh, I just noticed that his post where he said he change it was also done on May 3rd … so perhaps that original version no longer exists, which sort of defeats the purpose of using git …
        • BangeeB Offline
          Bangee Module Developer
          I think you would like to use this one.
          • floooF Offline
            flooo
            cool, thanks a lot
            • kwyjibo089K Offline
              kwyjibo089
              Great module. Already added it to my mirror. Is there any chance I could filter the list and display only trains? If I put in my Station (Wädenswil) I get lots of busses and also boats.
              • BangeeB Offline
                @kwyjibo089, yes it’s possible:
                change the line function getParams() like this:
                	/* getParams()
                	 * Generates an url with api parameters based on the config.
                	 * return String - URL params.
                	getParams: function() {
                		var params = "?";
                                params += "id=" + this.config.id;
                		params += "&limit=" + this.config.maximumEntries;
                                params += "&transportations[]=ec_ic&transportations[]=s_sn_r&transportations[]=ir&transportations[]=re_d&transportations[]=ice_tgv_rj";
                		return params;
                The line params += "&transportations[]=ec_ic&transportations[]=s_sn_r..."; is new an should allow you to filter the transportation object.
                Here are all option:
                transportations
                Transportation means; one or more of ice_tgv_rj, ec_ic, ir, re_d, ship, s_sn_r, bus, cableway, arz_ext, tramway_underground
                example:
                &transportations[]=ec_ic&transportations[]=bus
                Source: http://transport.opendata.ch/docs.html#section
                It’s not testet yet, but I think it should work for you.
                Have fun,
                Gruss aus Oberrieden :-)
                kwyjibo089K 1 Reply Last reply Reply Quote 0
                  kwyjibo089 @Bangee
                  nice, works like a charm! thanks a lot!
                  • BangeeB Offline
                    I’ve made an update. Now it works with a node_helper.js so you will have less problems with CORS errors.
                    Have fun
                      mydiva
                      Hi @Bangee
                      Now it stays with connection and shows nothing else. I tried a clean install of the module but it did’t work anymore.
                        BenGig
                        Has the station ID based data source been dropped by search.ch? Connections are not so convenient as station departure times. I have a bus stop nearby and want do display all departures, one particular connection is not informative enough.
