    How to hide Splash screen on boot or edit Splash screen on boot?
    12 Posts 7 Posters 13.8k Views 6 Watching
    • N Offline
      nobita
      Becuase I would like to show other Text replace Splash screen on boot
      Thanks for help
        broberg Project Sponsor
        First hit on google, h
        ttp://www.raspberry-projects.com/pi/pi-operating-systems/raspbian/custom-boot-up-screen
        Don’t know if it works on all PI’s however
        • L Offline
          lolobyte
          Hi, if you have installed the jessie plex version, you have to start
          sudo raspi-config
          At point 3 Boot Options it is possiblr to general disable or enable the splash screen on boot.
          If you have an normal jessie without plex the use a custom splash screen
          sudo apt-get install fbi
          Copy your custom splash image to /etc/ and name it splash.png.
          Next, create an init.d script called “asplashscreen” in “/etc/init.d/”.
          Create now this script with
          sudo nano /etc/init.d/asplashscreen
          #! /bin/sh
          ### BEGIN INIT INFO
          # Provides:          asplashscreen
          # Required-Start:
          # Required-Stop:
          # Should-Start:
          # Default-Start:     S
          # Default-Stop:
          # Short-Description: Show custom splashscreen
          # Description:       Show custom splashscreen
          ### END INIT INFO
          do_start () {
              /usr/bin/fbi -T 1 -noverbose -a /etc/splash.png
              exit 0
          case "$1" in
            start|"")
              do_start
            restart|reload|force-reload)
              echo "Error: argument '$1' not supported" >&2
              exit 3
            stop)
              # No-op
            status)
              exit 0
              echo "Usage: asplashscreen [start|stop]" >&2
              exit 3
          esac
          Then make that script executable and install it for init:
          sudo chmod a+x /etc/init.d/asplashscreen
          sudo insserv /etc/init.d/asplashscreen
          Reboot and watch your custom splash screen:
          sudo reboot
          If you want to hide most of the Boot text then follow this step:
          sudo nano /boot/cmdline.txt
          may look something like this:
          tty3: starts with console 3 to hide the boot messages!
          dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty3 loglevel=3 logo.nologo root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
          good luck
          Mod-Edit: Please use markdown, otherwise this becomes totally unreadable.
          N 1 Reply Last reply Reply Quote 1
          • N Offline
            nobita @lolobyte
            @lolobyte Thanks your help,I will try later
            • L Offline
              lolobyte
              Sorry, don’ know who has written this…
              Probably a Moderator.
              What please is “markdown” and how to use it?
                broberg Project Sponsor @lolobyte
                @lolobyte
                Here is a documentation of markdown :
                http://commonmark.org/help/
                  schlachtkreuzer6
                  The the easiest way to change the splash screen is changing the picture ;) https://pi280.wordpress.com/2016/10/17/about-that-pixel-splash-screen/
                  • N Offline
                    nobita @schlachtkreuzer6
                    @schlachtkreuzer6 I mean Splash screen on boot like this0_1486022813410_S__4210701.jpg
                    Y S 2 Replies Last reply Reply Quote 2
                    • Y Offline
                      yawns Moderator @nobita
                      @nobita
                      I did not check, so this is all theory.
                      The splashscreen is using plymouth, so you should be able to change it the “common way”:
                      http://www.bodhilinux.com/w/changing-plymouth-bootsplash/
                        schlachtkreuzer6 @nobita
                        @nobita yeah just change that image to another image (in the standard plymoth directory) and you are fine. i did that like this, before MM v2.1 with the splash screen was released, because that wohle plymouth stuff did not work for me. and there just few comandlines and worked perfectly!
                          bachoo786 @schlachtkreuzer6
                          @schlachtkreuzer6 how do you change the image? In which folder is the image?
                            sdetweil @bachoo786
                            @bachoo786 >In which folder is the image?
                            /usr/share/plymouth/themes
                            this shows the list of available
                             plymouth-set-default-theme --list
                            this resets to default
                            plymouth-set-default-theme --reset
                            see the installer code (and the install.log, as install changed the splash screen image)
