    MMM-CalendarExt3
    687 Posts 82 Posters 2.8m Views 86 Watching
    • K Offline
      KD @sdetweil
      @sdetweil Thank you Sam, i tried that and still nothing…
      Here is my config now:
        module: "MMM-CalendarExt3",
        position: "bottom_center",
          mode: "month",
          instanceId: "basicCalendar",
          locale: 'en-UK',
      	fontSize: '25px',
      	refreshInterval: 10000,
          maxEventLines: 10,
          firstDayOfWeek: 1,
          calendarSet: ["KD", "Tini"],
          broadcastPastEvents: true,
          maximumEntries: 100,
      			className: "KD",
      			url: "https://calendar.google.com/calendar/ical/basic.ics",
      			color: "green"
      			className: "tini",
      			color: "pink"
        sdetweil @KD
        @KD for the short term add
        position: “top_left”,
        to the calendar module location
        let’s make sure it is working
        • K Offline
          KD @sdetweil
          @sdetweil Thanks Sam - I now get Loading… than “error in the calendar module check log for more details” and finally no upcoming events… not sure how I have broken it as it was working yesterday… i also tried to replace the default calendar with
          git checkout modules/default/calendar/calendar.js
          As per one of your other posts in the forum but got "updated 0 (zero) paths from the index…
            sdetweil @KD
            @KD u have to be I the MagicMirror folder for the git checkout to work
            you should not have changed that file anyhow
            all config is done thru config.js
            can u show the output where u start mm?
            either npm start
            or if you use pm2, then
            pm2 logs --lines=50
            calendarext3, gets it’s info from the default calendar. so if it has problems, then u get nothing
            • K Offline
              KD @sdetweil
              @sdetweil here is an output from “npm start”
              kd@raspberrypi:~/MagicMirror $ npm start
              > magicmirror@2.20.0 start
              [11.09.2022 14:00.12.728] [LOG]   Starting MagicMirror: v2.20.0
              [11.09.2022 14:00.12.736] [LOG]   Loading config ...
              [11.09.2022 14:00.12.743] [LOG]   Loading module helpers ...
              [11.09.2022 14:00.12.745] [LOG]   No helper found for module: clock.
              [11.09.2022 14:00.12.747] [LOG]   No helper found for module: MMM-CalendarExt3.
              [11.09.2022 14:00.13.011] [LOG]   Initializing new module helper ...
              [11.09.2022 14:00.13.012] [LOG]   Module helper loaded: calendar
              [11.09.2022 14:00.13.013] [LOG]   No helper found for module: weather.
              [11.09.2022 14:00.13.554] [LOG]   Initializing new module helper ...
              [11.09.2022 14:00.13.556] [LOG]   Module helper loaded: MMM-BackgroundSlideshow
              [11.09.2022 14:00.13.558] [LOG]   All module helpers loaded.
              [11.09.2022 14:00.13.725] [LOG]   Starting server on port 8080 ...
              [11.09.2022 14:00.13.745] [LOG]   Server started ...
              [11.09.2022 14:00.13.747] [LOG]   Connecting socket for: calendar
              [11.09.2022 14:00.13.748] [LOG]   Starting node helper for: calendar
              [11.09.2022 14:00.13.749] [LOG]   Connecting socket for: MMM-BackgroundSlideshow
              [11.09.2022 14:00.13.750] [LOG]   Sockets connected & modules started ...
              [11.09.2022 14:00.14.038] [ERROR] Whoops! There was an uncaught exception...
              [11.09.2022 14:00.14.046] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                  at Server.setupListenHandle [as _listen2] (node:net:1372:16)
                  at listenInCluster (node:net:1420:12)
                  at GetAddrInfoReqWrap.doListen [as callback] (node:net:1559:7)
                  at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:73:8) {
                code: 'EADDRINUSE',
                errno: -98,
                syscall: 'listen',
                address: '127.0.0.1',
                port: 8080
              [11.09.2022 14:00.14.048] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [11.09.2022 14:00.14.052] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              [11.09.2022 14:00.14.099] [LOG]   Launching application.
              MESA-LOADER: failed to retrieve device information
              MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
              failed to load driver: kms_swrast
              MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
              failed to load swrast driver
              [11.09.2022 14:00.17.129] [LOG]   Shutting down server...
              [11.09.2022 14:00.17.136] [LOG]   Stopping module helper: calendar
              [11.09.2022 14:00.17.137] [LOG]   Stopping module helper: MMM-BackgroundSlideshow
                sdetweil @KD
                @KD yep, two copies running
                pm2 stop all
                then u can do npm start
                • K Offline
                  KD @sdetweil
                  @sdetweil Apologies yes i had a PM2 job in the background…
                  Here is the fresh output:
                  [11.09.2022 14:07.14.079] [LOG]   Starting MagicMirror: v2.20.0
                  [11.09.2022 14:07.14.088] [LOG]   Loading config ...
                  [11.09.2022 14:07.14.094] [LOG]   Loading module helpers ...
                  [11.09.2022 14:07.14.097] [LOG]   No helper found for module: clock.
                  [11.09.2022 14:07.14.099] [LOG]   No helper found for module: MMM-CalendarExt3.
                  [11.09.2022 14:07.14.368] [LOG]   Initializing new module helper ...
                  [11.09.2022 14:07.14.370] [LOG]   Module helper loaded: calendar
                  [11.09.2022 14:07.14.371] [LOG]   No helper found for module: weather.
                  [11.09.2022 14:07.14.976] [LOG]   Initializing new module helper ...
                  [11.09.2022 14:07.14.978] [LOG]   Module helper loaded: MMM-BackgroundSlideshow
                  [11.09.2022 14:07.14.979] [LOG]   All module helpers loaded.
                  [11.09.2022 14:07.15.149] [LOG]   Starting server on port 8080 ...
                  [11.09.2022 14:07.15.168] [LOG]   Server started ...
                  [11.09.2022 14:07.15.170] [LOG]   Connecting socket for: calendar
                  [11.09.2022 14:07.15.172] [LOG]   Starting node helper for: calendar
                  [11.09.2022 14:07.15.173] [LOG]   Connecting socket for: MMM-BackgroundSlideshow
                  [11.09.2022 14:07.15.174] [LOG]   Sockets connected & modules started ...
                  [11.09.2022 14:07.15.516] [LOG]   Launching application.
                  [11.09.2022 14:07.19.711] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ - Interval: 300000
                  [11.09.2022 14:07.19.985] [INFO]  BACKGROUNDSLIDESHOW: Reading directory "modules/MMM-BackgroundSlideshow/exampleImages/" for images.
                  [11.09.2022 14:07.20.006] [INFO]  BACKGROUNDSLIDESHOW: 171 files found
                  [11.09.2022 14:07.20.057] [INFO]  BACKGROUNDSLIDESHOW_NEXT_IMAGE
                  [11.09.2022 14:07.20.058] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/exampleImages//DSC_0038.JPG"
                  [11.09.2022 14:07.20.493] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                  [11.09.2022 14:07.29.492] [LOG]   Shutting down server...
                  [11.09.2022 14:07.29.493] [LOG]   Stopping module helper: calendar
                  [11.09.2022 14:07.29.494] [LOG]   Stopping module helper: MMM-BackgroundSlideshow
                    sdetweil @KD
                    @KD said in MMM-CalendarExt3:
                    so, the calendar module didnt find any events…
                    if you download the ICS file and look inside,
                    see the BEGIN VCALENDAR
                    BEGIN VEVENT
                    END VEVENT
                    END VCALENDAR
                    we can turn on debug to get more detail
                    change the config.js
                    	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                    to
                    	logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
                    then start mm with
                    npm start >somefile.txt
                    wait til the cal message comes up
                    then
                    ctrl-c (in the terminal window where u did npm start, or ctrl-q (if u didn’t start with pm2, as pm2’s JOB is to keep MM running, so it will restart it after it shuts down unexpectedly
                    • K Offline
                      KD @sdetweil
                      @sdetweil Added “Debug” to the config, and ran the npm start with the log file and waited for the calendar to say it was not able to find events - here is the output of the somefile.txt :
                      [11.09.2022 14:20.39.366] [LOG]   Starting MagicMirror: v2.20.0
                      [11.09.2022 14:20.39.373] [LOG]   Loading config ...
                      [11.09.2022 14:20.39.380] [LOG]   Loading module helpers ...
                      [11.09.2022 14:20.39.383] [LOG]   No helper found for module: clock.
                      [11.09.2022 14:20.39.384] [LOG]   No helper found for module: MMM-CalendarExt3.
                      [11.09.2022 14:20.39.628] [LOG]   Initializing new module helper ...
                      [11.09.2022 14:20.39.629] [LOG]   Module helper loaded: calendar
                      [11.09.2022 14:20.39.631] [LOG]   No helper found for module: weather.
                      [11.09.2022 14:20.40.066] [LOG]   Initializing new module helper ...
                      [11.09.2022 14:20.40.081] [LOG]   Module helper loaded: MMM-BackgroundSlideshow
                      [11.09.2022 14:20.40.082] [LOG]   All module helpers loaded.
                      [11.09.2022 14:20.40.206] [LOG]   Starting server on port 8080 ...
                      [11.09.2022 14:20.40.224] [LOG]   Server started ...
                      [11.09.2022 14:20.40.226] [LOG]   Connecting socket for: calendar
                      [11.09.2022 14:20.40.228] [LOG]   Starting node helper for: calendar
                      [11.09.2022 14:20.40.229] [LOG]   Connecting socket for: MMM-BackgroundSlideshow
                      [11.09.2022 14:20.40.230] [LOG]   Sockets connected & modules started ...
                      [11.09.2022 14:20.40.667] [LOG]   Launching application.
                      [11.09.2022 14:20.44.986] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/embed?src=konstantin.denishev%40gmail.com&ctz=Europe%2FLondon - Interval: 300000
                      [11.09.2022 14:20.45.260] [INFO]  BACKGROUNDSLIDESHOW: Reading directory "modules/MMM-BackgroundSlideshow/exampleImages/" for images.
                      [11.09.2022 14:20.45.273] [INFO]  BACKGROUNDSLIDESHOW: 171 files found
                      [11.09.2022 14:20.45.315] [INFO]  BACKGROUNDSLIDESHOW_NEXT_IMAGE
                      [11.09.2022 14:20.45.317] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/exampleImages//20161126_135734.jpg"
                      [11.09.2022 14:20.46.043] [DEBUG] parsed data={"value":"void 0}})},f=function(){var g={};return g.v=g.next=g.head=g},h=0;return c});var ea=function(a,b){a instanceof String&&(a+=);var c=0,d=!1,e={next:function(){if(!d&&c<a.length){var f=c++;return{value:b(f,a[f]),done:!1}}d=!0;return{done:!0,value:void 0}}};e[Symbol.iterator]=function(){return e};return e};p(Array.prototype.entries,function(a){return a?a:function(){return ea(this,function(b,c){return[b,c]})}});p(Array.prototype.keys,function(a){return a?a:function(){return ea(this,function(b){return b})}});","spdx-license-identifier":[" Apache-2.0"," Apache-2.0"],"e":")};M.prototype.get=function(a,b){for(var c=a+=,d=(this.g.cookie||).split(;),e=0,f;e<d.length;e++){f=H(d[e]);if(0==f.lastIndexOf(c,0))return f.slice(c.length);if(f==a)return}return b};M.prototype.o=function(){for(var a=(this.g.cookie||).split(;),b=[],c=[],d,e,f=0;f<a.length;f++)e=H(a[f]),d=e.indexOf(=),-1==d?(b.push(),c.push(e)):(b.push(e.substring(0,d)),c.push(e.substring(d+1)));return c};var Pa=new M;var Qa=function(){this.H=this.H;this.g=this.g};Qa.prototype.H=!1;Qa.prototype.G=function(){if(this.g)for(;this.g.length;)this.g.shift()()};var N=function(a,b){this.type=a;this.g=this.target=b;this.defaultPrevented=!1};N.prototype.h=function(){this.defaultPrevented=!0};var Ra=function(){if(!t.addEventListener||!Object.defineProperty)return!1;var a=!1,b=Object.defineProperty({},passive,{get:function(){a=!0}});try{t.addEventListener(test,function(){},b),t.removeEventListener(test,function(){},b)}catch(c){}return a}();var Sa=function(a){Sa[ ](a);return a};Sa[ ]=function(){};var Ua=function(a){var b=Ta;return Object.prototype.hasOwnProperty.call(b,9)?b[9]:b[9]=a(9)};var Va=K(Opera),Wa=K(Trident)||K(MSIE),Xa=K(Edge),Ya=K(Gecko)&&!(-1!=J().toLowerCase().indexOf(webkit)&&!K(Edge))&&!(K(Trident)||K(MSIE))&&!K(Edge),Za=-1!=J().toLowerCase().indexOf(webkit)&&!K(Edge),$a;","a":"{var ab=,bb=function(){var a=J();if(Ya)return/rv:([^\\);]+)(\\)|;)/.exec(a);if(Xa)return/Edge\\/([\\d\\.]+)/.exec(a);if(Wa)return/\\b(?:MSIE|rv)[: ]([^\\);]+)(\\)|;)/.exec(a);if(Za)return/WebKit\\/(\\S+)/.exec(a);if(Va)return/(?:Version)[ \\/]?(\\S+)/.exec(a)}();bb&&(ab=bb?bb[1]:);if(Wa){var cb,db=t.document;cb=db?db.documentMode:void 0;if(null!=cb&&cb>parseFloat(ab)){$a=String(cb);break a}}$a=ab}","array":"e:null)),e=type_error:SafeUrl;else{b:if(na){try{e=new URL(d)}catch(k){e=https:;break b}e=e.protocol}else c:{e=document.createElement(a);try{e.href=d}catch(k){e=void 0;break c}e=e.protocol;e=:===e||===e?https::e}javascript:===e?(oa(d),e=void 0):e=d}void 0!==e&&(b.href=e)}})};var Q=Object.create(null);function R(a,b){Q[a]||(Q[a]=b)};var S=function(){w.apply(this,arguments)};u(S,w);S.prototype.h=function(){var a=this.g.querySelector(#playCaptchaButton),b=this.g.querySelector(#captchaAudio),c=this.g.querySelector(input[name=ca]);a&&b&&c&&a.addEventListener(click,function(d){d.preventDefault();b.readyState===HTMLMediaElement.HAVE_NOTHING?b.load():b.paused&&b.play();c.value=;c.focus()})};var T=function(){w.apply(this,arguments)};u(T,w);T.prototype.h=function(){var a=this.g;void 0!==a.dataset.hasDomainSuffix&&(sa(a),ta(a))};var ta=function(a){a.addEventListener(keyup,function(){sa(a)})},sa=function(a){0<a.getElementsByTagName(INPUT.toString()).item(0).value.indexOf(@)?a.dataset.hasAtSign=:delete a.dataset.hasAtSign};var U=function(){w.apply(this,arguments)};u(U,w);U.prototype.h=function(){var a=this.g;void 0!==a.dataset.hasDomainSuffix&&(ua(a),va(a))};var va=function(a){a.addEventListener(keyup,function(){ua(a)})},ua=function(a){0<a.getElementsByTagName(INPUT.toString()).item(0).value.indexOf(@)?a.dataset.hasAtSign=:delete a.dataset.hasAtSign};R(CaptchaInput,S);R(Card,A);R(EmailInput,T);R(Footer,P);R(IdentifierInput,U);var wa=[],V,W=[].slice.call(document.querySelectorAll([data-auto-init])),xa=undefined!=typeof Symbol&&Symbol.iterator&&W[Symbol.iterator],X;xa?X=xa.call(W):X={next:h(W)};V=X;for(var Y=V.next();!Y.done;Y=V.next()){var Z=Y.value,ya=Z.getAttribute(data-auto-init);if(!ya)throw Error(auto-init attribute requires a value.);var za=new Q[ya](Z);wa.push(za);Z.removeAttribute(data-auto-init)};}).call(this);"}
                      [11.09.2022 14:20.46.045] [DEBUG] There are 5 calendar entries.
                      [11.09.2022 14:20.46.048] [DEBUG] Processing entry...
                      [11.09.2022 14:20.46.053] [DEBUG] Processing entry...
                      [11.09.2022 14:20.46.055] [DEBUG] Processing entry...
                      [11.09.2022 14:20.46.057] [DEBUG] Processing entry...
                      [11.09.2022 14:20.46.058] [DEBUG] Processing entry...
                      [11.09.2022 14:20.46.061] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                      This is the output from the terminal @almightyyoshi
                      kd@raspberrypi:~/MagicMirror $ npm start >somefile.txt
                      There is definitely events in the calendar…
                        sdetweil @KD
                        @KD wrong link… u used the embed link (make the full calendar SHOW in the client,…)
                        we want the ICal link
                        • 10
                        • 11
                        • 12
                        • 13
                        • 14
                        • 68
                        • 69
                        • 12 / 69
