    MMM-CalendarExt3
    678 Posts 82 Posters 2.7m Views 86 Watching
      MMRIZE
      1.1.0 (2022-05-29)
      • ADDED : control interval of refreshing on fetching calendar
        • config option waitFetch for waiting for too frequent fetching.
        • config option refreshInterval for refresh view by force.
        • config option glanceTime for focusing temporal moment then returning to current moment
        • config option animationSpeed for update animation
      • ADDED : calendar symbol can be used. (config option useSymbole)
      • ADDED : weather forecast could be displayable. (From MM 2.20 released or MM 2.19 develop branch)
      • CHANGED : Now, month view could has a fit weeks by the days not fixed 6 weeks.
      1.1.0
        almightyyoshi
        Just a couple of quick questions. First, how do you remove icons from events? I see in the sample pics that it’s been done, but I can’t seem to make it happen. Second, in CalExt2, I could style event borders and would show/color those instead of having a completely filled in event color. I could also show only certain borders (for full day I only had the left and bottom, but single day events only had the left border). Is that possible with CalExt3?
          MMRIZE @almightyyoshi
          @almightyyoshi
          1. Not to use symbol: useSymbol: false
          // config of your module;
            useSymbol: false,
          1. Is this what you wanted?
          /* in your custom.css */
          .CX3 .event.fullday,
          .CX3 .event.multiday {
            border-left: 4px solid var(--calendarColor);
            border-bottom: 1px solid var(--calendarColor);
            background-color: rgba(0, 0, 0, 0.2);
          .CX3 .event.singleday {
            border-left:4px solid var(--calendarColor);
          .CX3 .event.singleday:not(.useSymbol)::before {
            content: '';
            almightyyoshi @MMRIZE
            @MMRIZE That’s perfect. Thanks. I just wasn’t sure if those attributes were available and I honestly just didn’t feel like experimenting at that moment. Last question (think): Is there a way to hide the default calendar module and still populate CX3. I found a way to hide the module (by editing the calendar module’s base config) on startup, but then CX3 doesn’t have any events. Here’s what I used (courtesy of @sdetweil from a thread a couple of years ago):
            hidden: false,
            suspend: function(){
                this.hidden=true
            restore: function(){
                 this.hidden=false
            notificationReceived: function(notification, payload, source){
               // this comes before the first call to getDom()
               if(notification === "ALL_MODULES_STARTED")
                  this.hidden=true;
            getDom: function (){
            var wrapper=document.createElement('div')
            if(this.hidden==false){
                 //create normal content
            return wrapper;
              sdetweil @almightyyoshi
              @almightyyoshi I think you will have to use css to hide, vs code
                @almightyyoshi
                You can hide it with CSS, or just drop out “position”.
                  @MMRIZE Dropping position worked. I thought I’d get an error or blank screen for that. Thanks again!
                  luisestradaL 1 Reply Last reply Reply Quote 0
                  • luisestradaL Offline
                    luisestrada @almightyyoshi
                    @almightyyoshi Every time i think this is fixed then it comes back again…
                    I have 3 calendars so I renamed calendar1 and calendar2, as I don’t want these calendars to conflict with CX3.
                    Then I have my calendar module and dropped the position as I don’t want to show it.
                    My CX3 loads empty and after a while the information appears, then it goes and then it comes back. I think I have not set up properly the refresh. I’ve tried many combinations but nothing works
                    module: “MMM-CalendarExt3”,
                    position: “bottom_bar”,
                    title: “Calendario”,
                    waitFetch: 10000, // (ms) waiting the fetching of last calendar to prevent flickering view by too frequent fetching.
                    refreshInterval: 1000 * 60 * 1, // (ms) refresh view by force if you need it.
                    glanceTime: 1000 * 60 * 1, // (ms) Return to original view when you move to other moment by notification.
                    //animationSpeed: 2000, // (ms) Refreshing the view smoothly.
                    rotateInterval: 0,
                    eventTimeOptions: {
                    timeStyle: “short”
                    fetchInterval: 1000,
                    mode: “week”,
                    instanceId: “WeeklyCalendar”,
                    locale: ‘es-CO’,
                    maxEventLines: 3,
                    firstDayOfWeek: 0,
                    weekIndex: 0,
                    weeksInView: 4,
                    broadcastPastEvents: true, // <= IMPORTANT to see past events
                    calendarSet: [‘Cal1’, ‘Cal2’, ‘Cal3’, 'Cal4, ‘Cal5’],
                    And Go Jays Go!! :beaming_face_with_smiling_eyes:
                      sdetweil @luisestrada
                      @luisestrada do you have 3 instances of
                      module:‘calendar’
                        luisestrada @sdetweil
                        @sdetweil said in MMM-CalendarExt3:
                        module:‘calendar’
                        Yes, I have 3 modules, the holidays (shows 3), the birthday calendar (shows 2) and the normal calendar (shows 8).
                        • 67
                        • 68
                        • 3 / 68
