    How hot does your mirror run?
    29 Posts 8 Posters 24.2k Views 8 Watching
    • hartattackH Offline
      hartattack @Mykle1
      @Mykle1 said in How hot does your mirror run?:
      @hartattack
      I wanted to add a fan from the very beginning although all searches say that the Pi can run without problems up to 80°C or more. That “seemed” hot to me. My Pi was running at 60°C, which is well under the maximum that I discovered. So, I took it upon myself to add a 12v fan (I have spare parts lying around) and connected it to a 5V pin and a GRD pin on the GPIO header. I’ve been running the mirror more than a month without a hitch and my CPU temp is nearly 20°C cooler. Fans are cheap. If you can salvage one, even better. The result is pretty dramatic. Have a look.
      I started with a fan and 3 heatsinks from the beginning. Mine runs around 45C and gets close to 50C when doing anything intensive.
        Mykle1 Project Sponsor Module Developer @hartattack
        @hartattack said in How hot does your mirror run?:
        Yes, I started with the heatsinks that came in the Pi kit that I bought. There’s just no reason NOT to add a fan, in my case anyway. Besides, the cool factor (pun) of having a fan that’s half the size of the Pi sitting right on top. A 12v fan re-purposed from an old Mac G5 power supply connected to a 5v Pi pin. Come on, that’s cool! :-)
          Advokaten @Mykle1
          @Mykle1 would any heatsink do on a rpi? I saw one guy who brought the extreme and planted one that was bigger than the Pi itself, lol. He got it down to about 20 Celsius.
            Mykle1 Project Sponsor Module Developer @Advokaten
            @Advokaten said in How hot does your mirror run?:
            I don’t see why not. If it cools the Pi and it doesn’t harm it in any way then it’s good, I guess. Do you have a picture of that extreme heatsink you mentioned? I’m curious to see it.
            hartattackH 1 Reply Last reply Reply Quote 0
              hartattack @Mykle1
                I saw this one not too long ago!
                That’s hot! I mean cool! You know what I mean. ;-)
                • C Offline
                  chieftainSupreme
                  @wered doing the manual install and i’m getting this error after running tempcontrol config, after connecting to the repo: “tempcontrol.conf.sample: Permission denied. Cannot write to tempcontrol.conf.sample (Permission denied)”
                  Any advice? Thanks in advance
                  edit: fixed it by granting rwx access to the files. Having an issue with the display not turning off during the right hours though. My tempcontrol.conf looks like:
                  onhour= “08 09”
                  parttime= “true”
                  partial1 = “”
                  partial2 = “”
                  partial01 = “”
                  partial02 = “”
                    Advokaten @Mykle1
                    @Mykle1 https://youtu.be/1AYGnw6MwFM check this out!
                    • Y Offline
                      yawns Moderator
                      Do you actually hear the fan? I’m afraid it is disturbing even though it might only be whispering
