    Update fail
    28 Posts 4 Posters 10.7k Views 4 Watching
    • JerryPJ Offline
      JerryP @sdetweil
      @sdetweil said in
      That’s oke now. Ctrl- on keyboard to zoom out
      But look the camera postion.
      Normal it was lower
      		module: "MMM-RTSPStream",
      		disabled: false, //false, true
      		position: "upper_third",  // "middle_center" "upper_third"
      			autoStart: true,
      			rotateStreams: false,
      			rotateStreamTimeout: 20,
      			moduleWidth: 720,
      			moduleHeight: 420,
      			localPlayer: "omxplayer", // "omxplayer" or "ffmpeg", or "vlc"
      			remotePlayer: 'none',
      			showSnapWhenPaused: false,
      			remoteSnaps: false,
      			  stream1: {***************
      I put in the upper_third… But when I put in the middel_center i’ts at the bottom.
      So how can I lower the 4 camera feeds???
      Than the mirror is 100% back again.
      Thanks for the help so fare
        sdetweil @JerryP
        @JerryP I don’t know for sure, did u have a custom.css that moved the position?
        JerryPJ 3 Replies Last reply Reply Quote 0
        • JerryPJ Offline
          JerryP @sdetweil
          @sdetweil said in Update fail:
          MMM-RTSPStream .innerWrapper {
              border-style: none;
          .MMM-SystemStats table {
                  width: 350px;
                  color: #666;
                  font-size: 20px;
          .MMM-SystemStats td {
              line-height: 20px;
          .MMM-clock table {
                  width: 450px;
                  color: #666;
                  font-size: 20px;
          .MMM-MercedesMe #mercedesMain {
                  zoom: 0.4;
          .MMM-Formula1 .module-header {
          display:none !important;
          .MMM-MercedesMe .module-header {
          .MMM-NetworkScanner .module-header {
          .MMM-VolvoOnCall .module-header {
          .MMM-Spotify .SPOTIFY_BACKGROUND {
          border-style: none;
           zoom: 80%;
          .MMM-MyVolvo .VOC .graphic {
                  width: 50%;
                  margin-right: 1px;
                  margin-left: 10px;
                  margin-top:  -4px;
                  float: right;
          Yes but not for the RTSP-stream
          • JerryPJ Offline
            JerryP @sdetweil
            in your script (new mirror setup)
            makes the scrip a new config.js.
            In that files stands
            locale: "en-US",
            Where can I find the info for Netherland???
              sdetweil @JerryP
              @JerryP I just copy the config.js.sample
              but language/locale codes are public
              https://www.science.co.il/language/Locale-codes.php
              JerryPJ 1 Reply Last reply Reply Quote 0
              • JerryPJ Offline
                JerryP @sdetweil
                yes “nl-nl” that’s a check
                • JerryPJ Offline
                  JerryP @sdetweil
                  Yes see the custom.css above
                  • T Offline
                    torte22
                    after updating my MM installation I had also an electron problem and MM didn’t start. This topic works for my fine and fixed my installation:
                    https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more?page=1
