    MMM-OpenWeatherMapForecast stuck on Loading....
    63 Posts 16 Posters 49.5k Views 18 Watching
      sdetweil @ally
      @ally those errors are from the default weather module…
      i think you should disable them while we work this
      add
      disabled: true,
      after the module:“weather”,
      lines
        ally @sdetweil
        @sdetweil No errors being reported, but no change in the modules behavior.
        			module: "weather",
        			disabled: true,
        				type: "current",
        				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        				apiKey: "XXXXXXXXXXX"
        			module: "weather",
        			disabled: true,
        			header: "Weather Forecast",
        				type: "forecast",
        			module: "MMM-OpenWeatherMapForecast",
        			header: "Weather",
        			classes: "default everyone",
        			disabled: false,
        				apikey: "XXXXXXXXXXX",
        				latitude: "51.506130",
        				longitude: "-0.090270",
          sdetweil @ally
          @ally I need the messages from the terminal window or pm2 logs
          do
          pm2 flush
          pm2 restart 0
          wait
          pm2 logs --lines=80 >somefile.txt 2>&1
          ctrl-c
          then examine somefile.txt
            ally @sdetweil
            @sdetweil unfortunately the same useful answer
            /home/pi/.pm2/logs/MagicMirror-out.log last 80 lines:
            0|MagicMir |
            0|MagicMir | > magicmirror@2.20.0 start
            0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
            0|MagicMir |
            0|MagicMir | [28.08.2022 20:52.28.785] [LOG]   Starting MagicMirror: v2.20.0
            0|MagicMir | [28.08.2022 20:52.28.793] [LOG]   Loading config ...
            0|MagicMir | [28.08.2022 20:52.28.800] [LOG]   Loading module helpers ...
            0|MagicMir | [28.08.2022 20:52.28.803] [LOG]   No helper found for module: alert.
            0|MagicMir | [28.08.2022 20:52.28.823] [LOG]   Initializing new module helper ...
            0|MagicMir | [28.08.2022 20:52.28.825] [LOG]   Module helper loaded: updatenotification
            0|MagicMir | [28.08.2022 20:52.28.826] [LOG]   No helper found for module: clock.
            0|MagicMir | [28.08.2022 20:52.29.043] [LOG]   Initializing new module helper ...
            0|MagicMir | [28.08.2022 20:52.29.044] [LOG]   Module helper loaded: calendar
            0|MagicMir | [28.08.2022 20:52.29.046] [LOG]   No helper found for module: compliments.
            0|MagicMir | [28.08.2022 20:52.29.097] [LOG]   Initializing new module helper ...
            0|MagicMir | [28.08.2022 20:52.29.098] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
            0|MagicMir | [28.08.2022 20:52.29.129] [LOG]   Initializing new module helper ...
            0|MagicMir | [28.08.2022 20:52.29.131] [LOG]   Module helper loaded: newsfeed
            0|MagicMir | [28.08.2022 20:52.29.132] [LOG]   All module helpers loaded.
            0|MagicMir | [28.08.2022 20:52.29.246] [LOG]   Starting server on port 8080 ...
            0|MagicMir | [28.08.2022 20:52.29.264] [LOG]   Server started ...
            0|MagicMir | [28.08.2022 20:52.29.265] [LOG]   Connecting socket for: updatenotification
            0|MagicMir | [28.08.2022 20:52.29.267] [LOG]   Starting module helper: updatenotification
            0|MagicMir | [28.08.2022 20:52.29.268] [LOG]   Connecting socket for: calendar
            0|MagicMir | [28.08.2022 20:52.29.268] [LOG]   Starting node helper for: calendar
            0|MagicMir | [28.08.2022 20:52.29.269] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
            0|MagicMir | [28.08.2022 20:52.29.270] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast]
            0|MagicMir | [28.08.2022 20:52.29.271] [LOG]   Connecting socket for: newsfeed
            0|MagicMir | [28.08.2022 20:52.29.271] [LOG]   Starting node helper for: newsfeed
            0|MagicMir | [28.08.2022 20:52.29.272] [LOG]   Sockets connected & modules started ...
            0|MagicMir | [28.08.2022 20:52.29.554] [LOG]   Launching application.
            0|MagicMir | [28.08.2022 20:52.32.673] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
            0|MagicMir | [28.08.2022 20:52.33.281] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
            0|MagicMir | [28.08.2022 20:52.33.308] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
            0|MagicMir | [28.08.2022 20:52.33.374] [INFO]  Checking git for module: default
            0|MagicMir | [28.08.2022 20:52.33.661] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
            0|MagicMir | [28.08.2022 20:52.33.981] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
            0|MagicMir | [28.08.2022 20:52.34.387] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 20:52 ** ERROR ** null
              sdetweil @ally
              @ally there is another section of the output…where the error was reported last time
              home/pi/.pm2/logs/MagicMirror-error.log
                ally @sdetweil
                @sdetweil same error
                28.08.2022 21:10.34.377] [LOG]   Starting MagicMirror: v2.20.0
                [28.08.2022 21:10.34.385] [LOG]   Loading config ...
                [28.08.2022 21:10.34.394] [LOG]   Loading module helpers ...
                [28.08.2022 21:10.34.399] [LOG]   No helper found for module: alert.
                [28.08.2022 21:10.34.419] [LOG]   Initializing new module helper ...
                [28.08.2022 21:10.34.420] [LOG]   Module helper loaded: updatenotification
                [28.08.2022 21:10.34.422] [LOG]   No helper found for module: clock.
                [28.08.2022 21:10.34.635] [LOG]   Initializing new module helper ...
                [28.08.2022 21:10.34.638] [LOG]   Module helper loaded: calendar
                [28.08.2022 21:10.34.640] [LOG]   No helper found for module: compliments.
                [28.08.2022 21:10.34.689] [LOG]   Initializing new module helper ...
                [28.08.2022 21:10.34.692] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
                [28.08.2022 21:10.34.720] [LOG]   Initializing new module helper ...
                [28.08.2022 21:10.34.723] [LOG]   Module helper loaded: newsfeed
                [28.08.2022 21:10.34.724] [LOG]   All module helpers loaded.
                [28.08.2022 21:10.34.833] [LOG]   Starting server on port 8080 ...
                [28.08.2022 21:10.34.850] [LOG]   Server started ...
                [28.08.2022 21:10.34.853] [LOG]   Connecting socket for: updatenotification
                [28.08.2022 21:10.34.855] [LOG]   Starting module helper: updatenotification
                [28.08.2022 21:10.34.857] [LOG]   Connecting socket for: calendar
                [28.08.2022 21:10.34.859] [LOG]   Starting node helper for: calendar
                [28.08.2022 21:10.34.861] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
                [28.08.2022 21:10.34.863] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast]
                [28.08.2022 21:10.34.865] [LOG]   Connecting socket for: newsfeed
                [28.08.2022 21:10.34.867] [LOG]   Starting node helper for: newsfeed
                [28.08.2022 21:10.34.868] [LOG]   Sockets connected & modules started ...
                [28.08.2022 21:10.35.212] [LOG]   Launching application.
                [28.08.2022 21:10.38.502] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                [28.08.2022 21:10.38.552] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                [28.08.2022 21:10.38.603] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
                [28.08.2022 21:10.38.642] [INFO]  Checking git for module: default
                [28.08.2022 21:10.38.927] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                [28.08.2022 21:10.39.643] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 21:10 ** ERROR ** null
                [28.08.2022 21:10.39.896] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                [28.08.2022 21:15.39.424] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                [28.08.2022 21:15.41.132] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                [28.08.2022 21:20.39.237] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 21:20 ** ERROR ** null
                [28.08.2022 21:20.40.820] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                [28.08.2022 21:20.42.343] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                [28.08.2022 21:25.41.189] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                [28.08.2022 21:25.43.553] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                [28.08.2022 21:30.39.346] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 21:30 ** ERROR ** null
                [28.08.2022 21:30.41.369] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                [28.08.2022 21:30.44.877] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                [28.08.2022 21:35.41.533] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                [28.08.2022 21:35.46.150] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                [28.08.2022 21:40.39.257] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 21:40 ** ERROR ** null
                [28.08.2022 21:40.41.736] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                [28.08.2022 21:40.47.660] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                [28.08.2022 21:45.41.947] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                [28.08.2022 21:45.48.861] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                [28.08.2022 21:50.39.355] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 21:50 ** ERROR ** null
                [28.08.2022 21:50.42.128] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                [28.08.2022 21:50.50.284] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                [28.08.2022 21:55.42.480] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                [28.08.2022 21:55.51.610] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                [28.08.2022 22:00.39.318] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 22:00 ** ERROR ** null
                [28.08.2022 22:00.42.644] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                [28.08.2022 22:00.52.840] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                [28.08.2022 22:05.42.822] [INFO]  Newsfeed-Fetcher: Broadcasting 32 items.
                [28.08.2022 22:05.54.216] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                [28.08.2022 22:10.39.243] [LOG]   [MMM-OpenWeatherMapForecast] 28-Aug-22 22:10 ** ERROR ** null
                  sdetweil @ally
                  @ally did u add my new code?
                    bassin12
                    I’m having some hard time too, I cannot get it to work and get this error, I’m using the same key for the default weather module
                    [LOG] [MMM-OpenWeatherForecast] 29-Aug-22 07:50 ** ERROR ** Error: Request failed with status code 401
                    Not sure what I’m doing wrong.
                    module: “weather”,
                    position: “top_right”,
                    header: “Weather Forecast”,
                    weatherProvider: “openweathermap”,
                    type: “forecast”,
                    locationID: “4225309”,
                    apiKey: “working key”
                    module: “MMM-OpenWeatherForecast”,
                    header: “Wettervorschau Schama”,
                    apikey: “same key as above”, //SUPER SECRET
                    latitude: 49.039349,
                    longitude: 11.847070,
                    units: “metric”,
                    iconset: “4c”,
                    colored: true,
                    concise: true
                    S 3 Replies Last reply Reply Quote 0
                      sdetweil @bassin12
                      @bassin12 said in MMM-OpenWeatherMapForecast stuck on Loading....:
                      401
                      well, that is
                      http error 401 unauthorized
                      so, that looks like there is some error in your apiKey
                        sdetweil @bassin12
                        also, this is a different module than we are discussing
                          @bassin12 your config works perfectly with my apikey
                            sdetweil @bassin12
                            @bassin12 also, please enclose all config and code sections in a code block
                            copy paste the text into the new message
                            select the text
                            and the hit the button </> above the editor
                              bassin12
                              This is really funny, I downloaded the right module now, tested with my key, and now it is saying the key is invalid, this is the code I’m using
                                                     module: "weather",
                                                             type: "forecast",
                                                             locationID: "4225309",
                                                             apiKey: "Mykey"
                                               header: "Weather",
                                               disabled: false,
                                                 apiKey: "Mykey",
                                                 latitude: 51.506130,
                                                 longitude: -0.090270,
                                                 iconset: "4c",
                                                 concise: false,
                                                 forecastLayout: "table"
                              This is the error I get
                              [29.08.2022 09:07.47.834] [LOG] [MMM-OpenWeatherMapForecast] 29-Aug-22 09:07 ** ERROR ** No API key configured. Get an API key at https://openweathermap.org/api/one-call-api
                              I tried the Latitude and Longitude with and without quotes.
                                sdetweil @bassin12
                                @bassin12 this module uses all lowercase for the key name field
                                apikey:
                                this system is case sensitive
                                  bassin12
                                  I did the code change in node_helpe.js, and the system now reports this error
                                  [29.08.2022 10:34.06.199] [LOG] [MMM-OpenWeatherMapForecast] 29-Aug-22 10:34 ** bad status ** 401
                                  my full config.js is this:
                                  /* MagicMirror² Config Sample
                                   * By Michael Teeuw https://michaelteeuw.nl
                                   * MIT Licensed.
                                   * see https://docs.magicmirror.builders/configuration/introduction.html
                                   * and https://docs.magicmirror.builders/modules/configuration.html
                                  let config = {
                                  	address: "localhost", 	// Address to listen on, can be:
                                  	port: 8080,
                                  	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                  	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                                  	language: "en",
                                  	locale: "en-US",
                                  	timeFormat: 24,
                                  	units: "metric",
                                  			module: "weather",
                                  				type: "forecast",
                                  				apiKey: "45fe452eea1fcfe3589cd5e8aa3f3f93"
                                                          header: "Weather",
                                                          disabled: false,
        apikey: "45fe452eea1fcfe3589cd5e8aa3f3f93",
        iconset: "4c",
        concise: false,
                                  S 4 Replies Last reply Reply Quote 0
                                    sdetweil @bassin12
                                    @bassin12 yep… something…
                                    both work for me…
                                      sdetweil @bassin12
                                      @bassin12
                                      hm… I created a new key…
                                      seems OpenWeatherForecast has a bug
                                      in its node_helper.js
                                      change
                                                "&units=" + payload.units +
                                      to (same as openWeatherMapForecast
                                                          (payload.units !== "" ? "&units=" + payload.units : "") +
                                      can’t pass in junk
                                        sdetweil @bassin12
                                        @bassin12 if the apikey is valid, I get 401 as well…
                                        using my (new) apikey… all ok…
                                          sdetweil @bassin12
                                          @bassin12 with that api key data is coming back, but its in the wrong format
                                          i switch to my apikey and all is good
                                            ally @sdetweil
                                            @sdetweil I deleted the MMM-OpenWeatherMapForecast and reinstalled it as per the instructions. Results below, no change.
                                            /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
                                            0|MagicMir | [30.08.2022 18:29.44.705] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                            0|MagicMir | [30.08.2022 18:32.45.422] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                                            0|MagicMir | [30.08.2022 18:34.45.902] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                            0|MagicMir | [30.08.2022 18:37.19.673] [LOG]   [MMM-OpenWeatherMapForecast] 30-Aug-22 18:37 ** ERROR ** null
                                            0|MagicMir | [30.08.2022 18:37.45.605] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                                            0|MagicMir | [30.08.2022 18:39.47.120] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                            0|MagicMir | [30.08.2022 18:42.45.793] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                                            0|MagicMir | [30.08.2022 18:44.48.354] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                            0|MagicMir | [30.08.2022 18:47.19.775] [LOG]   [MMM-OpenWeatherMapForecast] 30-Aug-22 18:47 ** ERROR ** null
                                            0|MagicMir | [30.08.2022 18:47.45.968] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                                            0|MagicMir | [30.08.2022 18:49.49.561] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                            0|MagicMir | [30.08.2022 18:52.46.128] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                                            0|MagicMir | [30.08.2022 18:54.50.794] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                            0|MagicMir | [30.08.2022 18:57.19.667] [LOG]   [MMM-OpenWeatherMapForecast] 30-Aug-22 18:57 ** ERROR ** null
                                            0|MagicMir | [30.08.2022 18:57.46.299] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                                            0|MagicMir | [30.08.2022 18:59.52.001] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                            0|MagicMir | [30.08.2022 19:02.46.483] [INFO]  Newsfeed-Fetcher: Broadcasting 35 items.
                                            0|MagicMir | [30.08.2022 19:04.53.188] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                            Am I doing anything wrong?
                                            Ally
                                            • 2 / 4
