    MMM-OpenWeatherMapForecast stuck on Loading....
    63 Posts 16 Posters 54.7k Views 18 Watching
      bassin12
      I think I was able to get to the bottom of this, you need to subscribe to the API giving your credit card information, also API 2.5 is deprecated for new users, I entered in contact with Open Weather and they have sent me this information.
      Hope this helps people in the future.
        sdetweil @ally
        @ally what instructions?
        unless the author changed the code, nothing will change
          ally @bassin12
          @bassin12 said in MMM-OpenWeatherMapForecast stuck on Loading....:
          What service did you subscribe to, as that looks like the only way to enter your credit card info.
          Ally
          • E Offline
            elorand @ally
            Hey @ally, I recently ran into the same problem like you.
            I followed all instructions given to you from @sdetweil and finally figured out, what the problem was: openweathermap updated its api to version 3.0!
            Even if you have a free subscription (limiting to 1000 api-calls a day, which is fine unless you stay above a refreshrate of every 3 minutes), you need to edit the link in node_helper.js from
            var url = "https://api.openweathermap.org/data/2.5/onecall" +
            to
            var url = "https://api.openweathermap.org/data/3.0/onecall" +
            For the free subscription on API-Version 3.0, you need to provide your credit card information, but you can set the maximum of possible API-calls to 1000, so that you will never ever ran into any costs.
            S A L 3 Replies Last reply Reply Quote 1
              sdetweil @elorand
              @elorand the default weather module still uses 2.5 and it works
              • C Offline
                chief
                Just following up on this thread - I also am on the “free tier” 2.5 API version and when I try to use MMM-OpenWeatherForecast, it is stuck on “Loading”.
                Any advice?
                • E Offline
                  elorand @chief
                  @sdetweil I couldn’t choose the old 2.5 API when I registered as new user to OpenWeatherMap. Therefore I had no other chance than to go with the 3.0 API.
                  @chief depending on the API you are subscribed to, you need to edit the node_helper.js (as mentioned in my previous post). After editing you should restart your magicmirror.
                  • karsten13K Online
                    karsten13 @sdetweil
                    at the moment, yes.
                    I looked into their api stuff and onecall v2.5 is not mentioned anymore. The normal endpoints weather and forecast are still on v2.5.
                    Problem: For onecall 3.0 you need a special api key (as already mentioned here) with a subsciption where you have to give your payment data (1000 request free per day, limit is 2000 per day but you can set your limit to 1000 if you want it for free … ).
                    I think we will get problems/questions to this for the default weather module too.
                    So (for default weather module) if you use endpoints weather and forecast and old onecall v2.5 everthing works out of the box with old api keys, if someone use new onecall v3.0 he needs an api key for 3.0 and has to set apiVersion: "3.0", in the config …
                    • L Offline
                      LemonBrain @ally
                      @ally
                      Hi!
                      There was an error “** ERROR ** Error: socket hang up”
                      This solution helped:
                      in the module node_helper.js
                      replace with
                      var url = "http://api.openweathermap.org/data/2.5/onecall" +
                      (https -> http)
                      and restart the MM2
                      • Y Offline
                        yk
                        Was there an agreed solution to this one? Do we need to subscribe separately to the 3.0 API or does the free subscription doable (works with default weather module)?
                        • L Offline
                          LemonBrain @yk
                          @yk
                          Hello!
                          I use a free subscription. This subscription apparently has a problem with https protocol. Found out by randomly studying the weather server’s response in the browser.
                            anhanyoung @elorand
                            @elorand Hey man, I know this was a little while ago but I’m struggling with this atm. I subscribed to 3.0 but when I look at my services tab, it’s still showing the free version. When I create an API, it doesn’t seem to work even with editing the node helper to the url you posted. Is there a specific way to generate an API from them with 3.0?
                              sdetweil @anhanyoung
                              @anhanyoung try my version. I fixed a loading bug a while back
                              https://github.com/sdetweil/MMM-OpenWeatherMapForecast
                                @anhanyoung I see your key is 3.0, but the code uses 2.5.
                                module needs a new parameter to allow selecting which api group it’s in and use that when constructing the url
                                • L Offline
                                  Latch @elorand
                                  @elorand
                                  This worked for me. Great work!
                                  • T Offline
                                    Tomcat1977 @LemonBrain
                                    @LemonBrain This is the solution! Thanks! No API 3.0, no apiversions. THIS IS IT! Thank you very much! It took me a week to find this!
                                      schris88
                                      I just got it working after struggling with it myself for quite a while. Currently, only the 3.0 API is available for onecall, while forecast, etc., still uses version 2.5. That’s why the default weather with forecast is still functioning.
                                      For the MMM-OpenWeatherMapForecast module, you need to subscribe to the onecall 3.0 API, which is now part of a paid subscription. However, 1000 per month remain free, and you can specify the number of API calls per day allowed in your subscription.
                                      In the node_helper.js file of the modules, I updated the API endpoint to the specified 3.0 API from the OpenWeather API: “https://api.openweathermap.org/data/3.0/onecall”.
                                      Hint: The activation of the API may take a few minutes. You can check its status by calling the API in a browser. If you haven’t subscribed yet, the error message will indicate “invalid API key.” While it’s getting activated, it will display “bla bla for onecall 3.0, there is a separate subscription… see prices.”
                                      • P Offline
                                        postb8822
                                        I actually solved this pretty easily after reading all the posts, but not exactly what was posted worked for me.
                                        in the MMM-OpenWeatherMapForecast module director, edit the MMM-OpenWeatherMapForecast.js file.
                                        under defaults, change
                                        Endpoint:
                                        From
                                        “https://api.openweathermap.org/data/2.5/onecall”
                                        To
                                        then use an api key created after you subscribed, this last step may or may not be needed, but coincidentally or not, the last api key I made after making the above change was what worked.
                                          sdetweil @postb8822
                                          @postb8822 I have updated my fork
                                          actually in node_helper.js
                                          • P Offline
                                            postb8822 @sdetweil
                                            @sdetweil I appreciate your expertise, that is what got me there, your fork is now 18 publications behind so I think the node_helper.js file that comes with the main install must look a lot different. It contains a call back to the .js file I mentioned, and does not have the url that you can edit in that file any more. Later I also discovered there is a string you can add in the config file that will change that value to 3.0 as well, unfortunate that they made 3.0 incompatible for new users with 2.5, because now the choice is to break all the old installs, or break all the new ones without chasing down this post.
                                            • 3 / 4
