    Pir sensor
    27 Posts 8 Posters 13.7k Views 10 Watching
    • bugsounetB Offline
      bugsounet Banned @j.e.f.f
      @j-e-f-f ah ? So cool so! Give me a sample or tuto?
        MyMirror @tanvir586
        @tanvir586 said in Pir sensor:
        @sdetweil it work like https://github.com/paviro/MMM-PIR-Sensor
        mmm-pir-sensor is not working anymore that’s why I wanted to use the light one. but this one is not working looks like
        But of course the module still works.7
        I have this running on my Pi 3b, Bullseye and MM 2.21.0 …
        • T Offline
          tanvir586 @j.e.f.f
          @j-e-f-f Thanks will try soon
          • P Offline
            Peter @MyMirror
            @MyMirror unfortunately it does not work here.
            Pi3, Bullseye, MM2.22: PIR-Sensor does not work at all, PIR-Sensor-Light counts down from 15 minutes, but starts again without turning off the screen.
            No idea what to do.
            My MM has been working flawlessly for 5 years, but after the new fresh install with 2.22 I am having this problem.
            Can anybody help?
            Peter
            • T Offline
              tanvir586 @Peter
              @Peter didn’t worked for me either. Recovered my old sd card with mm 1.19 and MMM-PIR-Sensor installed. Not updating my mm now.
              • K Offline
                kaoshunter
                So I have my PIR working through a python script, from an old install but am using xrandr, which if run in terminal works great, I don’t know scripting well and would like to know if someone could make a module, utilising a PIR and xrandr codes below
                Monitor off: xrandr --display :0.0 --output HDMI-1 --off
                Monitor on: xrandr --display :0.0 --output HDMI-1 --rotate left --auto
                  sdetweil @kaoshunter
                  @kaoshunter see MMM-PIR-Sensor-Lite
                  supports xrandr
