    Title of two modules in one line
    10 Posts 3 Posters 2.1k Views 3 Watching
    • C Offline
      codac
      Hi guys,
      I’m using two modules (MMM-DWD-WarnWeather and the default Calendar Module).
      Somehow the titles of both modules are in one line, but the content is undeaneath each other.
      What can I do (CSS?) in order to get the title of the calendar Module underneath the content of the MMM-DWD-WarnWeather module?
      I’ve tried it with padding-bottom, but it just shifts the MMM-DWD-WarnWeather content further down, the title remains where it is.
        sdetweil @codac
        @codac wherever are they located, position?
        • C Offline
          codac @sdetweil
          @sdetweil both are at top_right
          • wishmaster270W Offline
            wishmaster270 Module Developer @codac
            @codac Hi, i think the problem is caused of the CSS settings of MMM-DWD-WarnWeather.
            I already forked the module and tried to change some things. Currently i do not have time to make a proper pull request to get the changes merged to the original module but i will do this in the future.
            If you want to give it a try you can use my fork and following settings in your custom.css:
            .MMM-DWD-WarnWeather .wrapper {
              display: flex;
              flex-direction: column;
              align-items: flex-start;
              width: 320px;
              gap: 5px;
            .MMM-DWD-WarnWeather .warning {
              width: 100%;
              display: flex;
              flex-direction: row;
              gap: 10px;
              margin-bottom: 0px;
            .MMM-DWD-WarnWeather .status {
              margin-top: 0px;
            .MMM-DWD-WarnWeather .description {
              padding-left: 0px;
              margin-left: 0px;
            .MMM-DWD-WarnWeather .small-icon{
              float: unset;
              zoom: unset;
              -moz-transform: unset;
              -moz-transform-origin: unset;
              width: 46px;
              height: 46px;
              position: relative;
            • C Offline
              codac @wishmaster270
              @wishmaster270 said in Title of two modules in one line:
              display: flex;
              width: 320px;
              gap: 5px;
              width: 100%;
              display: flex;
              gap: 10px;
              margin-bottom: 0px;
              margin-top: 0px;
              padding-left: 0px;
              margin-left: 0px;
              float: unset;
              zoom: unset;
              width: 46px;
              height: 46px;
              position: relative;
              Hi Tom, this totally worked out and fixed the issue.
              Do you have one more hint about shifting the text/icon more to the right?
              wishmaster270W 1 Reply Last reply Reply Quote 1
                @codac Hi and perfect.
                You can try replacing
                with
                align-items: flex-end;
                • C Offline
                  @wishmaster270 I did change it the way you suggested, but it wont change anything unfortunately.
                    @codac Hi,
                    i setup a quick dev environment to test the possibilities. You are right. Please keep the align-items option set to flex-start.
                    There are different ways to move the warnings to the right. Depending what you want it to be you can either set:
                    1: Reduce the module width
                      width: 280px;
                    Which will look like
                    Screenshot 1
                    2: Only the description to the right
                      width: 100%;
                      text-align: right;
                    Screenshot 2
                    3: Or you can move the warnings totally to the right
                      justify-content:flex-end;
                    Which looks like
                    Screenshot 3
                    • C Offline
                      @wishmaster270 I prefer the third version. I’ve tried a couple of combinations but none of them led to the requested result.
                      What am I missing?
                      From my understanding I would suggest this CSS code (which doesnt work this way):
                        display: flex;
                        width: 320px;
                        gap: 5px;
                        margin-top: 0px;
                        padding-left: 0px;
                        margin-left: 0px;
                        float: unset;
                        zoom: unset;
                        width: 46px;
                        height: 46px;
                        position: relative;
                        @codac
                        sorry for my unprecise description. I meant adding the the justify-content: flex-end; additionally. The whole CSS settings need to look like the following:
                          display: flex;
                          width: 320px;
                          gap: 5px;
                          width: 100%;
                          display: flex;
                          gap: 10px;
                          margin-bottom: 0px;
                          width: 100%;
                          text-align: right;
                          margin-top: 0px;
                          padding-left: 0px;
                          margin-left: 0px;
                          float: unset;
                          zoom: unset;
                          width: 46px;
                          height: 46px;
                          position: relative;
