    REQUEST : SEMS PORTAL for Magic Mirror
    16 Posts 4 Posters 8.1k Views 4 Watching
    • N
      nkc
      Hi developers,
      I am not a developer but would like to request a magic mirror module development of SEMS Portal which shows values from the GoodWe solar inverter. I am enclosing a github link (codes) which may be done for something else : URL link : https://github.com/TimSoethout/goodwe-sems-home-assistant
      may be name it : MMM-GoodWe-Solar
      Thank you and much appreciated.
      Regards
      nkc.
      • JerryPJ
        JerryP @nkc
        @nkc
        check out this module
        https://github.com/HugoTheStreamer/MMM-GoodWe
        sdetweil edited to make link visible
        • JerryPJ
          JerryP
          Yes pleas.
          • F
            Fifteen15Studios
            Looks like this GitHub repo is for connecting the SEMS Portal and Home Assistant. Have you looked into the Home Assistant modules? I have one, that I forked from someone else, that displays the value of sensors from Home Assistant:
            https://github.com/Fifteen15Studios/MMM-homeassistant-sensors
            And there is another one that can display other information from Home Assistant:
            https://github.com/wonderslug/MMM-HomeAssistantDisplay
            If you have the two systems linked already (the GoodWe solar and Home Assistant) this may be the way to go.
            N 1 Reply Last reply
            • N
              nkc @Fifteen15Studios
              @Fifteen15Studios : Need a magic Mirror solution - not anything else - the solution will get the values from sems portal api’s - I have a powershell script which works - it needs to be converted to a Magic Mirror Module - if anyone is interested in reverse engineering this script to a magic mirror module - please let me know.
              Thank you and regards.
              JerryPJ 1 Reply Last reply
              • JerryPJ
                JerryP @nkc
                @nkc
                • JerryPJ
                  JerryP @JerryP
                  And now there is data on the mirror. full in test fase
                  Reply Quote 1
                  • JerryPJ
                    JerryP @JerryP
                    More to show…
                    Reply Quote 1
                    • JerryPJ
                      JerryP @JerryP
                      Vandaag het zonnetje een klein beetje op de panelen.
                      Today I was a littelbit sunny. and the module is in test fase.
                      • JerryPJ
                        JerryP @JerryP
                        A small step for men…
                        N J 3 Replies Last reply
                        • N
                          nkc @JerryP
                          @JerryP : Hi Jerry - Are you willing to share this code - Where can I find your code ?
                          Thank you.
                          JerryPJ N 2 Replies Last reply
                          • JerryPJ
                            JerryP @nkc
                            @nkc said in REQUEST : SEMS PORTAL for Magic Mirror:
                            Thank you.
                            MMM-SemPortal
                            • N
                              nkc @JerryP
                              @JerryP -Hi Jerry - Would you have a copy of the above version of programs - If you do could I have a copy - I like the above version - it save a lot of space for my arrangents on the mirror - - Please let me know where to pick the above version from - Thank You - Neel.
                              • JerryPJ
                                JerryP @nkc
                                @nkc
                                • N nkc has marked this topic as solved on
                                • N
                                  nkc @nkc
                                  Hi Jerry - Would you have this version of the program ;
                                  • J
                                    Jose1701 @JerryP
                                    @JerryP said in REQUEST : SEMS PORTAL for Magic Mirror:
                                    This is very nice. I like it a lot.
                                    I use a very simple module to show the data. https://github.com/CuddlyCow/MMM-HoymilesPVMonitor
                                    Unfortunately I use a hoymiles inverter.
                                    Any ideas to get it as nice as this module?
                                    Jose
                                    • JerryPJ
                                      JerryP @Jose1701
                                      @Jose1701
                                      No… i ready have no idea
