    electron-rebuild problems with MagicMirror 2.22.0
    53 Posts 5 Posters 29.0k Views 6 Watching
    • wishmaster270W
      wishmaster270 Module Developer
      today i tried the new release and had the usual problems with electron-rebuild with my MMM-GPIO-Notifications module. I also tried MMM-Buttons of @sdetweil i copied his approche to handle electron-rebuild to my module some time ago.
      As nearly all PIR modules will have the same issues i wanted to discuss possible solutions in public.
      I use a fully patched Raspberry OS Bullseye 32Bit.
      pi@mirror-eg:~ $ cd MagicMirror/modules/
      pi@mirror-eg:~/MagicMirror/modules $ git clone https://github.com/sdetweil/MMM-Buttons.git
      Klone nach 'MMM-Buttons' ...
      remote: Enumerating objects: 56, done.
      remote: Counting objects: 100% (4/4), done.
      remote: Compressing objects: 100% (4/4), done.
      remote: Total 56 (delta 0), reused 2 (delta 0), pack-reused 52
      Entpacke Objekte: 100% (56/56), Fertig.
      pi@mirror-eg:~/MagicMirror/modules $ cd MMM-Buttons/
      pi@mirror-eg:~/MagicMirror/modules/MMM-Buttons $ npm install
      > Magic-Mirror-Module-Buttons@1.0.0 postinstall
      > ./postinstall
      ⠴ Building module: epoll, Completed: 0make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build“ wird betreten
      ⠦ Building module: epoll, Completed: 0  CXX(target) Release/obj.target/epoll/src/epoll.o
      ⠙ Building module: epoll, Completed: 0In file included from /home/pi/.electron-gyp/22.0.0/include/node/v8-local-handle.h:12,
                       from /home/pi/.electron-gyp/22.0.0/include/node/v8-array-buffer.h:12,
                       from /home/pi/.electron-gyp/22.0.0/include/node/v8.h:24,
                       from ../src/epoll.cc:11:
      /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:124:62: warning: left shift count >= width of type [-Wshift-count-overflow]
       constexpr size_t kPtrComprCageReservationSize = size_t{1} << 32;
      /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:124:59: error: right operand of shift expression ‘(1 << 32)’ is >= than the precision of the left operand [-fpermissive]
      /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:125:60: warning: left shift count >= width of type [-Wshift-count-overflow]
       constexpr size_t kPtrComprCageBaseAlignment = size_t{1} << 32;
      /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:125:57: error: right operand of shift expression ‘(1 << 32)’ is >= than the precision of the left operand [-fpermissive]
      /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:128:27: error: static assertion failed: Pointer compression can be enabled only for 64-bit architectures
           kApiSystemPointerSize == kApiInt64Size,
      /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:186:38: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘1099511627776’ to ‘0’ [-Woverflow]
       constexpr size_t kSandboxSize = 1ULL << kSandboxSizeLog2;
      /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:204:50: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738368’ to ‘0’ [-Woverflow]
       constexpr size_t kSandboxGuardRegionSize = 32ULL * GB;
      /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:220:56: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘8589934592’ to ‘0’ [-Woverflow]
       constexpr size_t kSandboxMinimumReservationSize = 8ULL * GB;
      /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:230:60: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738367’ to ‘4294967295’ [-Woverflow]
       constexpr size_t kMaxSafeBufferSizeForSandbox = 32ULL * GB - 1;
      /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:231:44: error: static assertion failed: The maximum allowed buffer size must not be larger than the sandbox's guard regions
       static_assert(kMaxSafeBufferSizeForSandbox <= kSandboxGuardRegionSize,
      /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:236:48: error: static assertion failed: The maximum size of a BoundedSize must be synchronized with the kMaxSafeBufferSizeForSandbox
       static_assert(1ULL << (64 - kBoundedSizeShift) ==
                         kMaxSafeBufferSizeForSandbox + 1,
      /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:260:56: error: static assertion failed: kExternalPointerTableReservationSize and kExternalPointerIndexShift don't match
       static_assert((1 << (32 - kExternalPointerIndexShift)) == kMaxExternalPointers,
      ⠹ Building module: epoll, Completed: 0make: *** [epoll.target.mk:129: Release/obj.target/epoll/src/epoll.o] Fehler 1
      make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build“ wird verlassen
      ✖ Rebuild Failed
      An unhandled error occurred inside electron-rebuild
      node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll'.
      For more information, rerun with the DEBUG environment variable set to "electron-rebuild".
      Error: `make` failed with exit code: 2
      Error: node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll'.
          at NodeGyp.rebuildModule (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/module-type/node-gyp.js:120:19)
          at processTicksAndRejections (node:internal/process/task_queues:96:5)
          at async ModuleRebuilder.rebuildNodeGypModule (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/module-rebuilder.js:98:9)
          at async ModuleRebuilder.rebuild (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/module-rebuilder.js:128:14)
          at async Rebuilder.rebuildModuleAt (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/rebuild.js:149:13)
          at async Rebuilder.rebuild (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/rebuild.js:112:17)
          at async /home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/cli.js:158:9
      npm ERR! code 255
      npm ERR! path /home/pi/MagicMirror/modules/MMM-Buttons
      npm ERR! command failed
      npm ERR! command sh -c ./postinstall
      npm ERR!     /home/pi/.npm/_logs/2023-01-06T11_10_38_105Z-debug-0.log
      S 3 Replies Last reply
        sdetweil @wishmaster270
        @wishmaster270 on my intel box this worked great
        sam@galliumos:~/MagicMirror/modules/MMM-Buttons$ npm install --omit=dev --no-audit --no-fund
        > ./postinstall
        /home/sam/MagicMirror/modules/MMM-Buttons
        ⠇ Building module: epoll, Completed: 0make: Entering directory '/home/sam/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
        ⠴ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
        ⠏ Building module: epoll, Completed: 0  COPY Release/epoll.node
        make: Leaving directory '/home/sam/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
        ✔ Rebuild Complete
        added 6 packages in 31s
        worked on on buster
        pi@raspberrypi42:~/MagicMirror/modules/MMM-Buttons $ npm install --omit=dev --no-fund --no-audit
        > ./postinstall
        ⠸ Building module: epoll, Completed: 0make: Entering directory '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
        ⠇ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
        ⠙ Building module: epoll, Completed: 0  COPY Release/epoll.node
        make: Leaving directory '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
        ✔ Rebuild Complete
        up to date in 14s
        pi@raspberrypi42:~/MagicMirror/modules/MMM-Buttons $ grep version ../../package.json
        	"version": "2.22.0",
        KristjanESPERANTOK S 2 Replies Last reply
        • KristjanESPERANTOK
          KristjanESPERANTO Module Developer @sdetweil
          To me this looks like a problem with the onoff package. Because if I remove onoff from the package.json, npm i works.
          onoff also comes with the dependency epoll, which appears a lot in the error messages.
          npm i onoff and npm i epoll produce similar error messages. I think that’s where the main problem is.
            sdetweil @KristjanESPERANTO
            @KristjanESPERANTO the ‘problem’ is that the module installs electron-rebuild in its OWN MODULE folder, and it can no longer figure out what electron version it needs to build for…
            the only ‘fix’ is to install electron-rebuild in the MM folder (we should just install it to begin with in my opinion)
            and to launch THAT version of eb…
              @KristjanESPERANTO epoll binary is dependent on the Electron version.
              no matter which lib drags it in … so you MUST run eb… to get it current…
              see my prior post for the troubles…
              NOBODY gives a crap about breaking changes anymore…
              they all feel if you don’t update, then your code dies. and they don’t care…
                @sdetweil and it succeeded on pi4 w bullseye… I also tested with my
                upgrade script and backup/restore
                and both those executed and did rebuild on the modules… (using the postinstall script)
                karsten13K 1 Reply Last reply
                • karsten13K
                  karsten13 @sdetweil
                  node@raspberrypi:/opt/magic_mirror/modules$ git clone https://github.com/sdetweil/MMM-Buttons.git
                  Cloning into 'MMM-Buttons'...
                  Receiving objects: 100% (56/56), 11.86 KiB | 1.69 MiB/s, done.
                  Resolving deltas: 100% (25/25), done.
                  node@raspberrypi:/opt/magic_mirror/modules$ cd MMM-Buttons/
                  node@raspberrypi:/opt/magic_mirror/modules/MMM-Buttons$ ls -la
                  total 40
                  drwxr-xr-x 3 node node 4096 Jan  6 19:39 .
                  drwxr-xr-x 5 node node 4096 Jan  6 19:39 ..
                  drwxr-xr-x 8 node node 4096 Jan  6 19:39 .git
                  -rw-r--r-- 1 node node  530 Jan  6 19:39 CHANGELOG.md
                  -rw-r--r-- 1 node node 3416 Jan  6 19:39 MMM-Buttons.js
                  -rw-r--r-- 1 node node 5725 Jan  6 19:39 README.md
                  -rw-r--r-- 1 node node 2778 Jan  6 19:39 node_helper.js
                  -rw-r--r-- 1 node node  693 Jan  6 19:39 package.json
                  -rwxr-xr-x 1 node node  179 Jan  6 19:39 postinstall
                  node@raspberrypi:/opt/magic_mirror/modules/MMM-Buttons$ npm install
                  > ./postinstall
                  ⠧ Building module: epoll, Completed: 0make: Entering directory '/opt/magic_mirror/modules/MMM-Buttons/node_modules/epoll/build'
                  ⠙ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                  ⠼ Building module: epoll, Completed: 0  COPY Release/epoll.node
                  make: Leaving directory '/opt/magic_mirror/modules/MMM-Buttons/node_modules/epoll/build'
                  ✔ Rebuild Complete
                  added 6 packages, and audited 7 packages in 2m
                  found 0 vulnerabilities
                    sdetweil @karsten13
                    @karsten13 yep, looks good…
                    KristjanESPERANTOK 1 Reply Last reply
                      For me it looks like this:
                      kristjan@debian:~/Infomonitor/MagicMirror/modules$ git clone https://github.com/sdetweil/MMM-Buttons.git
                      kristjan@debian:~/Infomonitor/MagicMirror/modules$ cd MMM-Buttons/
                      kristjan@debian:~/Infomonitor/MagicMirror/modules/MMM-Buttons$ npm install
                      npm ERR! code 1
                      npm ERR! path /home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll
                      npm ERR! command sh -c -- node-gyp rebuild
                      npm ERR! make: Entering directory '/home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
                      npm ERR!   CXX(target) Release/obj.target/epoll/src/epoll.o
                      npm ERR!   SOLINK_MODULE(target) Release/obj.target/epoll.node
                      npm ERR! make: Leaving directory '/home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
                      npm ERR! gyp info it worked if it ends with ok
                      npm ERR! gyp info using node-gyp@9.3.1
                      npm ERR! gyp info using node@16.18.0 | linux | x64
                      npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
                      npm ERR! gyp info spawn /usr/bin/python3
                      npm ERR! gyp info spawn args [
                      npm ERR! gyp info spawn args   '/home/kristjan/Infomonitor/MagicMirror/node_modules/node-gyp/gyp/gyp_main.py',
                      npm ERR! gyp info spawn args   'binding.gyp',
                      npm ERR! gyp info spawn args   '-f',
                      npm ERR! gyp info spawn args   'make',
                      npm ERR! gyp info spawn args   '-I',
                      npm ERR! gyp info spawn args   '/home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/config.gypi',
                      npm ERR! gyp info spawn args   '/home/kristjan/Infomonitor/MagicMirror/node_modules/node-gyp/addon.gypi',
                      npm ERR! gyp info spawn args   '/home/kristjan/.cache/node-gyp/16.18.0/include/node/common.gypi',
                      npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                      npm ERR! gyp info spawn args   '-Dvisibility=default',
                      npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/kristjan/.cache/node-gyp/16.18.0',
                      npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/home/kristjan/Infomonitor/MagicMirror/node_modules/node-gyp',
                      npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/kristjan/.cache/node-gyp/16.18.0/<(target_arch)/node.lib',
                      npm ERR! gyp info spawn args   '-Dmodule_root_dir=/home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll',
                      npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                      npm ERR! gyp info spawn args   '--depth=.',
                      npm ERR! gyp info spawn args   '--no-parallel',
                      npm ERR! gyp info spawn args   '--generator-output',
                      npm ERR! gyp info spawn args   'build',
                      npm ERR! gyp info spawn args   '-Goutput_dir=.'
                      npm ERR! gyp info spawn args ]
                      npm ERR! gyp info spawn make
                      npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                      npm ERR! /usr/bin/ld: /lib/x86_64-linux-gnu/libm.so.6: unknown type [0x13] section `.relr.dyn'
                      npm ERR! /usr/bin/ld: skipping incompatible /lib/x86_64-linux-gnu/libm.so.6 when searching for /lib/x86_64-linux-gnu/libm.so.6
                      npm ERR! /usr/bin/ld: cannot find /lib/x86_64-linux-gnu/libm.so.6
                      npm ERR! /usr/bin/ld: /lib/x86_64-linux-gnu/libmvec.so.1: unknown type [0x13] section `.relr.dyn'
                      npm ERR! /usr/bin/ld: skipping incompatible /lib/x86_64-linux-gnu/libmvec.so.1 when searching for /lib/x86_64-linux-gnu/libmvec.so.1
                      npm ERR! /usr/bin/ld: cannot find /lib/x86_64-linux-gnu/libmvec.so.1
                      npm ERR! collect2: error: ld returned 1 exit status
                      npm ERR! make: *** [epoll.target.mk:145: Release/obj.target/epoll.node] Error 1
                      npm ERR! gyp ERR! build error
                      npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
                      npm ERR! gyp ERR! stack     at ChildProcess.onExit (/home/kristjan/Infomonitor/MagicMirror/node_modules/node-gyp/lib/build.js:203:23)
                      npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
                      npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:293:12)
                      npm ERR! gyp ERR! System Linux 5.10.0-20-amd64
                      npm ERR! gyp ERR! command "/home/kristjan/.nvm/versions/node/v16.18.0/bin/node" "/home/kristjan/Infomonitor/MagicMirror/node_modules/.bin/node-gyp" "rebuild"
                      npm ERR! gyp ERR! cwd /home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll
                      npm ERR! gyp ERR! node -v v16.18.0
                      npm ERR! gyp ERR! node-gyp -v v9.3.1
                      npm ERR! gyp ERR! not ok
                      npm ERR!     /home/kristjan/.npm/_logs/2023-01-06T18_47_25_457Z-debug-0.log
                      kristjan@debian:~/Infomonitor/MagicMirror/modules/MMM-Buttons$ uname -r
                      5.10.0-20-amd64
                      kristjan@debian:~/Infomonitor/MagicMirror/modules/MMM-Buttons$ lsb_release -a
                      No LSB modules are available.
                      Distributor ID:	Debian
                      Description:	Debian GNU/Linux 11 (bullseye)
                      Release:	11
                      Codename:	bullseye
                        @wishmaster270 i don’t see any issues for your module either (modified using postinstall script)
                        sam@galliumos:~/MagicMirror/modules/MMM-GPIO-Notifications$ npm install --omit=dev --no-fund --no-audit
                        npm WARN deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                        > MMM-GPIO-Notifications@0.0.5 postinstall
                        > ./postinstall
                        ⠧ Building module: epoll, Completed: 0make: Entering directory '/home/sam/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                        ⠧ Building module: epoll, Completed: 0  COPY Release/epoll.node
                        ⠇ Building module: epoll, Completed: 0make: Leaving directory '/home/sam/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                        ✔ Rebuild Complete
                        added 170 packages in 20s
                        npm 8.11.0
                        node 16.16.0
                          @KristjanESPERANTO hm…
                          my laptop uname
                          Linux galliumos 4.16.18-galliumos #1 SMP PREEMPT Sun Jun 23 04:14:45 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
                            @KristjanESPERANTO but it didn’t execute the postinstall script…
                            tried to build without it… and it WILL fail without using electron-rebuild
                            what npm version is this?
                              @sdetweil npm -v: 8.19.2
                                @KristjanESPERANTO weird
                                sam@galliumos:~/MagicMirror/modules/MMM-Buttons$ npm -v
                                8.19.2
                                sam@galliumos:~/MagicMirror/modules/MMM-Buttons$ npm install --omit=dev --no-fund --no-audit
                                > ./postinstall
                                ⠋ Building module: epoll, Completed: 0make: Entering directory '/home/sam/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
                                ⠼ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                                ⠇ Building module: epoll, Completed: 0make: Leaving directory '/home/sam/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
                                ✔ Rebuild Complete
                                added 6 packages in 15s
                                • karsten13K
                                  karsten13 @sdetweil
                                  strange, I did npm install in the MMM-Buttons folder.
                                  More info (running in a docker container):
                                  node@raspberrypi:/opt/magic_mirror$ npx node-gyp -v
                                  v9.3.1
                                  node@raspberrypi:/opt/magic_mirror$ node -v
                                  v19.3.0
                                  node@raspberrypi:/opt/magic_mirror$ uname -a
                                  Linux raspberrypi 5.15.76-v7l+ #1597 SMP Fri Nov 4 12:14:58 GMT 2022 armv7l GNU/Linux
                                  node@raspberrypi:/opt/magic_mirror$ cat /etc/os-release
                                  PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                  NAME="Debian GNU/Linux"
                                  VERSION_ID="11"
                                  VERSION="11 (bullseye)"
                                  VERSION_CODENAME=bullseye
                                  ID=debian
                                  HOME_URL="https://www.debian.org/"
                                  SUPPORT_URL="https://www.debian.org/support"
                                  BUG_REPORT_URL="https://bugs.debian.org/"
                                  node@raspberrypi:/opt/magic_mirror$ npm -v
                                  9.2.0
                                  • karsten13K
                                    karsten13 @sdetweil
                                    @sdetweil said in electron-rebuild problems with MagicMirror 2.22.0:
                                    thats x86_64, not arm32v7, totally different concerning compiling stuff which is done in electron-rebuild …
                                      sdetweil @karsten13
                                      @karsten13 his was x86_64… (edit: i see his is amd64, oops, tldr;l!)…
                                      I will see if I can get a vm on my new amd64 chromebook… had it til I powered off…
                                      but I built on buster and bullseye on pi4 also … MM version 2.22
                                      but his didn’t execute the postinstall script
                                      karsten13K 2 Replies Last reply
                                      • karsten13K
                                        karsten13 @sdetweil
                                        his was x86_64…
                                        he wrote “I use a fully patched Raspberry OS Bullseye 32Bit.” so I think this is arm32v7
                                        strange
                                          sdetweil @karsten13
                                          @karsten13 yeh, his says
                                          5.10.0-20-amd64
                                          so not 32 bit.
                                          @KristjanESPERANTO
                                          can you go to the MMM-Buttons folder and do
                                          ./postinstall
                                          • karsten13K
                                            karsten13 @sdetweil
                                            so not 32 bit.
                                            he wrote 32 bit
                                            x86_64=amd64: No Raspian OS
                                            arm32v7=arm=aarch32: Raspian OS 32-bit
                                            arm64v8=arm64=aarch64: Raspian OS 64-bit
                                            • 1 / 3
