    v2.23.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 3.0k Views 1 Watching
    • MichMichM Offline
      MichMich
      [2.23.0] - 2023-04-04
      https://github.com/MichMich/MagicMirror/releases/tag/v2.23.0
      Thanks to: @angeldeejay, @buxxi, @CarJem, @dariom, @DaveChild, @dWoolridge, @grenagit, @Hirschberger, @KristjanESPERANTO, @MagMar94, @naveensrinivasan, @nfogal, @psieg, @rajniszp, @retroflex, @SkySails and @tomzt.
      Special thanks to @khassel, @rejas and @sdetweil for taking over most (if not all) of the work on this release as project collaborators. This version would not be there without their effort. Thank you guys! You are awesome!
      Added
      • Added increments for hourly forecasts in weather module (#2996)
      • Added tests for hourly weather forecast
      • Added possibility to ignore MagicMirror repo in updatenotification module
      • Added Pirate Weather as new weather provider (#3005)
      • Added possibility to use your own templates in Alert module
      • Added error message if <modulename>.js file is missing in module folder to get a hint in the logs (#2403)
      • Added possibility to use environment variables in config.js (#1756)
      • Added option pastDaysCount to default calendar module to control of how many days past events should be displayed
      • Added thai language to alert module
      • Added option sendNotifications in clock module (#3056)
      Removed
      • Removed darksky weather provider
      • Removed unneeded (and unwanted) ‘.’ after the year in calendar repeatingCountTitle (#2896)
      Updated
      • Use develop as target branch for dependabot
      • Update issue template, contributing doc and sample config
      • The weather modules clearly separates precipitation amount and probability (risk of rain/snow)
        • This requires all providers that only supports probability to change the config from showPrecipitationAmount to showPrecipitationProbability.
      • Update tests for weather and calendar module
      • Changed updatenotification module for MagicMirror repo only: Send only notifications for master if there is a tag on a newer commit
      • Update dates in Calendar widgets every minute
      • Cleanup jest coverage for patches
      • Update stylelint dependencies, switch to stylelint-config-standard and handle stylelint issues, update main.css matching new rules
      • Update Eslint config, add new rule and handle issue
      • Convert lots of callbacks to async/await
      • Revise require imports (#3071 and #3072)
      Fixed
      • Fix wrong day labels in envcanada forecast (#2987)
      • Fix for missing default class name prefix for customEvents in calendar
      • Fix electron flashing white screen on startup (#1919)
      • Fix weathergov provider hourly forecast (#3008)
      • Fix message display with HTML code into alert module (#2828)
      • Fix typo in french translation
      • Yr wind direction is no longer inverted
      • Fix async node_helper stopping electron start (#2487)
      • The wind direction arrow now points in the direction the wind is flowing, not into the wind (#3019)
      • Fix precipitation css styles and rounding value
      • Fix wrong vertical alignment of calendar title column when wrapEvents is true (#3053)
      • Fix empty news feed stopping the reload forever
      • Fix e2e tests (failed after async changes) by running calendar and newsfeed tests last
      • Lint: Use template literals instead of string concatenation
      • Fix default alert module to render HTML for title and message
      • Fix Open-Meteo wind speed units
      • MichMichM MichMich locked this topic on
