    After update 2.23.0 crash
    56 Posts 9 Posters 33.4k Views 8 Watching
      sdetweil @swvalenti
      @swvalenti how did you revert?
      swvalentiS 1 Reply Last reply Reply Quote 0
      • swvalentiS
        swvalenti Project Sponsor @sdetweil
        @sdetweil said in After update 2.23.0 crash:
        Copied original file and renamed before using your script.
          sdetweil @swvalenti
          @swvalenti got it…
          • swvalentiS
            @swvalenti got it…
            Thought maybe the script would catch it. Ha. Oh well thanks for all your help and work.
              sdetweil @swvalenti
              @swvalenti the script DID catch for request, but not jsdom…
              these are the undocumented libs used
              OWGR.js:const request = require('request');
              OWGR.js:const jsdom = require("jsdom");
              I just added that to the upgrade script list of missing libs
              • swvalentiS
                Cool so if I update it will work?
                  sdetweil @swvalenti
                  @swvalenti should…
                  • swvalentiS
                    @swvalenti should…
                    Thanks Sam I’ll report back
                      sdetweil @swvalenti
                      @swvalenti nope it wont work as it is… looks only in the node_helper… oops…
                      working on fix…
                      pushed a fix
                      • swvalentiS
                        working on fix…
                        pushed a fix
                        Ran upgrade script but still didn’t work same error
                          sdetweil @swvalenti
                          @swvalenti can u post the ~/MagicMirror/installers/upgrade.log
                          • swvalentiS
                            @sdetweil Here ya go
                            https://drive.google.com/file/d/1L5ORoBJlEV6lYSLzJC7VhHM1S1P-jRWy/view?usp=share_link
                              sdetweil @swvalenti
                              @swvalenti ok , because you had already done upgrade on this instance. apply doesnt do anything
                              do force
                              at the end instead of apply
                              swvalentiS 1 Reply Last reply Reply Quote 1
                              • swvalentiS
                                @sdetweil You are the man worked like a charm. Only thing I noticed when running on windows “alt” does not bring the toolbar up in order to quit MM. Did anything change?
                                  sdetweil @swvalenti
                                  @swvalenti alt-spacebar, or ctrl-m
                                  ctrl-q to quit, if not using pm2.
                                  pm2 will just restart it
                                  • swvalentiS
                                    @sdetweil ctrl m worked thanks Sam!
                                    • J
                                      JoeFranz
                                      Same here, error after Update :-(
                                      @sdetweil Update with your script
                                      (Use electron --trace-warnings ... to show where the warning was created)
                                      [05.04.2023 07:02.12.571] [ERROR] (node:4893) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
                                      [4932:0405/070214.077646:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                                      [4962:0405/070214.418104:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                                      • J
                                        JoeFranz
                                        I ran “electron-rebuild”, now it works again :-)
                                          sdetweil @JoeFranz
                                          @JoeFranz on what module?
                                          J W 2 Replies Last reply Reply Quote 0
                                          • J
                                            JoeFranz @sdetweil
                                            @sdetweil MMM-PIR-Sensor
                                            • 2 / 3
