    cannot get Raspberry pi 2 to run
    39 Posts 2 Posters 15.9k Views 2 Watching
    • T Offline
      theaddies @sdetweil
      lsb_release -a
      No LSB modules are available.
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 10 (buster)
      Release:        10
      Codename:       buster
      • T Offline
        theaddies @sdetweil
        @sdetweil for which chromium or which chromium-browswer I get nothing returned.
          sdetweil @theaddies
          @theaddies interesting, log says one of them got installed
          Unpacking chromium-browser (92.0.4515.98~buster-rpt2)
          note u had an extra w in the text on last message
          browswer
          pm2 setup for autostart having trouble…
          you do
          pm2 autostart
          and it gives you the command to execute to make that happen
          then it says it can’t find the systemd init system to update, after it just said that is the one to use…
          will have to research and debug
          • T Offline
            theaddies @sdetweil
            pi@raspberrypi:~/MagicMirror $ ./run-start.sh
            [07.04.2023 22:00.28.274] [LOG] Starting MagicMirror: v2.23.0
            [07.04.2023 22:00.28.488] [LOG] Loading config ...
            [07.04.2023 22:00.28.652] [DEBUG] config template file not exists, no envsubst
            [07.04.2023 22:00.28.853] [LOG] Loading module helpers ...
            [07.04.2023 22:00.28.933] [LOG] No helper found for module: alert.
            [07.04.2023 22:00.29.513] [LOG] Initializing new module helper ...
            [07.04.2023 22:00.29.565] [LOG] Module helper loaded: updatenotification
            [07.04.2023 22:00.29.597] [LOG] No helper found for module: clock.
            [07.04.2023 22:00.29.659] [WARN]  No /home/pi/MagicMirror/js/../modules/calendar_monthly/calendar_monthly.js found for module: calendar_monthly.
            [07.04.2023 22:00.29.722] [LOG] No helper found for module: calendar_monthly.
            [07.04.2023 22:00.41.528] [LOG] Initializing new module helper ...
            [07.04.2023 22:00.41.561] [LOG] Module helper loaded: calendar
            [07.04.2023 22:00.41.616] [WARN]  No /home/pi/MagicMirror/js/../modules/random_quotes/random_quotes.js found for module: random_quotes.
            [07.04.2023 22:00.41.664] [LOG] No helper found for module: random_quotes.
            [07.04.2023 22:00.41.707] [LOG] No helper found for module: weather.
            [07.04.2023 22:00.42.663] [LOG] Initializing new module helper ...
            [07.04.2023 22:00.42.687] [LOG] Module helper loaded: newsfeed
            [07.04.2023 22:00.42.732] [WARN]  No /home/pi/MagicMirror/js/../modules/MMM-Snow/MMM-Snow.js found for module: MMM-Snow.
            [07.04.2023 22:00.42.749] [LOG] No helper found for module: MMM-Snow.
            [07.04.2023 22:00.42.786] [WARN]  No /home/pi/MagicMirror/js/../modules/MMM-Unsplash/MMM-Unsplash.js found for module: MMM-Unsplash.
            [07.04.2023 22:00.42.814] [LOG] No helper found for module: MMM-Unsplash.
            [07.04.2023 22:00.42.841] [LOG] All module helpers loaded.
            [07.04.2023 22:00.43.422] [LOG] Starting server on port 8080 ...
            [07.04.2023 22:00.44.420] [LOG] Server started ...
            [07.04.2023 22:00.44.470] [LOG] Connecting socket for: updatenotification
            [07.04.2023 22:00.44.531] [LOG] Starting module helper: updatenotification
            [07.04.2023 22:00.44.568] [LOG] Connecting socket for: calendar
            [07.04.2023 22:00.44.598] [LOG] Starting node helper for: calendar
            [07.04.2023 22:00.44.642] [LOG] Connecting socket for: newsfeed
            [07.04.2023 22:00.44.672] [LOG] Starting node helper for: newsfeed
            [07.04.2023 22:00.44.709] [LOG] Sockets connected & modules started ...
            [07.04.2023 22:00.44.744] [LOG]
            Ready to go! Please point your browser to: http://localhost:8080
            Starting chromium browser now, have patience, it takes a minute
            The screen for the raspberry pi is blank. this output is from ssh.
            I just typed it again and now I get
            /usr/bin/chromium-broswer
            sorry about that.
              sdetweil @theaddies
              @theaddies screen black, yes, takes long time
              increase swap space helps some
              use Midori browser helps some more (have to install Midori, and set an env variable, see doc )
              • T Offline
                theaddies @sdetweil
                @sdetweil The screen has been black for an hour. When i reboot, the first thing I see is the MagicMirror logo. That is different than before. Before it booted into the raspian desktop and then the magicmirror loaded. It did take a while. Now, as I said above, I see the MagicMirror logo it seems to be loading and then the screen goes blank. It does not come back. ssh works, but the keyboard and mouse on the pi itself will not wake it up.
                I did see the correct screen after I ran the command below, but I can’t do that now.
                DISPLAY=:0 npm start
                S 4 Replies Last reply Reply Quote 0
                  sdetweil @theaddies
                  @theaddies pm2 is not working for autostart for some reason
                    sdetweil @theaddies
                    @theaddies reboot, then run the fixuppm2 script from my scripts page…
                    let me know
                      sdetweil @theaddies
                      @theaddies ok, I was able to reproduce the problem
                      after reboot do this
                      pm2 startup
                      it will return a command to execute
                      copy paste that command and hit enter
                      it worked for me to manually enter the command
                      i opened this issue in pm2
                      https://github.com/Unitech/pm2/issues/5582
                        sdetweil @theaddies
                        @theaddies i updated the install script to fail if the system is bullseye and this is an armv6l device
                        • T Offline
                          theaddies @sdetweil
                          @sdetweil I cannot get the pi to display anything via hdmi. my only access to it now is via ssh.
                            sdetweil @theaddies
                            @theaddies eh? not even the desktop?
                            I installed fresh on my pi0w, (all via ssh) and after fixing the pm2 issue it autostarts mm as expected
                            • T Offline
                              theaddies @sdetweil
                              @sdetweil I just followed the procedure on a pi4 and everything worked great.
                                sdetweil @theaddies
                                @theaddies cool
                                my pi0w test
                                flash sd card with legacy full desktop, 32gb sd card
                                edit the wap_supplicant file to enable wifi
                                boot
                                auto run update
                                enable ssh
                                change machine name (add a 0) (have others running on the network , pi3, pi4, pi42…)
                                reboot
                                logon via ssh
                                paste my install script url
                                run
                                select yes to pm2
                                select yes to screen saver off
                                pm2 install failed
                                fixuppm2 script failed
                                reboot
                                logon via ssh
                                run the pm2 startup command
                                copy/paste the output to execute pm2 setup again
                                worked this time
                                run fixuppm2 to add mm as an app…
                                mm starts
                                reboot
                                mm starts
                                • T Offline
                                  theaddies @sdetweil
                                  @sdetweil I am loathed to start the pi2 over again for the fourth time. here is what I have right now. I think I got MagicMirror and mm removed from the pm2. I installed mm when I thought things were not working.
                                  The HDMI output still does not work. I was thinking now I would run the pm2 startup command although I am sure I already did it and then I would run fixuppm2.
                                  • T Offline
                                    theaddies @theaddies
                                      sdetweil @theaddies
                                      @theaddies yes, it says spawining, so pm2 is not set to autostart
                                      do
                                      pm2 startup
                                      it will output a command string, copy paste that command string (last line) and hit enter,
                                      DO NOT USE MINE BELOW
                                      pi@raspberrypi0:~ $ pm2 startup
                                      [PM2] Init System found: systemd
                                      [PM2] To setup the Startup Script, copy/paste the following command:
                                      sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
                                      note the error in your post of running my fixuppm2 script
                                      init system not found
                                      THAT is the problem… for some reason it cannot figure out HOW to do the correct startup stuff…
                                      BUT it just said what type to use…
                                      • T Offline
                                        theaddies @sdetweil
                                        @sdetweil OK So I went ahead and did the whole thing over again for the fourth time with the exact method you outlined. It works. It would be nice to somehow let the next poor sod who wants to waste 2 days of their life of the right way to do this on a pi2.
                                          sdetweil @theaddies
                                          @theaddies I am trying to get a fix for pm2. not our code, so nothing we can force
                                          glad u got it working
