    Testing my module, it is stuck loading
    31 Posts 2 Posters 12.0k Views 2 Watching
    • L Offline
      l0zarus @sdetweil
      @sdetweil I’m going to try to fill it out like a template, let me know if I’m following.
      let header = "",
      let original_url = "https://api.seatgeek.com/2/events?client_id=MYCLIENTID&client_secret=MYCLIENTSECRET "
      let cors_url = "http://" + config.address==="IP ADDRESS HERE"?"localhost":config.address + ":" + config.port + "/cors?" + header + "&url=" + original_url
      and then I fetch(cors_url)?
      Is this right?
        sdetweil @l0zarus
        @l0zarus said in Testing my module, it is stuck loading:
        Is this right?
        yes
        almost …
        "IP ADDRESS HERE"
        MUST be
        "0.0.0.0"
        (which is the MM value for listen on any network adapter)
        • L Offline
          l0zarus @sdetweil
          // this next block is to deal with a CORS permissions issue with the API
          let header = “”;
              // this is the API call url
              let original_url = "http://api.seatgeek.com/2/events?lat=" + self.config.latitude + "&lon=" + self.config.longitude + "&per_page=" + self.config.eventCount + "&datetime_utc.gte=" + today + "&datetime_utc.lte=" + oneweek + "&range=" + self.config.range + "&type=concert" + "&client_id=" + self.config.clientID + "&client_secret=" + self.config.clientSecret;
              // this is the cors URL
              let cors_url = "http://" + config.address==="0.0.0.0"?"localhost":config.address + ":" + config.port + "/cors?" + header + "&url=" + original_url;
            sdetweil @l0zarus
            @l0zarus looks good
            • L Offline
              l0zarus @sdetweil
              @sdetweil I got a new console error:
                sdetweil @l0zarus
                @l0zarus you did NOT add let config= right? (or var, or const)
                config is already defined for you
                this.config is the stuff from your module entry
                config. is ALL the config.js
                L 2 Replies Last reply Reply Quote 0
                • L Offline
                  l0zarus @sdetweil
                  I added let header = “” and let cors_url = jdhflrkgd. I did not add anything else at all.
                  exact code below:
                          let header = "";
                          // fetching the data from seatgeek
                          fetch(cors_url)
                  • L Offline
                    l0zarus @sdetweil
                    strange… I just found the following code at the top of my file. I did not add it there. Going to delete it now.
                    const config = require("../../config/config");
                      sdetweil @l0zarus
                      config.address===“0.0.0.0”?“localhost”:config.address
                      oops
                      need parens around that…
                      L 1 Reply Last reply Reply Quote 1
                      • L Offline
                        l0zarus @sdetweil
                        @sdetweil aha!!! This did it! It’s ugly but it is working… now to spend time improving the design of the table and make my code more effective.
                        THANK YOU SO MUCH! I will probably be back with more questions, but not around this issue.
                          sdetweil @l0zarus
                          @l0zarus woohoo… thx for the feedback
