    MMM-CalendarExt3 how do you create multiple events with color css?
    17 Posts 4 Posters 5.0k Views 4 Watching
      Sam 0 @MMRIZE
      @MMRIZE
      Thank you very much for your effort. I try to describe as best as I can what is working now so that others can learn from it.
      Okay, I did some further research based on the term symbol and saw that the symbols had to be added in the general calendar. I also saw them in MMM-CalendarExt3 as below.
      Will show my config code here:
      			header: "Familie agenda",
      						symbol: "calendar-check",
      						url: "outlook url"
      customEvents: [
          	{keyword: "zwemmen", symbol: "person-swimming fas fa-fw fa-person-swimming"},
          	{keyword: "padel", symbol: "running fas fa-fw fa-running"},
      	{keyword: "zingen", symbol: "music fas fa-fw fa-music"},
      	{keyword: "verjaardag", symbol: "cake-candles fas fa-fw fa-cake-candles"},
          	{keyword: "volleybal", symbol: "volleyball fas fa-fw fa-volleyball"}
        module: "MMM-CalendarExt3",
        position: "lower_third",
        title: "",
      eventTransformer: (ev) => {
         if (ev.title.search('Uitje') > -1) ev.color = 'blue'
         if (ev.title.search('Verjaardag') > -1) ev.color = '#FF69B4'
      I will also try your previous code.
      I would also like to control the color via CSS in the config file.
      How are you doing this? I already tried something but this doesn’t seem to work.
        Sam 0 @MMRIZE
        @MMRIZE
        I also tested your code and it works fine too.
          MMRIZE @Sam 0
          @Sam-0
          If you have some knowledge about CSS, you can almost control the look of this module. Most needed info is described in readme md file.
            MMRIZE @Sam 0
            @Sam-0 said in MMM-CalendarExt3 how do you create multiple events with color css?:
            That is why I said;
            First,
            You can assign colour or class per each calendar. So check if your events are separated by different calendars. Check it first.
            BKeyportB S 2 Replies Last reply Reply Quote 0
            • BKeyportB Offline
              BKeyport Module Developer @MMRIZE
              Here’s my multi-transform code for reference. (The brackets may be off, I didn’t check on copy…)
              					if (ev.title.search("🏠") > -1) {
              						ev.title = ev.title.replace("🏠 Personal Commitment","🏠 Personal Event");
              						ev.color = 'yellow';
              					if (ev.title.search("✈ Flight") > -1) {
              						ev.title = ev.title.replace("✈ Flight","🏠 Personal Event");
              					if (ev.title.search("busy") > -1) {
              						ev.title = ev.title.replace("busy","🏠 Mom Event");
              					if (ev.title.search("Weekley") > -1) {
              						ev.title = ev.title.replace("Weekley","Weekly");
              					return ev
              I’m using both CX3 and CX3A
                Sam 0 @MMRIZE
                @MMRIZE said in MMM-CalendarExt3 how do you create multiple events with color css?:
                First,
                I only have one calendar. I’ve already looked at an example but it doesn’t seem to work.
                I found this example on this forum.
                with customer.css
                .CX3 .Ben {
                color: brown;
                eventTransformer: function(ev) {
                  if (ev.title.search(“Ben”) > -1)  ev.className = “Ben”;
                  return ev
                This doesn’t seem to do much, the color just remains white.
                But is this possible?
                  sdetweil @Sam 0
                  @Sam-0 in the default calendar, where you put url:
                  add
                  color: … whatever
