    Update is not working..I need help please
    41 Posts 5 Posters 13.1k Views 5 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @sil3ntstorm
      @sil3ntstorm I only deleted the module folder…
        Stoffbeuteluwe Project Sponsor @sdetweil
        thanks DWD-Warnweather is fine
        I can’t get MMM-MyCalendar to work, I’ve tried everything but unfortunately it doesn’t work.
        As soon as the module folder (MMM-MyCalendar) is in the modules folder it doesn’t work…
        Unfortunately I don’t know what to do next, sorry
          sdetweil
          @Stoffbeuteluwe show the output of the npm start
          best way
          pm2 stop all
          cd ~/MagicMirror
          npm start >somefile.txt 2>&1
          wait 20 seconds
          ctrl -c in the window for the above commands
          then edit somefile.txt
          and search for
          Cannot find module
          then next few lines will tell you which mmm module is affected
            > magicmirror@2.25.0 start
            [09.10.2023 21:11.47.231] [LOG]   Starting MagicMirror: v2.25.0
            [09.10.2023 21:11.47.231] [LOG]   Loading config ...
            [09.10.2023 21:11.47.232] [DEBUG] config template file not exists, no envsubst
            [09.10.2023 21:11.47.233] [LOG]   Loading module helpers ...
            [09.10.2023 21:11.47.233] [LOG]   No helper found for module: alert.
            [09.10.2023 21:11.47.257] [LOG]   Initializing new module helper ...
            [09.10.2023 21:11.47.257] [LOG]   Module helper loaded: MMM-Remote-Control
            [09.10.2023 21:11.47.258] [LOG]   Initializing new module helper ...
            [09.10.2023 21:11.47.258] [LOG]   Module helper loaded: updatenotification
            [09.10.2023 21:11.47.258] [LOG]   No helper found for module: MMM-Snow.
            [09.10.2023 21:11.47.258] [LOG]   No helper found for module: MMM-MyWordClock.
            [09.10.2023 21:11.47.258] [LOG]   No helper found for module: clock.
            [09.10.2023 21:11.47.258] [LOG]   No helper found for module: calendar_monthly.
            [09.10.2023 21:11.47.275] [LOG]   Initializing new module helper ...
            [09.10.2023 21:11.47.275] [LOG]   Module helper loaded: calendar
            [09.10.2023 21:11.47.276] [ERROR] (node:78446) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
            Require stack:
            - /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js
            - /Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js
            - /Users/patrickhahn/MM/js/app.js
            - /Users/patrickhahn/MM/js/electron.js
            - /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/Resources/default_app.asar/main.js
                at node:internal/modules/cjs/loader:1084:15
                at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                at Module._resolveFilename (/Users/patrickhahn/MM/node_modules/module-alias/index.js:49:29)
                at node:internal/modules/cjs/loader:929:27
                at Function._load (node:electron/js2c/asar_bundle:2:13327)
                at Module.require (node:internal/modules/cjs/loader:1150:19)
                at require (node:internal/modules/cjs/helpers:110:18)
                at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:11:15)
                at Module._compile (node:internal/modules/cjs/loader:1271:14)
                at Object..js (node:internal/modules/cjs/loader:1326:10)
                at Module.load (node:internal/modules/cjs/loader:1126:32)
                at node:internal/modules/cjs/loader:967:12
                at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js:8:25)
            (Use `Electron --trace-warnings ...` to show where the warning was created)
            [09.10.2023 21:11.47.276] [ERROR] (node:78446) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
            2023-10-09 21:11:47.294 Electron[78446:1242307] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
            /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron exited with signal SIGINT
              sdetweil @Stoffbeuteluwe
              @Stoffbeuteluwe said in Update is not working..I need help please:
              Cannot find module ‘fetch’
              yes, and the module doesn’t provide a package.json, so npm install can’t fix it…
              BUT fetch is provided in the base node 18 and 20… SO
              edit the
              and comment out the line (11) , by adding // to the start of the line
              const fetch = require("fetch");
                i have done this
                /* MagicMirror²
                 * Node Helper: Calendar - CalendarFetcher
                 * By Michael Teeuw https://michaelteeuw.nl
                 * MIT Licensed.
                const CalendarUtils = require("./calendarutils");
                const Log = require("logger");
                const NodeHelper = require("node_helper");
                const ical = require("node-ical");
                //const fetch = require("fetch");
                const digest = require("digest-fetch");
                const https = require("https");
                 * @param {string} url The url of the calendar to fetch
                 * @param {number} reloadInterval Time in ms the calendar is fetched again
                 * @param {string[]} excludedEvents An array of words / phrases from event titles that will be excluded from being shown.
                 * @param {number} maximumEntries The maximum number of events fetched.
                 * @param {number} maximumNumberOfDays The maximum number of days an event should be in the future.
                 * @param {object} auth The object containing options for authentication against the calendar.
                 * @param {boolean} includePastEvents If true events from the past maximumNumberOfDays will be fetched too
                 * @param {boolean} selfSignedCert If true, the server certificate is not verified against the list of supplied CAs.
                 * @class
                but it still does not work
                  @Stoffbeuteluwe you are on the wrong level of code
                  neither are there in 2.25
                  do
                  cd ~/MagicMirror
                  git checkout modules/default/calendar/calendarfetcher.js
                  then
                  git status
                  show the results
                  karsten13K StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                  • karsten13K Offline
                    karsten13 @sdetweil
                    MMM-MyCalendar is a mess, the author copied (meanwhile old) versions of our code into his repo, so the problem is calendarfetcher.js of the module.
                      @sdetweil said in Update is not working..I need help please:
                      git status
                      patrickhahn@Mac-mini MM % git checkout modules/default/calendar/calendarfetcher.js
                      Updated 0 paths from the index
                      patrickhahn@Mac-mini MM % git status
                      On branch master
                      Your branch is up to date with 'origin/master'.
                      Untracked files:
                        (use "git add <file>..." to include in what will be committed)
                      	css/icons/
                      	new_package.json
                      	run-start.sh
                      nothing added to commit but untracked files present (use "git add" to track)
                        @Stoffbeuteluwe ok, now do
                        cd ~/MagicMirror
                        git pull
                        npm run install-mm
                        • 2 / 5
