    Modifying the Config File
    101 Posts 7 Posters 174.0k Views 7 Watching
      sdetweil @jimb
      @jimb my apikey has 33 characters
      it is the default key in openweather (I have multiple)
      i just brought up MM, and used my chromebook to bring up the page… and then ctrl-shift-i (letter sounds like eye) all at once, opened the dev window
      you can do those three keys on any webpage, its a toggle… on/off
      using normal chrome, you can use the 3 dot menu to get there too
        jimb
        Sam, why is it always the simple things :-)
        I found a simple link that allowed me to test the openweather api link:
        http://api.openweathermap.org/data/2.5/forecast?id=524901&appid={API Key}
        I saw the 2.5 and changed it to 3.0 and got a 401 error. I changed it back to 2.5 and it worked. I tried commenting out the 3.0 & /onecall items in config.js and got a “config.js not found” error when running MM. I had used (/*) in the leftmost column as a ‘ignore line’ comment. So, I deleted the 4 lines from config.js and it worked fine except for a teensy error “displaying Howe instead of Houston” in the display. I have no idea where that came from. I wonder why the fourth largest city in the US isn’t listed in the pull-down menu?
        Now, I’m going to see if I can add additional modules.
        Thanks for your very patient help!!
        S BKeyportB 2 Replies Last reply Reply Quote 1
          sdetweil @jimb
          @jimb awesome… making progress!!!
          • BKeyportB Offline
            BKeyport Module Developer @jimb
            @jimb it’s always the simplest solution… ALWAYS.
              jimb
              Sam, into the weeds once again :-)
              I read the readme and comments on your MMM-Config module. I was stumped immediately by your comment: “clone this repo” into the config directory. I’m assuming this this is done via WinSCP remotely into the Pi, but have no clue. Some more Linux…
                sdetweil @jimb
                @jimb hm… I don’t see those words
                git clone is done via command line
                ALL commands are done via command line
                command line is terminal or ssh terminal window
                  jimb
                  Sam, sorry to be so dense. You mention the ‘git clone’ command. Is that how ‘all’ your files are moved into the MagicMirror/Moddules directory? I’ll hunt around for the proper usage. It’s a little confusing using commands from the computer though. Please keep im mind this is all new to me, thanks
                    sdetweil @jimb
                    @jimb please read this
                    https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                    I didn’t write it
                      jimb
                      Sam, I read your comments, thanks! I have git-cloned the files into the modules sub-directory. I modified the config.js to include the lines of code you listed. Somehow I’ve blown up the file. Running in dev mode it says “unexpected (:)” is in line 58. I’ve gone over the code and don’t see the issue. Here is my config file-
                      * MagicMirror² Config Sample
                       * By Michael Teeuw https://michaelteeuw.nl
                       * MIT Licensed.
                       * see https://docs.magicmirror.builders/configuration/introduction.html
                       * and https://docs.magicmirror.builders/modules/configuration.html
                       * You can use environment variables using a `config.js.template` file instead of `config.js`
                       * which will be converted to `config.js` while starting. For more information
                       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
                      let config = {
                      	address: "localhost",	// Address to listen on, can be:
                      	port: 8080,
                      	basePath: "/",			// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
                      	useHttps: false, 	// Support HTTPS or not, default "false" will use HTTP
                      	language: "en",
                      	locale: "en-US",
                      	timeFormat: 12,
                      	units: "imperial",
                      			module: "alert",
                      			module: "updatenotification",
                      			position: "top_bar"
                      			module: "MMM-Config",
                      			position: "top_right",		//the QR code (if requested) will appear here
                      			config:{
                      			module: "clock",
                      			timezone: "America/Chicago",
                      			showPeriodUpper: "true",
                      			showDate: "true",
                      			header: "US Holidays",
                      						symbol: "calendar-check",
                      						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                      			module: "compliments",
                      			position: "lower_third"
                      			module: "weather",
                      			units: "imperial",
                      			windUnits: "imperial",
                      			tempUnits: "imperial",
                      			appendLocationNameToHeader: "true",
                      			colored: "true",
                      			header: "Current Weather",
                      				lat: "29.763281",
                      				lon: "-95.363274",
                      				type: "current",
                      				locationID: "4699066", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                      				apiKey: "8eca2aec0c123ce212",
                      			module: "weather",
                      			units: "imperial",
                      			winUnits: "imperial",
                      			colored: "true",
                      			header: "Weather Forecast",
                      				lat: "29.763281",
                       				lon:"-95.363274",
                       				type: "forecast",
                      				apiKey: "8eca2aecb123ce212",
                      			module: "newsfeed",
                      			position: "bottom_bar",
                      				feeds: [
                      				title: "New York Times",
                      					url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                      				showSourceTitle: true,
                      				showPublishDate: true,
                      				broadcastNewsFeeds: true,
                      				broadcastNewsUpdates: true
                        sdetweil @jimb
                        @jimb you are still not using the code block , which makes this hard to read…
                          sdetweil @jimb
                          @jimb said in Modifying the Config File:
                            	config:{
                          you obviously didn’t copy everything
                          the syntax requires every { to have a matching }
                          and every [ and matching ]
                          and every " a matching "
                            jimb
                            Sam, Guess who? I got the Config.js straightened out and MM was starting fine. This was with the MMM-Config text added to the file.
                            The I attempted to follow the steps to add the module code to the module sub-folder.
                            1. Clicked on the green button in your instructions and pasted the link into the terminal prefaced by ‘git clone’. It ‘cloned’ into the modules directory without errors.
                            2. I ran ‘MPM install’ and it executed without errors
                            3. From the terminal I started MM, by executing NPM Start.
                            4. It started loading, but had errors then stopped.
                            5. I was unable to copy text of the loading (w/errors) because the terminal times out.
                              sdetweil @jimb
                              @jimb
                              1. npm install, all lower case
                              2. in the mm folder?, all lower case
                              3. maybe a picture?
                              4. don’t understand this, what terminal window
                              mm will always start, even to put up a dumb message. ctrl-c to stop it
                                jimb
                                Sam, I was able to grab the text from the terminal running on my computer- this was after starting MM
                                /home/rutspi/MagicMirror$ npm start
                                magicmirror@2.25.0 start
                                DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                                [11.12.2023 19:08.13.289] [LOG] Starting MagicMirror: v2.25.0
                                [11.12.2023 19:08.13.298] [LOG] Loading config …
                                [11.12.2023 19:08.13.303] [DEBUG] config template file not exists, no envsubst
                                [11.12.2023 19:08.13.308] [LOG] Loading module helpers …
                                [11.12.2023 19:08.13.311] [LOG] No helper found for module: alert.
                                [11.12.2023 19:08.13.338] [LOG] Initializing new module helper …
                                [11.12.2023 19:08.13.339] [LOG] Module helper loaded: updatenotification
                                [11.12.2023 19:08.13.352] [ERROR] (node:1623) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘deep-object-diff’
                                Require stack:
                                • /home/rutspi/MagicMirror/modules/MMM-Config/node_helper.js
                                • /home/rutspi/MagicMirror/js/app.js
                                • /home/rutspi/MagicMirror/js/electron.js
                                • /home/rutspi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                • at node:internal/modules/cjs/loader:1084:15
                                  at Function. (node:electron/js2c/browser_init:2:117576)
                                  at Module._resolveFilename (/home/rutspi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                  at node:internal/modules/cjs/loader:929:27
                                  at Function._load (node:electron/js2c/asar_bundle:2:13327)
                                  at Module.require (node:internal/modules/cjs/loader:1150:19)
                                  at require (node:internal/modules/cjs/helpers:110:18)
                                  at Object. (/home/rutspi/MagicMirror/modules/MMM-Config/node_helper.js:10:14)
                                  at Module._compile (node:internal/modules/cjs/loader:1271:14)
                                  at Object…js (node:internal/modules/cjs/loader:1326:10)
                                  at Module.load (node:internal/modules/cjs/loader:1126:32)
                                  at node:internal/modules/cjs/loader:967:12
                                  at loadModule (/home/rutspi/MagicMirror/js/app.js:180:19)
                                  (Use electron --trace-warnings ... to show where the warning was created)
                                  [11.12.2023 19:08.13.353] [ERROR] (node:1623) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                                [1623:1211/190814.008170:ERROR:object_proxy.cc(590)] Failed to call
                                ``` method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                                MESA-LOADER: failed to retrieve device information
                                MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                                failed to load driver: kms_swrast
                                MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                                failed to load swrast driver
                                  sdetweil @jimb
                                  yeh, you missed a step
                                  Clone this repo into ~/MagicMirror/modules directory.
                                  cd MMM-Config    <---- this one
                                  npm install
                                  I’ve updated the install steps
                                  1. cd ~/MagicMirror/modules
                                  2. git clone https://github.com/sdetweil/MMM-Config
                                  3. cd MMM-Config
                                  4. npm install
                                    jimb
                                    Sam, all is working OK again. Thanks! FYI, my capitalizations were for emphasis only, not copied or used.
                                    Now, real dumb question "How is “MMM-Config” invoked?
                                      sdetweil @jimb
                                      from the doc
                                      showQR OPTIONAL false Show a QR code on the MM screen to allow quick access to the configuration form
                                      Otherwise, use a browser to open
                                      http://MM_IP_Address:MM_Port/modules/MMM-Config/review
                                        jimb
                                        Sam, you can stick a fork in this one as I don’t need any more help at this point. Thanks for all the assistance!
                                          sdetweil @jimb
                                          @jimb is mmm-config working or just moved on?
                                            jimb
                                            Sam, moving on as I want to build the actual frame for the Magic Mirror and not spend this amount of time on the code which is difficult to understand. Not your fault, but mine. :-)
                                            • 6
                                            • 5 / 6
