    messed up my config.. MM tells me to create a config file
    31 Posts 6 Posters 24.6k Views 6 Watching
    • johnnyboyJ Offline
      johnnyboy
      This post is deleted!
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @johnnyboy
        @johnnyboy theres not much to see on the picture can you check your config on jshint.com?
        johnnyboyJ 1 Reply Last reply Reply Quote 0
          johnnyboy @strawberry 3.141
            johnnyboy @johnnyboy
              @johnnyboy your quotes are wrong only " and ' are valid, but on your screenshot you used different ones which is causing the error
              johnnyboyJ 1 Reply Last reply Reply Quote 1
                  @johnnyboy no you didn’t use markdown syntax, the forum messes up quotes if their not in set in markdown codeblock.
                  your second calendar uses different quotes
                      @johnnyboy as i said your pictures don’t show everything and your code snippet is corrupt, why you not just trying it out and if it doesnt work you report again?
                                  johnnyboyJ strawberry 3.141S 2 Replies Last reply Reply Quote 0
                                          @johnnyboy as I said earlier you can use single and double quotes, it doesn’t matter which one, but it has to be either " or ' and you used a backtick `, which is not working
                                          johnnyboyJ 2 Replies Last reply Reply Quote 0
