    MMM-GoogleKeep config.js
    18 Posts 3 Posters 7.9k Views 3 Watching
      svenpisa
      Hello everyone,
      I wanted to install the following module on my MM2, but I can’t get it into config.js
      [https://github.com/taxilof/MMM-GoogleKeep]
      Yes, I’m a beginner but I thought I finally understood the logic of config.js.
      I have entered the module as follows
      			module: "MMM-GoogleKeep",
      			header: "Google Keep",
      				username: "MeineMailAdresse@gmail.com",
      				password: "MeinSicheresPasswort",
      				noteId: "1VgB6XhzmCrCpCwUFXr42YIvMiduDVNw_iweGb3xxxxxxxxxxxxxxxxxxx",
      				updateInterval: 60,
      				maxLines: 10,
      				width: 400,
      				unchecked_only: true,
      My question is, where is my error and why does the MM2 not start or is it the module itself? I have read that some people have problems with the module?
      Please let me know how I can get the module to work, what I have to enter in which file or if you know an alternative to retrieve data from Google Keep.
      Thanks and greetings
      Sven
      • S svenpisa referenced this topic on
      • KristjanESPERANTOK Online
        KristjanESPERANTO Module Developer @svenpisa
        @svenpisa said:
        Do I understand correctly that I may only have to wait until the module works or do I have to make additional settings?
        I haven’t looked at the code in detail, but that could be possible, yes. Of course, it may still be the case that something needs to be adjusted in gkeepapi and/or MMM-GoogleKeep.
        The best thing would probably be to look at alternatives.
        Can I see the status somewhere when it should work again?
        If a gpsoauth version newer than 1.0.4 appears here, we can try again. You can also follow this discussion: https://github.com/kiwiz/gkeepapi/issues/81.
          I don’t use this module, but my first guess is that you have two-factor authentication on your Google account (which is definitely recommended) . In this case I suppose you have to create an app password to use the module.
          This would also fit in with gkeepapi’s documentation, which says the following: " Enabling TwoFactor and logging in via an app password is recommended."
          Have you already created an app password for it or have you used your normal Google password?
            svenpisa
            Hey Kristjan, thank you very much for your feedback. I had previously tried it with my Google password. After your message, I have now created an APP password, but it doesn’t work there either. And I keep thinking about what the problem could be. I have tested the 16-digit (4x4) password with spaces and without spaces, but every time I insert the module into the config.js and save it, only the Raspberry OS desktop is displayed and no longer the MM.
            I have just had a quick look at the documentation https://gkeepapi.readthedocs.io/en/latest/#logging-in, but I can’t make any sense of it. I simply don’t yet have the knowledge of how to implement this documentation or where I may have to make which entries… :-( I’m just too much of a beginner for that.
            so if you have any other tips or could explain to me how I should use these instructions, I would be very happy!!! :-)
              sdetweil @svenpisa
              @svenpisa please check the messages where u do npm start
              if you use pm2 then do pm2 logs --lines=50
              or
              pm2 stop all
              cd ~/MagicMirror
              npm start
              if you are running on the same screen as mm, then press ctrl-q, look at the messages
                svenpisa
                Hi Sam,
                Here is the error excerpt. The error definitely occurs with KEEP but no idea what to do…
                magicmirror@2.25.0 start
                DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                [25.01.2024 19:42.13.949] [LOG] Starting MagicMirror: v2.25.0
                [25.01.2024 19:42.13.959] [LOG] Loading config …
                [25.01.2024 19:42.13.964] [DEBUG] config template file not exists, no envsubst
                [25.01.2024 19:42.13.972] [LOG] Loading module helpers …
                [25.01.2024 19:42.13.975] [LOG] No helper found for module: alert.
                [25.01.2024 19:42.14.621] [LOG] Initializing new module helper …
                [25.01.2024 19:42.14.622] [LOG] Module helper loaded: MMM-Wallpaper
                [25.01.2024 19:42.14.624] [LOG] No helper found for module: clock.
                [25.01.2024 19:42.15.040] [LOG] Module helper loaded: MMM-Sonos
                [25.01.2024 19:42.15.042] [LOG] No helper found for module: weather.
                [25.01.2024 19:42.15.044] [LOG] No helper found for module: MMM-CalendarExt3.
                [25.01.2024 19:42.15.046] [LOG] No helper found for module: MMM-CalendarExt3Agenda.
                [25.01.2024 19:42.15.408] [LOG] Initializing new module helper …
                [25.01.2024 19:42.15.409] [LOG] Module helper loaded: calendar
                [25.01.2024 19:42.15.411] [LOG] No helper found for module: compliments.
                [25.01.2024 19:42.15.518] [LOG] Initializing new module helper …
                [25.01.2024 19:42.15.519] [LOG] Module helper loaded: MMM-AccuWeatherForecastDeluxe
                [25.01.2024 19:42.15.527] [ERROR] (node:3930) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘python-shell’
                Require stack:
                • /home/sven/MagicMirror/modules/MMM-GoogleKeep/node_helper.js
                • /home/sven/MagicMirror/js/app.js
                • /home/sven/MagicMirror/js/electron.js
                • /home/sven/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                • at node:internal/modules/cjs/loader:1084:15
                  at Function. (node:electron/js2c/browser_init:2:117576)
                  at Module._resolveFilename (/home/sven/MagicMirror/node_modules/module-alias/index.js:49:29)
                  at node:internal/modules/cjs/loader:929:27
                  at Function._load (node:electron/js2c/asar_bundle:2:13327)
                  at Module.require (node:internal/modules/cjs/loader:1150:19)
                  at require (node:internal/modules/cjs/helpers:110:18)
                  at Object. (/home/sven/MagicMirror/modules/MMM-GoogleKeep/node_helper.js:10:23)
                  at Module._compile (node:internal/modules/cjs/loader:1271:14)
                  at Object…js (node:internal/modules/cjs/loader:1326:10)
                  at Module.load (node:internal/modules/cjs/loader:1126:32)
                  at node:internal/modules/cjs/loader:967:12
                  at loadModule (/home/sven/MagicMirror/js/app.js:180:19)
                  (Use electron --trace-warnings ... to show where the warning was created)
                  [25.01.2024 19:42.15.528] [ERROR] (node:3930) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                  [3930:0125/194216.046643:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                  MESA-LOADER: failed to retrieve device information
                  ^C/home/sven/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                  sdetweil @svenpisa
                  @svenpisa yes, the instruction leave out an important step
                  after step 2
                  then change to the module folder
                   cd MMM-GoogleKeep
                  THEN
                  npm install
                  you can do that step now, in the module folder
                    svenpisa @sdetweil
                    @sdetweil i did it…
                    I went directly to ~/MagicMirror/modules/MMM-GoogleKeep $ and started npm install but then only got error messages
                    npm ERR! code ERESOLVE
                    npm ERR! ERESOLVE could not resolve
                    npm ERR!
                    npm ERR! While resolving: MMM-GoogleKeep@1.0.0
                    npm ERR! Found: stylelint@15.11.0
                    npm ERR! node_modules/stylelint
                    npm ERR! peer stylelint@“15.x” from grunt-stylelint@0.19.0
                    npm ERR! node_modules/grunt-stylelint
                    npm ERR! dev grunt-stylelint@“latest” from the root project
                    npm ERR!
                    npm ERR! Could not resolve dependency:
                    npm ERR! dev stylelint-config-standard@“latest” from the root project
                    npm ERR!
                    npm ERR! Conflicting peer dependency: stylelint@16.2.0
                    npm ERR! peer stylelint@“^16.1.0” from stylelint-config-standard@36.0.0
                    npm ERR! node_modules/stylelint-config-standard
                    npm ERR!
                    npm ERR! Fix the upstream dependency conflict, or retry
                    npm ERR! this command with --force or --legacy-peer-deps
                    npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
                    npm ERR!
                    npm ERR!
                    npm ERR! For a full report see:
                    npm ERR! /home/sven/.npm/_logs/2024-01-25T19_14_43_524Z-eresolve-report.txt
                    npm ERR! A complete log of this run can be found in: /home/sven/.npm/_logs/2024-01-25T19_14_43_524Z-debug-0.log
                      sdetweil @svenpisa
                      @svenpisa gr… the developer junk
                      edit package.json and change
                      "devDependencies"
                      to
                      "devDependencies1"
                      then do the
                      npm install
                      again
                        svenpisa @sdetweil
                        @sdetweil You’re great… Thank you very much
                        Partly good news.
                        It could now be installed and entered in config.js. MM also starts cleanly and is also displayed cleanly, but the KEEP module is unfortunately not displayed on the MM.
                        Now I need to get the list displayed somehow.
                        I have tried it with the APP password 16 digits as well as 4x4 digits and also with the Google password but unfortunately it is not displayed.
                        Any more ideas?
                          sdetweil @svenpisa
                          @svenpisa sorry, don’t know the internals of the module
                          S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                            svenpisa @sdetweil
                            @sdetweil What? I thought you were the God Father of Magic Mirror Modules!!! ;-)
                            No problem, maybe there is someone who has used this module before and it works for him to tell me what to do… I would be very happy anyway!!!
                              KristjanESPERANTO Module Developer @sdetweil
                              I have tried to get the module to run, but have also failed. It seems to me that there is a problem with gkeepapi. A simple query with gkeepapi already fails.
                              There seems to be a workaround with docker (see https://github.com/kiwiz/gkeepapi/issues/81), but I didn’t tested that. In the issue discussion the maintainer of gkeepapi mentioned waiting for a new release of gpsoauth. Then MMM-GoogleKeep might work again without any tinkering 🙂
                                svenpisa @KristjanESPERANTO
                                @KristjanESPERANTO Thank you very much. Do I understand correctly that I may only have to wait until the module works or do I have to make additional settings? Can I see the status somewhere when it should work again?
                                  sdetweil @svenpisa
                                  @svenpisa well I can fix most install problems.
                                      Hi @KristjanESPERANTO I have seen that something has happened in the issue. But I didn’t understand what was changed and what was adjusted. May I come back to your help? If you have time, could you take a look at the issue on GitHub?
                                      Thank you very much and best regards
                                        I still can’t see a new version of gpsoauth or gkeepapi. In the issue they seem only talking about a workaround.
                                          @KristjanESPERANTO ah ok, then I took it the wrong way. Sorry and thanks
