    custom.css ......body???
    42 Posts 3 Posters 11.0k Views 3 Watching
    • P
      piki
      Re: CSS 101 - Getting started with CSS and understanding how CSS works
      I can’t change the background to MagiMirror. I need to put one image (file) there that will be loaded from the SD card. I also changed through css…but none of it works. If I change only the color it works…but the photo from the file does not. I checked the path name of the address books…but it still doesn’t work. Isn’t it necessary to add something? Thanks for any advice.
        sdetweil @piki
        @piki the MM webserver root is the MagicMirror folder, you cannot load anything from outside that folder tree thru the local server file:/// doesn’t work either
        http://localhost:MM-port/
        points to the MagicMirror folder
        SO, you can make a LINK to the file into the MM folder
        see the ln command
        sudo ln -s source dest
        source is where it is
        dest is where you want it to appear
        also, see the second link in my signature below, or using the developers window elements tab to check on the contents and play with/test styles on elements
        • P
          piki @sdetweil
          @sdetweil so via custom.css as I read it won’t work over time?
          • P
            piki
            or it won’t work only through custom .css?
              sdetweil @piki
              @piki IF you make the file to appear (copy or link) IN the MM tree THEN you can make it work thru css only
              the MM http server is configured ONLY for the MagicMirror tree and forward…
              not just anywhere in the file system
              • P
                piki
                but in which line in the tree should I edit (configure) just write the path there…or?
                  sdetweil @piki
                  @piki sorry, don’t understand the question
                  put your file in ~/MagicMirror
                  then your css url will be
                  http://localhost:mm_config_port (usually 8080)/filename(whatever the name of the file is in the MagicMirror folder)
                  http://localhost:8080/somefile.jpg
                  or whatever you call it
                  if you don’t want to copy it then
                  cd ~/MagicMirror
                  sudo ln -s /wherever_the_actual_file_is somefile.jpg
                  that will create a link for the file (from the booted sd card) to the MagicMirror folder
                  you can name it whatever you want with whatever type it is: gif, png, jpg…
                  • P
                    piki
                      sdetweil @piki
                      @piki so
                      http://localhost:8080/sku.jpg
                      • P
                        piki
                        and should I enter that in custom .css?
                        body {
                        background-image : url(‘http://localhost:8080/sku.jpg.’);
                        background-size: cover;
                          sdetweil @piki
                          @piki yes,
                          you should be able to use the developers window to add that to test out
                          select the body element and add in top right
                          • P
                            piki
                            I copied it directly into custom .css…but it still doesn’t work
                              sdetweil @piki
                              @piki can you show the custom.css entry
                              • P
                                piki
                                body {
                                background-image : uurl(‘http://localhost:8080/sku.jpg.’);
                                  sdetweil @piki
                                  @piki said in custom.css ......body???:
                                  uurl
                                  only url
                                  • P
                                    piki
                                    I fixed it, but the image still doesn’t appear
                                    body {
                                      sdetweil @piki
                                      @piki and if you open the developers window, elements tab , select the body element
                                      is the css selected
                                      and are there any errors? (in the console tab)
                                        sdetweil @piki
                                        /sku.jpg.');
                                        you also have a trailing . in the image name, ‘jpg.’
                                        • P
                                          piki
                                          Failed to load resource: the server responded with a status of 404 (Not found) sku.jpg.:1
                                            sdetweil @piki
                                            @piki still the trailing comma
                                            but, I tested here, needs to be in a subfolder of MagicMirror, config worked
                                            • 1 / 3
