    Default Calendar stuck on loading
    55 Posts 2 Posters 16.3k Views 2 Watching
      @rushmuzik OK i tested on my desktop ubuntu, and on pi4 with latest PI os (bookworm) 64bit.
      I do not see that
      what machine are you on? can u show the startup info section
      this output comes after Launching application
      [2024-12-19 08:19:24.759] [INFO]  System information:
      ### SYSTEM:   manufacturer: ; model: ; virtual: false
      ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
      ### VERSIONS: electron: 31.7.3; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
      ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
      S R 2 Replies Last reply
        @rushmuzik
        given the error you showed, can you try list change
        edit MagicMirror/js/server.js
        and down at the bottom
        	this.close = function () {
        		return new Promise((resolve) => {
        			for (const socket of serverSockets.values()) {
        				socket.close();   //<--- add this line
        				socket.destroy();
        save and restart MagicMirror
        • R
          rushmuzik @sdetweil
          @sdetweil This is what I’m using. with Firefox ESR as the browser because Chromium and regular firefox are no longer supported on a Pi zero. Also, I’m using an API to connect to my Tempest weather station and that works fine. In addition all the other default modules work as they should except for calendar.
            sdetweil @rushmuzik
            @rushmuzik pi zero. ok… let me set that up
            R 1 Reply Last reply
            • R
              rushmuzik @sdetweil
              @sdetweil These are the steps I followed to set it up
              https://www.davidgagne.net/2024/05/30/how-to-get-magicmirror-to-run-on-a-raspberry-pi-zero-w-rev-1-1/
                sdetweil @rushmuzik
                @rushmuzik ok, but because you said yes on step 2 to pm2
                you don’t need step 8 as it causes a duplicate app definition, which will cause TWO to start
                pm2 status
                will show you the apps defined
                • R
                  rushmuzik @sdetweil
                  @sdetweil How do I fix that? Is there a way to undo? This is what I see in pm2 status
                    sdetweil @rushmuzik
                    @rushmuzik you only have 1, so no issue…
                    pm2 --help
                    has lots of options
                    • R
                      rushmuzik @sdetweil
                      @sdetweil ok. Where would you suggest I go from here? COuld it be the Firefox ESR causing the issue?
                        sdetweil @rushmuzik
                        @rushmuzik I don’t know yet… I posted a potential fix for you to try, based on the error shown
                        • R
                          rushmuzik @sdetweil
                          @sdetweil Yes, I saw that. I tried it. It did’t work.
                          I wonder if something in here might help
                            sdetweil @rushmuzik
                            @rushmuzik no idea…
                            trying to get ff installed
                              @rushmuzik well i can recreate it. its a bug in firefox. trying to find a workaround, 3 so far dont
                              • R
                                rushmuzik @sdetweil
                                @sdetweil OK so I’m not crazy! Good to know! It amazes me how much you know!
                                  sdetweil @rushmuzik
                                  @rushmuzik just learned about this today, and google has a lot of info. wading thru it is time consuming.
                                  • R
                                    rushmuzik @sdetweil
                                    @sdetweil Absolutely. I appreciate all the attention you’ve given to this so far. You have been a big help to the community.
                                    • R
                                      rushmuzik @sdetweil
                                      @sdetweil I’ve searched all over google but I still haven’t found a viable solution.
                                      Do you think a previous socket.io version would fix the problem? my current version is 4.8.1
                                        sdetweil @rushmuzik
                                        @rushmuzik no idea yet
                                        • R
                                          rushmuzik @sdetweil
                                          @sdetweil The socket.io GIT lists this as a possible solution to the bad request error however I’m not quite sure where to put it.
                                          Installation: npm i http-proxy
                                          const httpProxy = require(“http-proxy”);
                                          httpProxy
                                          .createProxyServer({
                                          target: “http://localhost:3000”,
                                          ws: true,
                                          .listen(80);
                                            sdetweil @rushmuzik
                                            @rushmuzik me either. socket.io is setup in server.js
                                            • 2 / 3
