    Please commit your changes or stash them before you merge?
    17 Posts 3 Posters 11.4k Views 3 Watching
    • J
      jefftse
      I tried to update my mirror tonight but i’m getting this.
      jeff@raspberrypi:~/MagicMirror $ sudo git pull && npm run install-mm
      Updating 94c3c69…c24de64
      error: Your local changes to the following files would be overwritten by merge:
      package-lock.json
      package.json
      Please commit your changes or stash them before you merge.
      Aborting
      please advise
        sdetweil @jefftse
        @jefftse ok short path
        sudo npm install n -g
        sudo n 20.18.1
        cd ~/MagicMirror
        npm run install-mm
        J 1 Reply Last reply
          sdetweil @jefftse
          @jefftse
          1.NEVER use sudo when doing anything w MagicMirror files
          what is changed in package.json!
          git diff package.json
          BKeyportB J 2 Replies Last reply
          • BKeyportB
            @sdetweil Don’t NPM install touch the package.json - or is it just package-lock?
            Either way, @jefftse can just delete package-lock.json for that error.
            S J 2 Replies Last reply
              sdetweil @BKeyport
              @BKeyport npm does not change package.json
              • J
                jefftse @sdetweil
                jeff@raspberrypi:~/MagicMirror $ git diff package.json
                diff --git a/package.json b/package.json
                index 7b80b4e…aa80952 100644
                — a/package.json
                +++ b/package.json
                @@ -58,6 +58,7 @@
                “ajv”: “^8.17.1”,
                “ansis”: “^3.3.2”,
                “console-stamp”: “^3.1.2”,
                •           "electron-version": "^2.0.1",
                            "envsub": "^4.1.0",
                            "eslint": "^9.11.1",
                            "express": "^4.21.0",
                @@ -66,13 +67,17 @@
                “helmet”: “^7.1.0”,
                “html-to-text”: “^9.0.5”,
                “iconv-lite”: “^0.6.3”,
                •           "luxon": "^3.5.0",
                            "module-alias": "^2.2.3",
                            "moment": "^2.30.1",
                            "node-ical": "0.18.0",
                •           "onoff": "^6.0.3",
                            "pm2": "^5.4.2",
                •           "rss-parser": "^3.13.0",
                            "socket.io": "^4.8.0",
                            "suncalc": "^1.9.0",
                •           "systeminformation": "^5.23.5"
                •           "systeminformation": "^5.23.5",
                •           "wiring-pi": "^2.2.1"
                    "devDependencies": {
                            "@eslint/js": "^9.11.1",
                • J
                  jefftse @BKeyport
                  @BKeyport
                  jeff@raspberrypi:~/MagicMirror $ rm package-lock.json
                  jeff@raspberrypi:~/MagicMirror $ git pull && npm run install-mm
                  package.json
                  Aborting
                    sdetweil @jefftse
                    @jefftse
                    cd ~/MagicMirror
                    git checkout package.json
                    git pull
                    if that is successful
                    npm run mm-install
                    but watch out, then sudo may have messed things uo
                    • J
                      jefftse @sdetweil
                      jeff@raspberrypi:~/MagicMirror $ npm run mm-install
                      npm ERR! Missing script: “mm-install”
                      npm ERR!
                      npm ERR! Did you mean one of these?
                      npm ERR! npm install # Install a package
                      npm ERR! npm uninstall # Remove a package
                      npm ERR!
                      npm ERR! To see a list of scripts, run:
                      npm ERR! npm run
                      npm ERR! A complete log of this run can be found in: /home/jeff/.npm/_logs/2025-01-03T16_14_57_938Z-debug-0.log
                        sdetweil @jefftse
                        @jefftse nano package.json
                        version should be 2.30.0
                        "name": "magicmirror",
                        	"version": "2.30.0"
                        • J
                          jefftse @sdetweil
                          i’m confused. it is showing “2.30.0”
                            sdetweil @jefftse
                            @jefftse and further down
                            "scripts": {
                            		"config:check": "node js/check_config.js",
                            		"install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                            		"install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
                            		"install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
                            		"install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                            doah… my mistake…
                            npm run install-mm
                            J 3 Replies Last reply
                            • J
                              jefftse @sdetweil
                              That’s exactly what I have
                              • J
                                jefftse @sdetweil
                                jeff@raspberrypi:~/MagicMirror $ git checkout package.json
                                Updated 0 paths from the index
                                • J
                                  jefftse @sdetweil
                                  Already up to date.
                                  magicmirror@2.30.0 install-mm
                                  npm ERR! code EBADENGINE
                                  npm ERR! engine Unsupported engine
                                  npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.30.0
                                  npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.30.0
                                  npm ERR! notsup Required: {“node”:“>=20.18.1 <21 || >=22”}
                                  npm ERR! notsup Actual: {“npm”:“10.1.0”,“node”:“v20.9.0”}
                                  npm ERR! A complete log of this run can be found in: /home/jeff/.npm/_logs/2025-01-03T16_52_04_066Z-debug-0.log
                                    sdetweil @jefftse
                                    sudo n 20.18.1
                                    cd ~/MagicMirror
                                    npm run install-mm
                                    • J
                                      jefftse @sdetweil
                                      I think that did the trick
                                        sdetweil @jefftse
                                        @jefftse ok!!!
