    MMM-Webuntis
    Scheduled Pinned Locked Moved Education
    82 Posts 13 Posters 27.0k Views 13 Watching
    • H Offline
      HeikoGr @kurkarte
      @kurkarte you can try to search your school at https://webuntis.com/ . On the next site the school name in the URL could work if you replace empty spa es with „+“ signs.
      • H Offline
        HeikoGr @OliWer
        @OliWer i pushed a fix to github.
        I was able to reproduce your error.
        it should work now.
        E 1 Reply Last reply Reply Quote 2
        • O Offline
          OliWer
          Data is getting displayed now, will play around with it more later. Thank you very much!
          • E Offline
            Eli @HeikoGr
            @HeikoGr
            Hi, I am running on an RPI normally. The test system is running on Windows, yes. But both show the same issue.
            I install modules the standard way, fro a git console by pulling and npm install.
            I also tried without remote control module - same issue.
            • E Offline
              Eli @HeikoGr
              @HeikoGr Smashing, Heiko! Works perfect now! Many thanks!
              • E Offline
                Eli @Eli
                @Eli said in MMM-Webuntis:
                Small update: Seems to work only when debug mode is true…
                • H Offline
                  HeikoGr @Eli
                  @Eli maybe your school doesn‘t show more than 2 days to the future (like our school).
                  Because the only differences in the debug mode are more log output and not filtering past lessons (there is also an undocumented option „debugLastDays“ - so i was able to develop during the holidays…). How many future days do you see in the untis app or on webuntis.com?
                  H E 2 Replies Last reply Reply Quote 0
                  • H Offline
                    HeikoGr @HeikoGr
                    @HeikoGr a new commit is on github with a fix in the handling of “days” - maybe this fixes your problem.
                    • O Offline
                      OliWer
                      Fix works for me, thanks for your work!
                      • E Offline
                        Eli @HeikoGr
                        @HeikoGr Sorry, for the delayed reply. You are acorrect, also works without debug mode. Seems there was some other hickup with the server and just next time I enabled debug again is was working again. So all fine.
                        • H Offline
                          HeikoGr
                          Achtung, ich habe eine neue Version veröffentlicht und dabei die Konfigurations Variablen umbenannt - es muss die config.js angepasst werden.
                          Dafür habe ich jetzt aber auch eine Tabellenansicht implementiert:
                          T 1 Reply Last reply Reply Quote 1
                          • T Offline
                            thk @HeikoGr
                            @HeikoGr
                            Hallo & Vielen Dank für dieses tolle Modul!
                            I do love the module and especially the grid-view.
                            Is there a way to limit the number of hours displayed?
                            By that the vertical height of the grid-view could be reduced, I suppose.
                            I am asking because the generated table is exceeding the needed length to display the last hours of actual school, especially when there are weekdays in the grid which span across the whole day, like “kein Unterricht”.
                            I see there is a grid-comlumn-end, but I struggle to use it properly.
                            Thanks a lot in advance for any hint :-)
                            • H Offline
                              HeikoGr @thk
                              @thk thank you for you kind word. I was able to implement a new config option “maxGridLessons” which will cut-off everything below the configured lesson. A “… more” badge is placed if an actual lesson is hidden because of this cutoff.
                              • T Offline
                                thk @HeikoGr
                                @HeikoGr
                                Perfect!
                                Thank you so much for this fast feature implementation, exactly what I was looking for.
                                • H Offline
                                  HeikoGr
                                  Attention / Important
                                  (for our school) Untis GmbH changed url and schoolname.
                                  You may need to log in your (childrens) account(s) an edit the config.js according to the new values.
                                  At least they didn’t switch off te old json-rpc api MMM-Webuntis is using
                                    AlexLin @schmucke
                                    @schmucke, @HeikoGr
                                    I have the same situation and i finally managed to receive the timetable for my daughter by using parents account. She did not register herself for Webuntis so no chance. I made a research on the module and the webuntis API.
                                    By concept the function
                                    getOwnClassTimetableForRange(rangeStart, rangeEnd);
                                    must fail, because the parents account does not have an own timetable. So I used the function
                                    getTimetableForRange(rangeStart, rangeEnd, id, WebUntisElementType.STUDENT);
                                    The trick was to determine which “id” is to use. The id is meant as student’s id, in my case of my daughter. So I had to make a detour via
                                    const studentList = await untis.getStudents();
                                    I made a debug output of studentList to console and searched for the name of my daughter and found the id I needed for the function above. This list is very long because it showed all students of school (more than one thousand).
                                    Afterwards I could use the function and received her timetable successfully.
                                    It only worked by login with username & pass not by qrcode and only by hardcoded id because I did not find a filter method for the studentList, e.g. by name, etc. If available it should be possible not hardcoded but by config - Param.
                                    • H Offline
                                      HeikoGr
                                      that’s great - i will look how i may use this in my module.
                                      Thank you
                                        Rondejavu
                                        Ein guten Morgen,
                                        ich benutze Ihr WebUntis nun schon seid geraumer Zeit.
                                        Leider musste ich feststellen das seid ca. 2Wochen keine Verbindung mehr zu WebUntis stattfindet.
                                        mir wird jedes mal Error code 404 angezeigt.
                                        Was ich mir leider nicht vorstellen kann, da ich es auch über Handy nutze und dort alle Termine sowie den Stundenplan einsehen kann.
                                        Es wäre nett wenn ich dafür etwas Hilfe bekommen könnte damit dies wieder angezeigt wird.
                                        MfG
                                        Krause
                                        • H Offline
                                          HeikoGr @Rondejavu
                                          @Rondejavu gerne:
                                          Ich vermute, dass die Antwort schon hier im Forum ca. 3 Beiträge obendrüber steht. Untis hat an den Servern gearbeitet - evtl. müssen hier die Verbindungsparamter neu eingestellt werden.
                                            Rondejavu @HeikoGr
                                            @HeikoGr Moin,
                                            ja das ist mir klar … aber welche … da ich nur Zugang mit Benutzer und Passwort habe und keinen QR code … und auf der Website gibt es auch keinen link mehr um es iwie extern zu teilen bzw. der link funktioniert nicht in dem Modul … daher meine frage was ich jetzt machen soll …
                                            ich danke dir schon mal im voraus
                                            • 2 / 5
