    New module installer
    51 Posts 7 Posters 23.6k Views 6 Watching
      sdetweil @plainbroke
      @plainbroke i pushed a bunch of fixes.
      plainbrokeP 1 Reply Last reply Reply Quote 0
      • plainbrokeP Offline
        plainbroke @sdetweil
        I removed it with rm -rf MMM-Config
        Then rebooted Pi
        Then reinstalled with:
        cd ~/MagicMirror/modules
        git clone https://github.com/sdetweil/MMM-Config
        cd MMM-Config
        npm install
        THAT DID NOT WORK.
        threw all kinds of errors in shift+ctrl+i
        So I went back to the
        cd MMM_Config module and ran
        git pull
        git checkout with_installer
        npm install
        rebooted the Pi
        Now it works.
        Why I do not know.
        But it does. I am going to try it out with MMM-MPlayer.
        Thanks for the great work…
          @plainbroke said in New module installer:
          yes, that will put you on the root branch main or master
          you have to checkout the other branch that has the installer function in it
            @plainbroke pushed a few more updates… now open repo button in configuration screens as well as installer
              MDWEBB @sdetweil
              @sdetweil Hi Sam,
              I update the fetch interval on my CalendarExt3 module via MMM-Config as i had a power flick and events hadn’t came back quick enough for my liking. However now the whole CalendarExt3 module is not display and i am getting errors on start up saying it can’t calidate main module.js i hadn’t made any changes outside of the config module. I tried uninstalling CalendaerExt3 and reinstalling but without any luck would love some guidance. Will past the latest config module below also.
              mdwebb@raspberrypi:~/MagicMirror $ npm start
              > magicmirror@2.31.0-develop start
              > npm run start:x11
              > magicmirror@2.31.0-develop start:x11
              [2025-01-20 20:36:52.086] [LOG]   Starting MagicMirror: v2.31.0-develop
              [2025-01-20 20:36:52.114] [LOG]   Loading config ...
              [2025-01-20 20:36:52.116] [LOG]   config template file not exists, no envsubst
              [2025-01-20 20:36:52.693] [INFO]  Checking config file /home/mdwebb/MagicMirror/config/config.js ...
              [2025-01-20 20:36:52.837] [INFO]  Your configuration file doesn't contain syntax errors :)
              [2025-01-20 20:36:52.839] [INFO]  Checking modules structure configuration ...
              [2025-01-20 20:36:52.983] [INFO]  Your modules structure configuration doesn't contain errors :)
              [2025-01-20 20:36:52.985] [LOG]   Loading module helpers ...
              [2025-01-20 20:36:52.997] [LOG]   Initializing new module helper ...
              [2025-01-20 20:36:52.998] [LOG]   Module helper loaded: updatenotification
              [2025-01-20 20:36:52.999] [LOG]   No helper found for module: clock.
              [2025-01-20 20:36:53.000] [LOG]   No helper found for module: MMM-CountDown.
              [2025-01-20 20:36:53.244] [LOG]   Initializing new module helper ...
              [2025-01-20 20:36:53.244] [LOG]   Module helper loaded: MMM-ImagesPhotos
              [2025-01-20 20:36:53.265] [LOG]   Initializing new module helper ...
              [2025-01-20 20:36:53.265] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
              [2025-01-20 20:36:53.429] [LOG]   Initializing new module helper ...
              [2025-01-20 20:36:53.429] [LOG]   Module helper loaded: MMM-Config
              [2025-01-20 20:36:53.430] [LOG]   No helper found for module: MMM-CalendarExt3.
              [2025-01-20 20:36:53.430] [LOG]   No helper found for module: alert.
              [2025-01-20 20:36:53.526] [LOG]   Initializing new module helper ...
              [2025-01-20 20:36:53.527] [LOG]   Module helper loaded: calendar
              [2025-01-20 20:36:53.650] [LOG]   Initializing new module helper ...
              [2025-01-20 20:36:53.650] [LOG]   Module helper loaded: MMM-Remote-Control
              [2025-01-20 20:36:53.698] [LOG]   Initializing new module helper ...
              [2025-01-20 20:36:53.698] [LOG]   Module helper loaded: MMM-ModuleScheduler
              [2025-01-20 20:36:53.699] [LOG]   All module helpers loaded.
              [2025-01-20 20:36:53.711] [LOG]   Starting server on port 8080 ...
              [2025-01-20 20:36:54.371] [LOG]   Server started ...
              [2025-01-20 20:36:54.377] [LOG]   Connecting socket for: updatenotification
              [2025-01-20 20:36:54.378] [LOG]   Starting module helper: updatenotification
              [2025-01-20 20:36:54.384] [LOG]   Connecting socket for: MMM-ImagesPhotos
              [2025-01-20 20:36:54.386] [LOG]   Starting node helper for: MMM-ImagesPhotos
              [2025-01-20 20:36:54.389] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
              [2025-01-20 20:36:54.390] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast
              [2025-01-20 20:36:54.396] [LOG]   Connecting socket for: MMM-Config
              [2025-01-20 20:36:54.727] [LOG]   will pull config data at 17:00:00 in 22985320 ms
              [2025-01-20 20:36:54.729] [LOG]   Connecting socket for: calendar
              [2025-01-20 20:36:54.736] [LOG]   Starting node helper for: calendar
              [2025-01-20 20:36:54.738] [LOG]   Connecting socket for: MMM-Remote-Control
              [2025-01-20 20:36:54.744] [LOG]   Starting node helper for: MMM-Remote-Control
              [2025-01-20 20:36:54.848] [LOG]   Connecting socket for: MMM-ModuleScheduler
              [2025-01-20 20:36:54.849] [LOG]   Starting node helper for: MMM-ModuleScheduler
              [2025-01-20 20:36:54.850] [LOG]   Sockets connected & modules started ...
              [2025-01-20 20:36:55.644] [LOG]   Launching application.
              [2025-01-20 20:36:57.126] [INFO]  System information:
              ### SYSTEM:   manufacturer: ; model: ; virtual: false
              ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
              ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
              ### OTHER:    timeZone: Australia/Melbourne; ELECTRON_ENABLE_GPU: undefined
              [2025-01-20 20:36:57.162] [ERROR] ERROR! Could not validate main module js file.
              [2025-01-20 20:36:57.168] [ERROR] ReferenceError: HTMLElement is not defined
                  at Object.<anonymous> (/home/mdwebb/MagicMirror/modules/MMM-CalendarExt3/MMM-CalendarExt3.js:6:26)
                  at Module._compile (node:internal/modules/cjs/loader:1484:14)
                  at Module._extensions..js (node:internal/modules/cjs/loader:1564:10)
                  at Module.load (node:internal/modules/cjs/loader:1295:32)
                  at Module._load (node:internal/modules/cjs/loader:1111:12)
                  at c._load (node:electron/js2c/node_init:2:16955)
                  at Module.require (node:internal/modules/cjs/loader:1318:19)
                  at require (node:internal/modules/helpers:179:18)
                  at Class.loadModuleDefaultConfig (/home/mdwebb/MagicMirror/modules/MMM-Remote-Control/node_helper.js:317:30)
                  at /home/mdwebb/MagicMirror/modules/MMM-Remote-Control/node_helper.js:271:26
                  at FSReqCallback.oncomplete (node:fs:198:5)
              [3636:0120/203657.414249:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [3636:0120/203657.423716:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [3636:0120/203657.424432:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [3636:0120/203657.424789:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [3636:0120/203657.425361:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [3636:0120/203657.425726:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [3636:0120/203657.426131:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [3636:0120/203657.426495:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [3636:0120/203657.431838:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [3636:0120/203657.439567:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [3636:0120/203657.451490:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [3636:0120/203657.455922:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [3636:0120/203657.456469:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [3636:0120/203657.456802:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [3636:0120/203657.458595:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [3636:0120/203657.463710:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [3636:0120/203657.468093:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [3636:0120/203657.471514:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [3636:0120/203657.472361:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [3636:0120/203657.472678:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [3636:0120/203657.473397:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [3636:0120/203657.479438:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [3636:0120/203657.485371:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [3636:0120/203657.485794:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [3636:0120/203657.486390:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [3636:0120/203657.486682:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [3636:0120/203657.487070:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
              [3636:0120/203657.488116:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
              [2025-01-20 20:36:58.222] [LOG]
              [2025-01-20 20:37:00.003] [LOG]   Config based debug=module_3_MMM-ImagesPhotos
              [2025-01-20 20:37:00.008] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/ - Interval: 3600000
              [2025-01-20 20:37:00.017] [LOG]   MMM-ModuleScheduler is removing all scheduled jobs
              [2025-01-20 20:37:00.018] [LOG]   MMM-ModuleScheduler received CREATE_NOTIFICATION_SCHEDULE
              [2025-01-20 20:37:00.021] [LOG]   MMM-ModuleScheduler cannot create schedule. Missing `schedule` in `notification_schedule`: true
              [2025-01-20 20:37:00.029] [INFO]  updatenotification: Updater Class Loaded!
              [2025-01-20 20:37:00.030] [INFO]  updatenotification: Checking PM2 using...
              [2025-01-20 20:37:00.031] [INFO]  updatenotification: [PM2] You are not using pm2
              [2025-01-20 20:37:00.033] [INFO]  Checking git for module: MMM-CountDown
              [2025-01-20 20:37:00.070] [INFO]  Checking git for module: MMM-ImagesPhotos
              [2025-01-20 20:37:00.104] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
              [2025-01-20 20:37:00.171] [INFO]  Checking git for module: MMM-Config
              [2025-01-20 20:37:00.213] [INFO]  Checking git for module: MMM-CalendarExt3
              [2025-01-20 20:37:00.240] [INFO]  Checking git for module: MMM-Remote-Control
              [2025-01-20 20:37:00.265] [INFO]  Checking git for module: MMM-ModuleScheduler
              [2025-01-20 20:37:00.319] [INFO]  Checking git for module: MagicMirror
              [2025-01-20 20:37:05.720] [INFO]  Calendar-Fetcher: Broadcasting 970 events from https://calendar.google.com/calendar/ical...
              [2025-01-20 20:37:06.063] [LOG]   Shutting down server...
              [2025-01-20 20:37:06.066] [LOG]   Stopping module helper: updatenotification
              [2025-01-20 20:37:06.067] [LOG]   Stopping module helper: MMM-ImagesPhotos
              [2025-01-20 20:37:06.069] [LOG]   Stopping module helper: MMM-OpenWeatherMapForecast
              [2025-01-20 20:37:06.070] [LOG]   Stopping module helper: MMM-Config
              [2025-01-20 20:37:06.071] [LOG]   Stopping module helper: calendar
              [2025-01-20 20:37:06.076] [LOG]   Stopping module helper: MMM-ModuleScheduler
              [2025-01-20 20:37:06.078] [LOG]   Node_helpers stopped ...
              Config file
                var config = {
                  address: "0.0.0.0",
                  port: 8080,
                  basePath: "/",
                  ipWhitelist: [
                    "127.0.0.1",
                    "::ffff:127.0.0.1",
                    "::1",
                    "192.000.00.000",
                    "192.000.00.00"
                  language: "en",
                  locale: "en-US",
                  logLevel: [
                    "INFO",
                    "LOG",
                    "WARN",
                    "ERROR"
                  timeFormat: 24,
                  units: "metric",
                  useHttps: false,
                      module: "updatenotification",
                      position: "top_bar",
                      order: "*",
                      disabled: false,
                      animateIn: "None",
                      animateOut: "None",
                      config: {}
                      module: "clock",
                      order: "*",
                      animateIn: "None",
                      animateOut: "None",
                      index: 0,
                      label: "instance 1",
                        displayType: "digital",
                        timeFormat: "24",
                        displaySeconds: true,
                        showPeriod: true,
                        showDate: true,
                        showTime: true,
                        dateFormat: "dddd, LL",
                        analogSize: "200px",
                        analogFace: "simple",
                        analogPlacement: "bottom",
                        analogShowDate: "top",
                        secondsColor: "#888888",
                        lat: 47.630539,
                        lon: -122.344147,
                        showPeriodUpper: false,
                        clockBold: false,
                        showWeek: false,
                        sendNotifications: false,
                        showSunTimes: false,
                        showMoonTimes: false
                      disabled: false
                      module: "MMM-CountDown",
                        date: "2025-02-21",
                        event: "Webb Holiday"
                      order: "*",
                      disabled: false,
                      animateIn: "None",
                      animateOut: "None"
                      module: "MMM-ImagesPhotos",
                      position: "top_center",
                        animationSpeed: 1000,
                        updateInterval: 30000,
                        maxHeight: "500px",
                        maxWidth: "500px",
                        path: ""
                      order: "*",
                      disabled: false,
                      animateIn: "None",
                      animateOut: "None"
                      module: "weather",
                      disabled: true,
                      order: "*",
                      index: 0,
                      animateIn: "none",
                      animateOut: "none",
                        weatherProvider: "openmeteo",
                        type: "current",
                        units: "metric",
                        tempUnits: "metric",
                        windUnits: "metric",
                        timeFormat: "24",
                        useBeaufort: true,
                        lang: "en",
                        useKmh: false,
                        showHumidity: false
                      module: "weather",
                      disabled: true,
                      label: "instance 2",
                      order: "*",
                      index: 1,
                      animateIn: "none",
                      animateOut: "none",
                        type: "forecast",
                        units: "metric",
                        updateInterval: 600000,
                        timeFormat: "24",
                        showPeriod: true,
                        showWindDirection: true,
                        useBeaufort: true,
                        lang: "en",
                        showSun: true,
                        decimalSymbol: ".",
                        maxNumberOfDays: 5,
                        maxEntries: 5,
                        fade: true,
                        fadePoint: 0.25,
                        initialLoadDelay: 0,
                        appendLocationNameToHeader: true,
                        calendarClass: "calendar",
                        tableClass: "small",
                        showFeelsLike: true,
                        roundTemp: false,
                        useKmh: false,
                        showWindDirectionAsArrow: false,
                        showHumidity: false,
                        degreeLabel: false,
                        showIndoorTemperature: false,
                        showIndoorHumidity: false,
                        ignoreToday: false,
                        onlyTemp: false,
                        showPrecipitationAmount: false,
                        colored: false,
                        absoluteDates: false
                      module: "MMM-OpenWeatherMapForecast",
                      header: "Weather",
                      classes: "default everyone",
                        apikey: "",
                        latitude: "-38.314560",
                        longitude: "146.419373",
                        iconset: "4c",
                        concise: false,
                        forecastLayout: "table",
                        maxDailiesToShow: 5,
                        showWind: false,
                        units: "metric",
                        language: "en",
                        showExtraCurrentConditions: false,
                        showHourlyForecast: false,
                        forecastHeaderText: ""
                      order: "*",
                      disabled: false,
                      animateIn: "None",
                      animateOut: "None"
                      module: "MMM-Config",
                        restart: "none"
                      order: "*",
                      disabled: false,
                      animateIn: "none",
                      animateOut: "none"
                      module: "MMM-CalendarExt3",
                      position: "bottom_bar",
                      title: "",
                        instanceId: "basicCalendar",
                        locale: "en-US",
                        maxEventLines: 6,
                        firstDayOfWeek: "0",
                        weekIndex: 0,
                        weeksInView: 4,
                        eventHeight: "15px",
                        useMarquee: true,
                        refreshInterval: 600,
                        eventTransformer: (ev)=> {
                if (ev.title.search('DINNER') > -1) ev.symbol = ['fluent-color:food-28']
                if (ev.title.search('Arnold') > -1) ev.symbol = ['fluent-emoji-flat:dog']
                if (ev.title.search('Gus') > -1) ev.symbol = ['fluent-emoji-flat:dog']
                if (ev.title.search('Dogs') > -1) ev.symbol = ['fluent-emoji-flat:dog']
                if (ev.title.search('dogs') > -1) ev.symbol = ['fluent-emoji-flat:dog']
                if (ev.title.search('Marcus') > -1) ev.symbol = ['noto:pretzel']
                if (ev.title.search('Pretzel') > -1) ev.symbol = ['noto:pretzel']
                if (ev.title.search('Recycle Bin') > -1) ev.symbol = ['game-icons:soda-bottle']
                if (ev.title.search('Green Waste bins') > -1) ev.symbol = ['streamline-emojis:leaf-fluttering-in-wind']
                if (ev.title.search('Cleaning Day') > -1) ev.symbol = ['openmoji:broom']
                if (ev.title.search('Swimming') > -1) ev.symbol = ['fxemoji:swimming']
                if (ev.title.search('Phils') > -1) ev.symbol = ['twemoji:baby-angel-light-skin-tone']
                if (ev.title.search('Phyllis') > -1) ev.symbol = ['twemoji:baby-angel-light-skin-tone']
                if (ev.title.search('Birthday') > -1) ev.symbol = ['emojione:birthday-cake']
                if (ev.title.search('birthday') > -1) ev.symbol = ['emojione:birthday-cake']
                if (ev.title.search('Hugo') > -1) ev.symbol = ['cryptocurrency-color:hight']
                if (ev.title.search('Maggie') > -1) ev.symbol = ['cryptocurrency-color:xmy']
                if (ev.title.search('Lucas') > -1) ev.symbol = ['openmoji:man-judge-light-skin-tone']
                if (ev.title.search('Hudge') > -1) ev.symbol = ['twemoji:gemini']
                if (ev.title.search('Danielle') > -1) ev.symbol = ['twemoji:gemini']
                if (ev.title.search('Factory') > -1) ev.symbol = ['emojione-v1:cow']
                if (ev.title.search('factory') > -1) ev.symbol = ['emojione-v1:cow']
                return ev
                        eventFilter: (ev) =>  {
               return true
                        manipulateDateCell: (cellDom, events) =>  {
                        weatherPayload: (payload) =>  {
               return payload
                        eventPayload: (payload) =>  {
               return payload
                      order: "*",
                      disabled: false,
                      animateIn: "None",
                      animateOut: "None"
                      module: "newsfeed",
                      disabled: true,
                      order: "*",
                      animateIn: "None",
                      animateOut: "None",
                      index: 0,
                        feeds: [
                            title: "New York Times",
                            url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml",
                            encoding: "UTF-8"
                        showSourceTitle: true,
                        showPublishDate: true,
                        broadcastNewsFeeds: true,
                        broadcastNewsUpdates: true,
                        wrapTitle: true,
                        wrapDescription: true,
                        truncDescription: true,
                        lengthDescription: 400,
                        reloadInterval: 300000,
                        updateInterval: 10000,
                        animationSpeed: 2500,
                        maxNewsItems: 0,
                        ignoreOlderThan: 86400000,
                        scrollLength: 500,
                        showAsList: false,
                        showDescription: false,
                        showTitleAsUrl: false,
                        hideLoading: false,
                        ignoreOldItems: false,
                        logFeedWarnings: false,
                        dangerouslyDisableAutoEscaping: false,
                        startTags: [],
                        endTags: [],
                        prohibitedWords: []
                      module: "alert",
                      order: "*",
                      animateIn: "None",
                      animateOut: "None",
                      index: 0,
                        effect: "slide",
                        alert_effect: "jelly",
                        display_time: 3500,
                        position: "center",
                        welcome_message: false
                      disabled: false
                      order: "*",
                      animateIn: "None",
                      animateOut: "None",
                      index: 0,
                        maximumEntries: 10,
                        maximumNumberOfDays: 365,
                        limitDays: 0,
                        pastDaysCount: 0,
                        displaySymbol: true,
                        defaultSymbol: "calendar-alt",
                        defaultSymbolClassName: "fas fa-fw fa-",
                        maxTitleLength: 25,
                        maxLocationTitleLength: 25,
                        maxTitleLines: 3,
                        maxEventTitleLines: 3,
                        fetchInterval: 3600000,
                        animationSpeed: 2000,
                        fade: true,
                        fadePoint: 0.25,
                        urgency: 7,
                        timeFormat: "relative",
                        dateFormat: "MMM Do",
                        dateEndFormat: "LT",
                        fullDayEventDateFormat: "MMM Do",
                        getRelative: 6,
                        hideDuplicates: true,
                            symbol: "calendar-alt",
                            url: "https://calendar.google.com/calendar/ical/
                        customEvents: [
                            keyword: ".*",
                            transform: {
                              search: "De verjaardag van "
                            keyword: ".*",
                            transform: {
                              search: "'s birthday"
                        locationTitleReplace: {
                          "street ": ""
                        broadcastEvents: true,
                        broadcastPastEvents: true,
                        updateOnFetch: true,
                        showLocation: false,
                        displayRepeatingCountTitle: false,
                        wrapEvents: false,
                        wrapLocationEvents: false,
                        showEnd: false,
                        showEndsOnlyWithDuration: false,
                        hidePrivate: false,
                        hideOngoing: false,
                        hideTime: false,
                        showTimeToday: false,
                        colored: false,
                        forceUseCurrentTime: false,
                        sliceMultiDayEvents: false,
                        nextDaysRelative: false,
                        selfSignedCert: false,
                        coloredText: false,
                        coloredBorder: false,
                        coloredSymbol: false,
                        coloredBackground: false,
                        limitDaysNeverSkip: false,
                        flipDateHeaderTitle: false,
                        excludedEvents: []
                      disabled: false
                      module: "MMM-Remote-Control",
                        apiKey: ""
                      order: "*",
                      disabled: false,
                      animateIn: "None",
                      animateOut: "None"
                      module: "MMM-ModuleScheduler",
                        notification_schedule: true
                      order: "*",
                      disabled: false,
                      animateIn: "None",
                      animateOut: "None"
              S M 4 Replies Last reply Reply Quote 0
                sdetweil @MDWEBB
                @MDWEBB hm, could not validate file…
                edit: ---- you said you reinstalled, so this is not a file corruption problem
                lets go to the MMM-CalendarExt3 folder
                and do
                git status
                it should not list any files
                please show the reults
                  sdetweil @MDWEBB
                  @MDWEBB also you changed refreshInterval to 600
                  milliseconds down from 30 minutes!! (the module cannot redraw that fast)
                  i think you need to change the waitFetch value up to 10000
                  milliseconds.
                  i don’t think refreshInterval should ever be less that 300000
                  (5 minutes)
                    @MDWEBB I could not recreate the error by setting one of my Ext3 instances to refreshInterval :600
                      @MDWEBB
                      BUT… just for the sake of testing something… MMM-Config saved the prior config.js
                      so if you
                      cd~/MagicMirror/config
                      #rename this one out of the way
                      mv config.js save-config.js
                      ls config -laFt config.*
                      #and copy the top one back to config.js
                      #mark the filename, right click mouse
                      cp -rightclick-paste config.js
                      and then restart MagicMirror
                      do you still get the error??
                        sdetweil
                        I added the default modules to have links to their config doc too… (in configuration)
                        I made significant changes to the weather form layout, using select lists and custom field sets per weather provider.
                        updated the schemas MMM-Config ships to add the view readme button
                          MMRIZE @MDWEBB
                          @MDWEBB said in New module installer:
                          This error message seems to be caused by some JS validator trying to check the browser-oriented syntax on the nodeJS environment.
                          @MDWEBB
                          You’d better start from a clean configuration and then add one by one to find what was wrong.
                            sdetweil @MDWEBB
                            I bet this is the remote-control error…
                            shouldn’t stop anything
                            but, if you want to try my fork, which captures that error
                            https://github.com/sdetweil/MMM-Remote-Control
                            just remove the existing folder and git clone mine in its place
                            no functional code change or parms… just trapping this error
                              MDWEBB @sdetweil
                              @sdetweil Apologise for slow reply i was able to remove the node modules file and run the update for the module and now my calendar is working again.
                                sdetweil @MDWEBB
                                @MDWEBB no apologies required
                                updated what module?
                                  MDWEBB @sdetweil
                                  @sdetweil update MMM-Remotecontrol.
                                  I am getting update notifications for both the MMM-Config module and MMM-Remote-Control.
                                  MMM-Config says its 3 commits behind the with_installer branch. Not sure whats happening with that
                                  MMM-Remote-Control s 8 commits behind on the master branch i get the following error when trying to use the update script though
                                  mdwebb@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-Remote-Control # adapt directory if you are using a different one
                                  git pull
                                  npm install # install (new) dependencies
                                  Updating 76c0859..5c39b06
                                  error: Your local changes to the following files would be overwritten by merge:
                                  	modules.json
                                  	package-lock.json
                                  	package.json
                                  Please commit your changes or stash them before you merge.
                                  Aborting
                                  up to date, audited 340 packages in 3s
                                  103 packages are looking for funding
                                    run `npm fund` for details
                                  found 0 vulnerabilities
                                    sdetweil @MDWEBB
                                    @MDWEBB yes there are updates to mmm-config
                                    are you using my remotecontrol repo?
                                    i would disable the updatenotification module
                                      MDWEBB @sdetweil
                                      @sdetweil i am using your remote control module yes very handy, however having issues utilising the MMM-Module-Scheduler to to turn my monitor on and off via Remote-Control. i can see in the developer window its trying to send the notification however my monitor isn’t turning off. Am i missing something?
                                              module: 'MMM-ModuleScheduler',
                                                  notification_schedule: [
                                                      // TURN THE MONITOR/SCREEN ON AT 07:30 EVERY DAY
                                                      {notification: 'REMOTE_ACTION', schedule: '30 7 * * *', payload: {action: "MONITORON"}},
                                                      // TURN THE MONITOR/SCREEN OFF AT 22:30 EVERY DAY
                                                      {notification: 'REMOTE_ACTION', schedule: '01 14 * * *', payload: {action: "MONITOROFF"}},
                                                      // RESTART THE MAGICMIRROR PROCESS AT 2am EVERY SUNDAY
                                                      {notification: 'REMOTE_ACTION', schedule: '0 2 * * SUN', payload: {action: "RESTART"}}
                                        sdetweil @MDWEBB
                                        @MDWEBB issue on remotecontrol
                                        is not MY remote control, I just fixed the error trap that was misleading
                                        no other code change
                                        https://github.com/Jopyth/MMM-Remote-Control/issues/303
                                        which one of the 10 or 12 ways does it try to turn monitor off??
                                        which OS is different
                                        which window compositor is different x11/wayland/labwc is different
                                        I know MMM-PIR has been working hard on making it woirk thru all the choices
                                        did it work before and doesn’t now??
                                        I don’t know the module internals…
                                          @MDWEBB I just resynced my fork with his latest remote-control
                                          he had most of my changes and seemed to catch that error… maybe
                                            sdetweil
                                            I just updated the code again, this time to provide opening the readme for the repo in both install and config
                                            its on a different branch again
                                            git pull
                                            git checkout better_repo_url
                                            npm install     # <--- required.. added another library and copies a template file
                                            everything else is the same, except there is a button to open the module readme
                                            an example from the installer page, exactly the same on the config page
                                            still have some trouble with our own docs site, gitlab
                                            the readme window will open at the button position
                                            • 2 / 3
