    Display values from a JSON file hosted online
    10 Posts 4 Posters 6.0k Views 4 Watching
    • L Offline
      looolz
      Want to display two fields from this file:
      https://www.dropbox.com/s/k1t6mjjc3knxp3a/dataset.json?raw=1
      Kind of like this:
      Customers today - Astronomy department:
      88
      The file looks like this:
      "graph": {
      "title" : "Customers today",
      "total" : true,
      "datasequences" : [
      "title" : "Astronomy department",
      "datapoints" : [
      { "title" : "Amount", "value" : 88 }
      I want to display the amount value (88 in the example), and the titles, (Customers today and Astronomy department in the example).
      The module I have so far looks like this:
      Module.register("MMM-backlog",{
      	// Default module config.
      	defaults: {
      		text: "test text"
      	// Override dom generator.
      	getDom: function() {
      		wrapper.innerHTML = this.config.text;
      		return wrapper;
      Anybody able to help me get it working?
      • Y Offline
        yawns Moderator
        Quick and dirty, but should get you going :)
        You have to use the node_helper, because using XMLHttpRequest would result in an “origin error”.
        MMM-backlog.js
        /* global Module */
        /* Magic Mirror
         * Module: MMM-backlog
         * By Stefan Krause http://yawns.de
         * MIT Licensed.
        Module.register('MMM-backlog',{
        	defaults: {
        		units: config.units,
        		animationSpeed: 1000,
        		updateInterval: 1000 * 3600, //update every hour
        		refreshInterval: 1000 * 60 * 10, //refresh every minute
        		timeFormat: config.timeFormat,
        		lang: config.language,
        		initialLoadDelay: 0, // 0 seconds delay
        		retryDelay: 2500,
        		fileUrl: "https://www.dropbox.com/s/k1t6mjjc3knxp3a/dataset.json?raw=1"
        	// Define required scripts.
        	getScripts: function() {
        		return ["moment.js"];
        	// Define requird styles
        	getStyles: function() {
        		return ["font-awesome.css"];
        	start: function() {
        		Log.info('Starting module: ' + this.name);
        		this.loaded = false;
        		this.sendSocketNotification('CONFIG', this.config);
        		if (!this.loaded) {
        			wrapper.innerHTML = this.translate('LOADING');
        			wrapper.className = "dimmed light small";
        			return wrapper;
        		if (!this.data) {
        			wrapper.innerHTML = "No data";
        			return wrapper;
        		var t = this.data.graph;
        		var content = document.createElement("div");
        		content.innerHTML = "";
        		for (var i in t.datasequences) {
        			content.innerHTML += t.title  + " - " + t.datasequences[i].title + "<br />";
        			for (var j in t.datasequences[i].datapoints) {
        				content.innerHTML += t.datasequences[i].datapoints[j].title + ": " + t.datasequences[i].datapoints[j].value + "<br />";
        		wrapper.appendChild(content);
        		return wrapper;
            		if (notification === "STARTED") {
        				this.updateDom();
        			else if (notification === "DATA") {
        				this.loaded = true;
        				this.processData(JSON.parse(payload));
        				this.updateDom();
        	/* processData(data)
        	 * Uses the received data to set the various values.
        	 * argument data object - tide information received form worldtides.info
        	processData: function(data) {
        		if (!data) {
        			// Did not receive usable new data.
        			// Maybe this needs a better check?
        			return;
        		this.data = data;
        		this.loaded = true;
        		this.updateDom(this.config.animationSpeed);
        node_helper.js
        'use strict';
        /* Magic Mirror
         * MIT Licensed.
        const NodeHelper = require('node_helper');
        var request = require('request');
        	start: function() {
        		this.started = false;
        		this.config = null;
        	getData: function() {
        		var self = this;
        		var myUrl = this.config.fileUrl;
        		request({
        			url: myUrl,
        			method: 'GET',
        		}, function (error, response, body) {
        			if (!error && response.statusCode == 200) {
        				self.sendSocketNotification("DATA", body);
        		setTimeout(function() { self.getData(); }, this.config.refreshInterval);
        		var self = this;
        		if (notification === 'CONFIG' && self.started == false) {
        			self.config = payload;
        			self.sendSocketNotification("STARTED", true);
        			self.getData();
        			self.started = true;
        • L Offline
          looolz
          wow! This looks great! I cant wait to try this out!
          Thank you so much! 👍🏻
          • L Offline
            looolz
            @yawns HAVE MY BABIES!
            It works! Thank you so much! I’ll now start to play around with the CSS! Thank you so much! :)
            • Y Offline
              yawns Moderator @looolz
              Glad it gets you going. Of course you can add more divs/spans or even a table to place your output and adjust proper css to single lines or values.
              If you need explanation of single commands or routines just let us know.
              @looolz said in Display values from a JSON file hosted online:
              I doubt my wife would be happy with that :rofl:
              • L Offline
                looolz
                You are very kind!
                I’ve got a couple of issues so far:
                1: The module doesn’t seem to survive a manual refresh. For some reason, if I hit CTRL R to refresh, all other modules load, but this one is stuck at “loading…” If I do CTRL Q, quit the Magic Mirror and try again, it works. Even more strangely, it does correctly update on it’s own, when the JSON file changes. Just a minor thing.
                2: I’ve been trying to create en separate class for the value, so that I can style the number individually. So I tried to create an element that I can style with xlarge from the css file. But so far I’ve only been able to style the titles. I tried to read up on this on w3schools.com, but it’s evident that I lack a pillar of information to understand the syntax completely.
                How would change the code to make the numbervalue an element I can style in the CSS?
                • Y Offline
                  yawns Moderator
                  1: This is a know issue. If the module uses a node_helper, it does not survive a manual refresh of the webpage. It requires a restart of the magic mirror process. If someone knows how to get rid of this, I am more than happy to learn. @Module-Developers
                  2:
                  		if (!this.loaded) {
                  			return wrapper;
                  		if (!this.data) {
                  			return wrapper;
                  		var titleDiv = document.createElement("div");
                  		var dataDiv = document.createElement("div");
                  		var titleDataSpan = document.createElement("span");
                  		var valueDataSpan = document.createElement("span");
                  			titleDiv.className = "LIST YOUR CLASSES HERE";
                  			titleDiv.innerHTML = t.title  + " - " + t.datasequences[i].title;
                  			content.appendChild(titleDiv);
                  				dataDiv.className = "LIST YOUR CLASSES HERE";
                  				titleDataSpan.className = "LIST YOUR CLASSES HERE";
                  				titleDataSpan.innerHTML = t.datasequences[i].datapoints[j].title + ":";
                  				valueDataSpan.className = "LIST YOUR CLASSES HERE";
                  				valueDataSpan.innerHTML = t.datasequences[i].datapoints[j].value;
                  				dataDiv.appendChild(titleDataSpan);
                  				dataDiv.appendChild(valueDataSpan);
                  				content.appendChild(dataDiv);
                  		return wrapper;
                  You could even use the datapoint title (“amount” in this example), define a css class with this selector and add the datapoint title to the list of classnames ;)
                  I did not test it, I just wrote it in notepad++, so there might be a typo. You could also try to add more entries to your JSON file to see if the loops are correct and fetch all data.
                  • strawberry 3.141S Offline
                    strawberry 3.141 Project Sponsor Module Developer @yawns
                    @yawns i could imagine that the start flag of the node_helper is still true so the getdata call gets skipped
                    Y 1 Reply Last reply Reply Quote 1
                    • Y Offline
                      yawns Moderator @strawberry 3.141
                      @strawberry-3.141
                      good point. Maybe I find some time at the weekend to debug this and check where it is stopping/skipping
                      • E Offline
                        E3V3A @yawns
                        @yawns Was that re-load issue ever resolved? I have my own basic issues and I’m considering using this code instead…
                        "Everything I do (here) is for free – altruism is the way!"
                        MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
