    MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call
    67 Posts 6 Posters 13.5k Views 7 Watching
      rkorell @xIExodusIx
      @xIExodusIx Dear Carsten, this is awesome!
      Thanks a LOT!
      Currently - in my installation - the Info Box which is signalling the call is not a „message-box“ and disappears when call is ended.
      Did you modify this -then I would hesitate to install newest version…
      Thanks a lot for your effort!
      Warmest regards,
      Ralf
      X 1 Reply Last reply Reply Quote 0
      • X Offline
        xIExodusIx @rkorell
        @rkorell said in MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call:
        Hi Ralf,
        I did not change the appearance of the message-box, in the module it is an alert, I only tried to let it disappear right when you answer the incomming call, because on my MM2 the message box blurres the background and I can not clearly see all other modules and the “MMM-Current-Call” module, that also shows me if the current call is incomming or outgoing, but now the message box disappears when the incomming call is answered.
        The MMM-Current-Call" module makes only sense if you have more then one telephon-line, so you can see how many people are talking right now, and if the calls are incomming or outgoing.
        Hope that will help you to decide.
        Regards
        Carsten
          rkorell @xIExodusIx
          @xIExodusIx Thanks again, this helps!
          Regards,
          Ralf
          • X Offline
            xIExodusIx @rkorell
            @rkorell
            I played a little bit around with the colors and changed also the appearance of missed calls, the missed calls now will be displayed in color “magenta” with a “star”. You can edit the colors by yourself by editing the “MMM-Fritz-Box-Callmonitor-py3.js” file, you can’t miss these entrys.
            I also edited the README.md file again.
            I will push these changes to github at my next update, but I have to test a little bit more because I have to wait for the unwanted calls that are in my blocked “phonenumber range list”, and I don’t know when these unwanted calls are incomming.
            But hopefully I got most of the annoying problems under control. :-)
            Regards
            Carsten
              rkorell @xIExodusIx
              @xIExodusIx It’s good practise to keep style information not in the *.js code but in the CSS file of module - than everybody can make persistent changes to style related issues in custom.css which will not been overwritten by module updates…
              Warm regards,
              Ralf
              • X Offline
                xIExodusIx @rkorell
                @rkorell
                Yes, I know, but I don’t know how to transfer this code-lines to the .css file, the code for appaerance and color were in the module.js file before I began to try to get it work. I only modified them.
                The last two problems I have with the module is, to show the correct number in the callist, not “sip:myown number”, when an incomming call is blocket by the “number range list” and to hide the alert of these calls.
                On these problems I still work.
                Regards
                Carsten
                  rkorell @xIExodusIx
                  quick feedback for you: Just installed your newest version.
                  And - to my big surprise - it works like I would like to have…
                  I only have installed "MMM-FRITZ-Box-Callmonitor-py3 " - to be 100% clear, may there is the difference.
                  But with only this module incoming calls are displayed/signalled (grey’ish / white color) and the message box disappears either when the call is taken or if the caller hangs up.
                  This exactly is what I would like to have.
                  You definitely have done something magical because the initial code holds the message box until call is ended.
                  THANKS!!!
                  You ARE a coder :-)
                  Warmest greetings to Hamburg (as your git-account now reveals),
                  Ralf
                  For the CSS stuff - my apologies…
                  I cannot guide here, as well. I’ve seen your color coding in dependency from call-type.
                  I GUESS you can solve this with case-dependent CSS-attributes and so avoid the complete “switch”-clause.
                  But this is far beyond my own capabilities - may Sam (@sdetweil ) can lead through this…
                    Jose1701 @rkorell
                    I`m new to magicmirror and I like the CallMonitor a lot.
                    Everthing works fine for me except the arrows and colours. I installed MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call. I put the necessary information in the conifg as ou can see:
                    		module: 'MMM-Callmonitor-Current-Call',
                    		position: 'top_right',	// This can be any of the regions. Best results in left or right regions.
                    			showDirection: "true",
                    			colorEnabled: "true",
                    		module: 'MMM-FRITZ-Box-Callmonitor-py3',
                    		position: 'bottom_right',	// This can be any of the regions. Best results in left or right regions.
                    		header: "Letzte Anrufe", // This is optional
                    			showContactsStatus: "true",
                                	  fritzIP: "192.168.178.1",
                                	  maximumCallDistance: "240",
                                            maximumCalls: "4",
                                            reloadContactsInterval: "1",
                    			showOutgoing: "true",
                                            password: "******",
                    An idea what am I doing wrong?
                    Regards
                    Jose
                      rkorell @Jose1701
                      @Jose1701 Dear Jose,
                      you are referring to my post but may I’m the wrong person.
                      You may ask the developer, @xIExodusIx, too.
                      As I’m not knowing exactly what your problem is, I just can guess what’s going on…
                      from configuration perspective I do not see an issue - mine is similar.
                      As I wrote before I only have ‘MMM-FRITZ-Box-Callmonitor-py3’ in use, NOT ‘MMM-Callmonitor-Current-Call’,
                      For ‘MMM-FRITZ-Box-Callmonitor-py3’ I’m aware of some problems, but I do not know if this aligns with your problems.
                      • do you have the right (actual) fork? in my case this was https://github.com/xIExodusIx/MMM-FRITZ-Box-Callmonitor-py3.git
                      • I’m not sure if this is correct: In your config a username is missing. As far as I’m aware of you have to use a username/password combination - therefore I remember that I had to create a separate user for using the module.
                      • there were some requirements for the module - some python libraries as I remember correctly. - Do you have installed them in a proper version?
                      This is the “guessing” version.
                      If you could describe the “problem” more exact or concrete may we get other ideas…
                      Good luck!
                      Regards,
                      Ralf
                        Jose1701 @rkorell
                        @rkorell
                        sorry for the late response but I was ill and laying in bed.
                        I will have a look. Actually I have the following “proofed”.
                        Yes, I’m using this one, too.
                        Well, until now I didn’t need more. Everything is working fine except the arrows and colours. But I will see if sth. is needed.
                        I think I have the right ones and up to date but I will have a look, too.
                        Thanks so far.
                        Kind regards
                        Jose
                        • 6
                        • 7
                        • 5 / 7
