    MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call
    69 Posts 7 Posters 25.0k Views 8 Watching
    • X
      xIExodusIx @rkorell
      @rkorell
      I think it is something with the syntax, maybe it has changed somehow in python3, or a wrong set “,” or “;” so the modulescript could not run correct, but it is enough to let the module almost run as expected.
      For that I have not enough experience to figure that out.
      Would be nice if there were the possebility of a testing enviroment for MS-Windows, so that I could test the scripts. For editing I could use VS-Code.
        rkorell Module Developer @xIExodusIx
        @xIExodusIx said in MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call:
        For Python you can use this …
        Regards,
        Ralf
        X 1 Reply Last reply Reply Quote 0
        • X
          xIExodusIx @rkorell
          @rkorell
          Hi Ralf,
          I found out that the correct entry for handle “blocked calls” is “10”, not “4”, I found that on “https://fritzconnection.readthedocs.io/en/1.14.0/sources/library_modules.html”
          Slowly I understand how the module works and what the entire entries do, but without understandig the syntax and how to code. I will not come further.
          Regards
          Carsten
            @xIExodusIx
            Dear Carsten,
            quick question: For several reasons yesterday I had checked the log files during startup of my MagicMirror.
            Unfortunately there is an error related to your pimped module:
            [ERROR] ERROR! Could not find main module js file for MMM-FRITZ-Box-Callmonitor-py3_drtorchwood
            The module works (!?) but may there is something that don’t work?
            Is there a submodule which is not loaded to git?
            Thanks for any hint!
            • X
              xIExodusIx @rkorell
              @rkorell said in MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call:
              Hi Ralf,
              I have searched all my log-files in “.pm2/logs/” for that string, but I didn’t find anything related to that error. I don’t have this error in my pm2 log-files.
              Are there more log-files I can check, if so where can I find them?
              I’m sure you have checked your MagicMirror/config/config.js if there is a type missmatch.
              Reguards
              Carrsten
                @xIExodusIx It’s in the PM2 logs, yes.
                I guess you have some code parked in an additional file “py3_drtorchwood” which is present on your system but not on mine …
                especially drtorchwood isn’t present on my system at all.
                Will dig into code lateron …
                Thanks for your double check.
                Regards,
                Ralf
                • X
                  xIExodusIx @rkorell
                  @rkorell
                  Hi Ralf,
                  sorry it took a while to answer, what I did until now is:
                  I updated python on my raspberry pi 4 bookworm 64bit, to python 3.13.2 and I overworked the module MMM-FRITZ-Box Callmonitor-py3, it now handles almost all unwanted (blocked) calls, that are in your FritzBox callist for blocked calls, and shows them in the callist on your MM2.
                  But it can’t handle blocked numbers that are in the “area list”, that means numbers that begins with e.g. 0031* (+31*) all numbers from, in this example, Netherlands, they appear as “SIP:ownnumber” with a red X in the callist of your MM2. I can’t find out how to fetch the whole correct number that ist displayed in the FritzBox gui under incomming calls.
                  And I can’t find out how to let the alert “Incomming Call” disappear for that blocked calls.
                  Everything else should work as expected, for me it does.
                  Regards,
                  Carsten
                    @xIExodusIx
                    Carsten, as you stated, you cannot code - than this is really awsome!!!
                    Congratulations.
                    Did you maanage as well to let the message box disappear whan call is in progress?
                    Do you have pushed your modified code to github?
                    To my last posting: In fact there is NO occurance of “py3_drtorchwood” in ANY of my files …
                    So I will simply ignore the error message.
                    Warmest regards and chapeau !!!
                    Ralf
                    X 2 Replies Last reply Reply Quote 0
                    • X
                      xIExodusIx @rkorell
                      @rkorell
                      Hi Ralf,
                      Yes the message box disappears now when a call is in progress, and no I did not push my modificated code to github by now.
                      But sadly I can’t find out how to let the massage box disapper when a call is incomming that will be blocked. So the message box is displayed over hours on the screen, to let it disappear I have to connect to my MM2 using “RealVNC Viewer” and mouseclick on the message box, then it disappears. This is not satisfying.
                      With the update of python to version 3.13.2 I made a failure, that was not a good idea, so I have to reinstall my MM2 from scratch, what I’m doing right now. If this is done and all runs like I want again, I will push my modified code to githup. If this is done I will inform you.
                      I will continue to work on the module to eliminate the last few problems. I hope I can do it.
                      As I said I can’t code was and is this the truth, all I have done is to try to copy existing code lines change them a little bit and paste it where I thought it could be the right place, then pushed the entirely .js file up to my MM2 and tested it. If it doesn’t work I tried an other way and tested it again. So all I do is “Try and Error”, not really coding! But VSCode helps a lot.
                      Regards
                      Carsten
                      • X
                        xIExodusIx @rkorell
                        @rkorell
                        Hi Ralf,
                        I just pushed up my reworked version of the module “MMM-FRITZ-Box-Callmonitor-py3” to github.
                        I hope it works for you too.
                        Regards
                        Carsten
                          @xIExodusIx Dear Carsten, this is awesome!
                          Thanks a LOT!
                          Currently - in my installation - the Info Box which is signalling the call is not a „message-box“ and disappears when call is ended.
                          Did you modify this -then I would hesitate to install newest version…
                          Thanks a lot for your effort!
                          Warmest regards,
                          Ralf
                          • X
                            xIExodusIx @rkorell
                            Hi Ralf,
                            I did not change the appearance of the message-box, in the module it is an alert, I only tried to let it disappear right when you answer the incomming call, because on my MM2 the message box blurres the background and I can not clearly see all other modules and the “MMM-Current-Call” module, that also shows me if the current call is incomming or outgoing, but now the message box disappears when the incomming call is answered.
                            The MMM-Current-Call" module makes only sense if you have more then one telephon-line, so you can see how many people are talking right now, and if the calls are incomming or outgoing.
                            Hope that will help you to decide.
                            Regards
                            Carsten
                              @xIExodusIx Thanks again, this helps!
                              Regards,
                              Ralf
                              • X
                                xIExodusIx @rkorell
                                @rkorell
                                I played a little bit around with the colors and changed also the appearance of missed calls, the missed calls now will be displayed in color “magenta” with a “star”. You can edit the colors by yourself by editing the “MMM-Fritz-Box-Callmonitor-py3.js” file, you can’t miss these entrys.
                                I also edited the README.md file again.
                                I will push these changes to github at my next update, but I have to test a little bit more because I have to wait for the unwanted calls that are in my blocked “phonenumber range list”, and I don’t know when these unwanted calls are incomming.
                                But hopefully I got most of the annoying problems under control. :-)
                                Regards
                                Carsten
                                  @xIExodusIx It’s good practise to keep style information not in the *.js code but in the CSS file of module - than everybody can make persistent changes to style related issues in custom.css which will not been overwritten by module updates…
                                  Warm regards,
                                  Ralf
                                  • X
                                    xIExodusIx @rkorell
                                    @rkorell
                                    Yes, I know, but I don’t know how to transfer this code-lines to the .css file, the code for appaerance and color were in the module.js file before I began to try to get it work. I only modified them.
                                    The last two problems I have with the module is, to show the correct number in the callist, not “sip:myown number”, when an incomming call is blocket by the “number range list” and to hide the alert of these calls.
                                    On these problems I still work.
                                    Regards
                                    Carsten
                                      quick feedback for you: Just installed your newest version.
                                      And - to my big surprise - it works like I would like to have…
                                      I only have installed "MMM-FRITZ-Box-Callmonitor-py3 " - to be 100% clear, may there is the difference.
                                      But with only this module incoming calls are displayed/signalled (grey’ish / white color) and the message box disappears either when the call is taken or if the caller hangs up.
                                      This exactly is what I would like to have.
                                      You definitely have done something magical because the initial code holds the message box until call is ended.
                                      THANKS!!!
                                      You ARE a coder :-)
                                      Warmest greetings to Hamburg (as your git-account now reveals),
                                      Ralf
                                      For the CSS stuff - my apologies…
                                      I cannot guide here, as well. I’ve seen your color coding in dependency from call-type.
                                      I GUESS you can solve this with case-dependent CSS-attributes and so avoid the complete “switch”-clause.
                                      But this is far beyond my own capabilities - may Sam (@sdetweil ) can lead through this…
                                        Jose1701 @rkorell
                                        I`m new to magicmirror and I like the CallMonitor a lot.
                                        Everthing works fine for me except the arrows and colours. I installed MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call. I put the necessary information in the conifg as ou can see:
                                        		module: 'MMM-Callmonitor-Current-Call',
                                        		position: 'top_right',	// This can be any of the regions. Best results in left or right regions.
                                        			showDirection: "true",
                                        			colorEnabled: "true",
                                        		module: 'MMM-FRITZ-Box-Callmonitor-py3',
                                        		position: 'bottom_right',	// This can be any of the regions. Best results in left or right regions.
                                        		header: "Letzte Anrufe", // This is optional
                                        			showContactsStatus: "true",
                                                    	  fritzIP: "192.168.178.1",
                                                    	  maximumCallDistance: "240",
        maximumCalls: "4",
        reloadContactsInterval: "1",
                                        			showOutgoing: "true",
        password: "******",
                                        An idea what am I doing wrong?
                                        Regards
                                        Jose
                                          rkorell Module Developer @Jose1701
                                          @Jose1701 Dear Jose,
                                          you are referring to my post but may I’m the wrong person.
                                          You may ask the developer, @xIExodusIx, too.
                                          As I’m not knowing exactly what your problem is, I just can guess what’s going on…
                                          from configuration perspective I do not see an issue - mine is similar.
                                          As I wrote before I only have ‘MMM-FRITZ-Box-Callmonitor-py3’ in use, NOT ‘MMM-Callmonitor-Current-Call’,
                                          For ‘MMM-FRITZ-Box-Callmonitor-py3’ I’m aware of some problems, but I do not know if this aligns with your problems.
                                          • do you have the right (actual) fork? in my case this was https://github.com/xIExodusIx/MMM-FRITZ-Box-Callmonitor-py3.git
                                          • I’m not sure if this is correct: In your config a username is missing. As far as I’m aware of you have to use a username/password combination - therefore I remember that I had to create a separate user for using the module.
                                          • there were some requirements for the module - some python libraries as I remember correctly. - Do you have installed them in a proper version?
                                          This is the “guessing” version.
                                          If you could describe the “problem” more exact or concrete may we get other ideas…
                                          Good luck!
                                          Regards,
                                          Ralf
                                            Jose1701 @rkorell
                                            @rkorell
                                            sorry for the late response but I was ill and laying in bed.
                                            I will have a look. Actually I have the following “proofed”.
                                            Yes, I’m using this one, too.
                                            Well, until now I didn’t need more. Everything is working fine except the arrows and colours. But I will see if sth. is needed.
                                            I think I have the right ones and up to date but I will have a look, too.
                                            Thanks so far.
                                            Kind regards
                                            Jose
                                            • 2 / 4
